Author | Topic: Rattling noise |
greatkat POA Site Supporter Prowler Junkie From:Ontario, Canada |
posted 06-17-2014 03:06 PM
Hi all, As you probably know, I'm a new owner of a Prowler and am just starting to drive it. The Prowler is a red 1999, with 2050 miles on it. Every time I go over a bump or rough pavement, I experience strange sounds that can best be described as "loose screws rattling around". I realize that the tight suspension will cause the car to vibrate, but I'm questioning whether there is something I can do about this annoying sound. Your input would be most helpful. Thanks |
posted 06-17-2014 03:33 PM
The panel below the side panels has been known to rattle. I had to tighten mine up. If you feel below the edge you can feel the screw. Check it out, of course a rattle could be coming from anywhere but check that location. |
posted 06-17-2014 05:19 PM
You might also want to check the frame holes in which the front struts go down. It's easy to drop tools and nuts and bolts in those holes, I've done it. Keep a telescoping magnet on hand |
posted 06-17-2014 05:23 PM
check out these discussions. They may help with the process of elimination. http://www.prowleronline.com/ubb/Forum2/HTML/003705.html http://www.prowleronline.com/ubb/Forum2/HTML/003089.html http://www.prowleronline.com/ubb/Forum2/HTML/003268.html http://www.prowleronline.com/ubb/Forum2/HTML/002629.html |
posted 06-17-2014 05:24 PM
posted 06-17-2014 05:27 PM
You didn't mention if your top is up or down when you hear it. If the top is up, check the 2 front pins on your top. I noticed both of mine were very loose and rattling around the other day. |
posted 06-18-2014 07:38 AM
Thanks to everyone for their input. I'll follow the advice, check everything this week, and post my findings. Cheers, Terry |
posted 06-22-2014 06:07 PM
Hi All...reporting in. I checked everyone's suggestions, and unfortunately did not find anything. I took the Prowler out on the road this weekend, and tried to narrow the area down. It is definately coming from an area behind/beside my head, at head level. I loosened the front and rear fasteners on the convertible roof, examined the area which supports the roof struts, and opened the trunk. Absolutely nothing there, so the only other place it can be, is behind the rear panel (which contains the rear speaker). I plan to remove the rear panel when I've got more time. Am I correct that the rear panel is only held in place by push grommets? |
georgieboy POA Site Supporter Prowler Junkie From:Lake Don Pedro, CA USA |
posted 06-22-2014 06:53 PM
Your Kat is 15 years old but with few miles. I'll bet your still driving around on the original run flat tires. The rubber in these tires has all dried out and the tires are hard. Every small bump in the road is magnified through the tires, the wheels and the car. Get some new soft rubber and the whole ride will improve and probably lose the noise. |
posted 06-22-2014 08:20 PM
do you really think that changing tires is going to get rid of a rattle,ill have to admit thats the dumbest answer to a problem ever.why not find the rattle. ------------------ This message has been edited by catfish on 06-22-2014 at 08:20 PM |
posted 06-22-2014 08:43 PM
What is loose in the trunk area? Anything back there that can contact anything is magnified immensely by that huge (lol) open space. The sound comes up along the trunk lid next to the back fender and very close to your ear, where the soft top mechanism folds. Couple of times I have put a couple of loose wrenches back there and forgot about them until I hit the first bump. Very loud. |
posted 06-23-2014 01:24 PM
I agree with Ed, there's lots of things under the trunk that can come loose, like wires, carpet grommets, the tie downs for the top, etc. that can give off a rattle.
posted 06-23-2014 02:09 PM
Thanks all. Next, I'm going to test the trunk theory. The car will be in a parade next week (a quaint celebration in the colony called Canada Day).... catchy name don't you think ??? I will put the top down and secure it in the trunk with ties.....and then we'll see what happens. |
posted 06-23-2014 02:17 PM
Have you placed anything in the trunk, loose? By the way, the hard tire can actually CREATE the rattle. It takes something to jar something loose to cause a rattle. |
posted 06-23-2014 06:16 PM
If you cannot find where it's coming from behind you, sounds crazy but check up front, I had a squeak I swore was coming from around or behind the passenger seat, it was suggested that I lube the hood hinges... it worked! From where I thought the sound was surely coming from.... not even close. Good luck! |
posted 06-23-2014 08:16 PM
Might also try the sliding door on the CD player....... |
RJGR0713 Prowler Enthusiast From:Dekalb, Il. USA |
posted 06-23-2014 10:47 PM
Check the pin guides from the trunk. They could be loose. |
posted 06-24-2014 07:57 AM
Once again Prowler Nation, thanks for all the input as it is much appreciated. Based on the extra input, I'll keep looking and let you know what the final result is. Cheers, Terry |
posted 06-24-2014 11:15 AM
Are you married? Sometimes I think I hear a rattle, but it's my wife going on & on. |
posted 06-24-2014 04:01 PM
maybe it's your dentures. Try Polygrip |
