  Instrument cluster issue (Page 1)
   Bottom of Page
This topic is 2 pages long:   1  2
next newest topic | next oldest topic
Author Topic:   Instrument cluster issue
Nick00800
posted 02-07-2018 08:16 PM     Click Here to See the Profile for Nick00800     send a private message to Nick00800   Edit/Delete Message   Reply w/Quote   Search for more posts by Nick00800
Took out prowler today for first time in a while. Everything was working fine. Stopped somewhere for a quick beer and when I got back into the car the only gauge that worked was the voltage and the air bag warning light was on. Any ideas? I'm hoping just a fuse.
garysss
posted 02-07-2018 08:26 PM     Click Here to See the Profile for garysss     send a private message to garysss   Edit/Delete Message   Reply w/Quote   Search for more posts by garysss
Did you shut if off and restart it again? Make sure your battery terminals are tight also.
Nick00800
posted 02-07-2018 09:04 PM     Click Here to See the Profile for Nick00800     send a private message to Nick00800   Edit/Delete Message   Reply w/Quote   Search for more posts by Nick00800
Did start and restart but will check terminals.
Thanks
TLRandall
posted 02-07-2018 09:29 PM     Click Here to See the Profile for TLRandall     send a private message to TLRandall   Edit/Delete Message   Reply w/Quote   Search for more posts by TLRandall
What does your odometer and gear selection screen read?
Nick00800
posted 02-07-2018 09:47 PM     Click Here to See the Profile for Nick00800     send a private message to Nick00800   Edit/Delete Message   Reply w/Quote   Search for more posts by Nick00800
It doesn't read. Only two of the possible lights show up
ClayD
posted 02-07-2018 10:25 PM     Click Here to See the Profile for ClayD     send a private message to ClayD   Edit/Delete Message   Reply w/Quote   Search for more posts by ClayD
My 97 had the same symptoms. A capacitor on the cluster circuit board had leaked and failed. Replaced it, all is well. There's a thread on here about that, but I can't find the dern thing.
401KAT
posted 02-07-2018 10:50 PM     Click Here to See the Profile for 401KAT     send a private message to 401KAT   Edit/Delete Message   Reply w/Quote   Search for more posts by 401KAT
And here"s where Robin enters......Don't let us down my friend......
ClayD
posted 02-07-2018 11:04 PM     Click Here to See the Profile for ClayD     send a private message to ClayD   Edit/Delete Message   Reply w/Quote   Search for more posts by ClayD
Found it:
http://www.prowleronline.com/ubb/Forum2/HTML/005603.html
Nick00800
posted 02-07-2018 11:08 PM     Click Here to See the Profile for Nick00800     send a private message to Nick00800   Edit/Delete Message   Reply w/Quote   Search for more posts by Nick00800
Thanks. I just got back from where I have the car stored. Started it up and everythi g worked fine. I told my wife about it and she actually said it happened to her too but forgot to tell me.
I wonder if just a bad connection. Did your work intermittently or just never work?
ClayD
posted 02-08-2018 12:42 AM     Click Here to See the Profile for ClayD     send a private message to ClayD   Edit/Delete Message   Reply w/Quote   Search for more posts by ClayD
Mine never worked until I replaced the capacitor. Doesn't sound like you have that problem.
TLRandall
posted 02-08-2018 07:43 AM     Click Here to See the Profile for TLRandall     send a private message to TLRandall   Edit/Delete Message   Reply w/Quote   Search for more posts by TLRandall
Both my 99s are doing the same thing. Started off as intermittent, but eventually it will stay like it is now. I swapped clusters with a known working cluster, replaced batteries, checked and cleaned all grounds, checked all fuses and relays, unplugged and replugged all harness connectors. I still need to take it to the dealer to check the BCM, I believe that is the problem. The only other thing it may be is the ignition, as I get different garbage on the readout most times when I turn the key on and off.
Nick00800
posted 02-08-2018 09:22 AM     Click Here to See the Profile for Nick00800     send a private message to Nick00800   Edit/Delete Message   Reply w/Quote   Search for more posts by Nick00800
Thanks.
I was worried the BCM could be the culprit. I sure that is a cheap fix...
If anyone else has run into this and the BCM was the problem please let me know.
Weezy
posted 02-08-2018 11:53 AM     Click Here to See the Profile for Weezy     send a private message to Weezy   Edit/Delete Message   Reply w/Quote   Search for more posts by Weezy
I wonder if this is what was causing my issue of gauges dancing up and down. I couldn't find any ground issues which was suggested. Where exactly is this capacitor? Do you pull the dash out and it's in plain sight or do I need to pull both the dash and the instrument cluster to get behind the cluster?
robin
posted 02-08-2018 12:48 PM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
http://www.prowleronline.com/ubb/Forum1/HTML/024338.html
The problem has returned....Check above thread.
you have to remove the dash panel then you can access the computer chips. You can do a visual inspection with a magnifying glass but that is 50/50.
robin
posted 02-08-2018 12:52 PM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
noted in this thread ...
All the instruments quit working on my 1999 Prowler except the volt meter and the tach, also the airbag light is on. All my research led me to believe it was the body control module. I just replaced the BCM and still have the same issue. I guess I just wasted $700. I need some technical help from you guys, I'm frustrated. Car only has 15,400 miles on it.
http://www.prowleronline.com/ubb/Forum2/HTML/005187.html
This message has been edited by robin on 02-08-2018 at 12:53 PM
robin
posted 02-08-2018 12:56 PM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
pinched wire.
http://www.prowleronline.com/ubb/Forum6/HTML/009738.html
padroo
posted 02-08-2018 01:12 PM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
There is a self diagnostic instrument cluster test in the shop manual. My manual is for a 1999 and starts on 8E-4.
Does anyone ever read the manual. lol
Good luck.
robin
posted 02-08-2018 01:12 PM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
Opps
This message has been edited by robin on 02-08-2018 at 04:02 PM
robin
posted 02-08-2018 01:13 PM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
Just a heads up to read things carefully before you spend unnecessary money. Here is a good thread .
http://www.prowleronline.com/ubb/Forum2/HTML/005458.html
Weezy
posted 02-08-2018 02:45 PM     Click Here to See the Profile for Weezy     send a private message to Weezy   Edit/Delete Message   Reply w/Quote   Search for more posts by Weezy
Robin, thank you - you are the best! I will look through these and see if I can identify what my issue is.
Thanks for the info!
TLRandall
posted 02-08-2018 03:17 PM     Click Here to See the Profile for TLRandall     send a private message to TLRandall   Edit/Delete Message   Reply w/Quote   Search for more posts by TLRandall
Good luck.
Yes, I do have a manual, and yes, I did read my manual, and the self test is unresponsive.
I did want to chase down any other issues before taking it in to the dealer, since the first thing they told me was they were going to replace the instrument cluster, (I already did that). Next they would point to the BCM. The next set of diagnostic tests need to be completed with the scan tool.
There are many other things it could have been that would have masked itself as a BCM problem that I chose to run down myself, knowing that the dealer would not have taken the time to do that. I wanted to make sure that there was not a simple problem that I could fix myself, and in past experiences with these cars and dealers that are no longer familiar with them, I wanted to narrow down the focus before they started throwing my money at a problem that they were not sure on how to correct.
I had hoped to have one in the shop to be diagnosed way before this, but it keeps getting pushed downward on my "List of Things to do Today".
Nick00800
posted 02-08-2018 03:59 PM     Click Here to See the Profile for Nick00800     send a private message to Nick00800   Edit/Delete Message   Reply w/Quote   Search for more posts by Nick00800
Can you briefly share the procedure for the self diagnostic test.
Thanks
robin
posted 02-08-2018 04:08 PM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
What you are seeing is the instrument cluster self test.
l page 8J-2 states 'Initiate cluster test by depressing the trip reset button WHILE turning the key to the RUN/START position.'
padroo
posted 02-08-2018 04:30 PM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
Here is what I found in my 1999 shop manual
This message has been edited by padroo on 02-08-2018 at 04:39 PM
Pat and Jonie
posted 02-08-2018 07:09 PM     Click Here to See the Profile for Pat and Jonie     send a private message to Pat and Jonie   Edit/Delete Message   Reply w/Quote   Search for more posts by Pat and Jonie
I had that problem when the car was new.
It was a bad ground under the dash.
Look in the manual and you will see where the grounds are.
Clean the grounds, they are probably corroded.
