General Prowler Discussion New "Tips" page coming to the POA Board (Page 1)
Bottom of Page This topic is 3 pages long: 1 2 3 |
Author | Topic: New "Tips" page coming to the POA Board |
Alex POA Site Supporter Prowler Junkie From:Westminster, CO USA |
posted 07-23-2001 11:09 PM
Mike K and I have emailed and Mike has expressed interest in starting a "Tips" page, so I have volunteered to help . This would consist of any helpful tip you might know or have come across while working on your Kat. The range wide open, anything you might have come across and found out an easy way to go, or something that might help a new Kat owner. Please read the thread and try not to list in duplication. Feel free to list as many as you like. I will start with the basic and foremost tip for a new Kat owner. Thanks for your help. 1) Order mud flaps, front and rear from your Chyrsler dealer. Alex ------------------ |
posted 07-23-2001 11:13 PM
Do you want to add the part numbers to your tip? -Mud flap front #82203235 Or is there going to be a section of parts / numbers listed? ------------------ Classic/Beautiful - I'm referring to the Cat! |
posted 07-23-2001 11:22 PM
Alex asked me to post this again for the "Tips" page.. "The low tire pressure system (LTPS) consists of a transmitter with valvestem mounted in each wheel, a receiver mounted in the instrument panel and a warning light in the message center. The LTPS warning light will flash slowly and a single tone will sound if the tire pressure falls below the initial threshold pressure and the light will flash more rapidly and a continuous tone will sound if the pressure falls below the critical threshold pressure. The 1997's and most 1999's had the LTPS threshold at 24/19 for front and rear. Late 1999s (March to July 99)had a dual threshold of 21/19 front & 24/19 rear. The dual threshold receiver is a service replacement for all 97's and 99's. The 2000's with the new tires and 28-psi front and rear have a threshold of 20/14 pressure. The tire pressure transmitter is battery operated with a battery life of approximately 10 years. Also, if the LTPS warning light stays lit constantly, it means that there is a system problem: a transmitter is not transmitting or the receiver is not operating correctly. A dealer can use a DRBIII to investigate the problem and will be able to tell which part is not working. |
cwatsonjr unregistered Personal ScrapBook Admin Use |
posted 07-23-2001 11:28 PM
Install ceramic brake pads on the front ONLY. This will elimate most brake dust and will greatly enhance the look of your kat. Most owners purchase the Raybestos pads at a store like Pep Boys - Part No. PGD730QS. They are also available from CarQuest and various places online. ------------------ |
posted 07-23-2001 11:31 PM
CJ, A part number would be helpful if applicable as not all tips will require a part number. I have a seperate Prowler Part Index page that will be going up in the next few days that will contain a very handy reference and can be sorted in various ways. There will be a form attached to this page that will allow anyone to submit a commonly used part for addition to the list. Alex, Thank you for volunteering your help on the new Prowler Tips Page! All Enthusiasts: Please give us your input here for a tip you would like to share (no funny stuff, let's be serious here). ------------------ |
posted 07-23-2001 11:33 PM
LECAT Inexpensive Chrome Grille Treatment: Buy 20 to 25 ft of door edge moulding Clean grille good. Starting on the bottom vanes, and working up. Pre-heat moulding with blow dryer, cut to vane lenghts plus alittle. Install. Trim with razor blade. ------------------
posted 07-23-2001 11:39 PM
Gallagher/MagicTouchDesigns - Cold Air Intake System. Grab that cooler air in front of your cats to make your engine run better, sound better, and improve MPG. The Alley Cat highly recommends. Available from William Gallagher, www.magictouchdesigns.com ------------------
posted 07-23-2001 11:46 PM
Great stuff Larry! Everyone, let's keep them coming. Don't be afraid to dig into older posts that someone else made. Just cut and paste it here and give the original person credit. We will also acknowledge credit to each person that submits a tip on the new page. ------------------ |
posted 07-23-2001 11:56 PM
PREVENT possible convertible top material wear: This one if a simple fix, but heavy in detail - go to Ed Monahan's thread and read my post. 28 cents to prevent $2800 damage??? ------------------
posted 07-24-2001 12:04 AM
ATTENTION - NEW PROWLER OWNERS: Right now examine the length of the front of your Prowler, make a strong mental note, and avoid what 9,411 of us have done - putting the Prowler nose up unto a curb. You are getting the benefit of our mistakes, so make the most of it! ------------------
posted 07-24-2001 12:42 AM
Courtesy of Dan Pena and John Davies, thank you both. Transmission limp mode problem: Invest and carry in your cat one transmission Input Sensor #04800878 and one transmission Output Sensor #04800879, for a easy fix if your transmission goes into limp mode. July 12, 2001 thread on transmission limp mode problem. |
posted 07-24-2001 12:44 AM
If you have a supercharger, carry a exta belt. ------------------ |
posted 07-24-2001 01:58 AM
Don't push down on your hood to shut it. Lower it to about half way and then just let it drop and have gravity close it. If you push down on the hood while closing it you may wind up with dents. The dealer showed me that one over two years ago and I have followed his advice. |
posted 07-24-2001 06:14 AM
Make sure the latches that secure the top to the window frame are in the closed position before lowering the top into the trunk. Handle these with care as the replacement sets are expensive. Always strap the top when lowered into the trunk to prevent chafing. ------------------ |
posted 07-24-2001 06:25 AM
Remove the center caps and run a bead of silicone on the INSIDE of each plastic tab that holds the center caps to the rim. This will reinforce them so they wont break so easily. ------------------ This message has been edited by butchcee on 07-24-2001 at 12:13 PM |
posted 07-24-2001 08:16 AM
look into the 3M clear rocker panel strip to protect even more against rock chips. PK |
posted 07-24-2001 08:19 AM
Always srap down the top when not up. and when down put a cloth over the top section the trunk lid latch comes down over will stop the wear there..a face cloth folded in half is a nice size to use PK |
Joe Rad Prowler Junkie From:Orlando, FL, USA |
posted 07-24-2001 08:23 AM
If accessing your CD changer, and releasing the seatback of the passenger seat....WATCH OUT, seatback moves very FAST, and may hit you in the head. (from experience) |
posted 07-24-2001 08:34 AM
Here's one tip that isn't a tech tip but I think very important..No matter how uncomfortable PLEASE WEAR YOUR SEAT BELT and DON'T DRINK TO AN ACCESS AND DRIVE THESE KAT'S. I only had to look at the pictures posted last month of the silver one that rolled. Made me sick thought about it all the way to Deadwood Cruise. JMO. If I could repost those Pic's here I would just don't know how to do it, if anyone else feels like I do here and can repost them Please do PK |
posted 07-24-2001 09:15 AM
PK, I agree with the drinking and driving. A lot of people do drink to excess to access though That's how Alley Cat gets most of his dates. ------------------ This message has been edited by butchcee on 07-24-2001 at 09:28 AM |
posted 07-24-2001 10:06 AM
COMMON SENSE: If your garage is full of junk like mine, remember to keep ALL falling items away from the sides of your cat. I also have water skis and kneeboards stored above on ceiling storage rack- DA, maybe its time to take a day off to clean and rearrange the garage - I'd hate to damage that $3,000 hood! ------------------
posted 07-24-2001 10:27 AM
DEAD BATTERY & LONG TERM STORAGE: Courtesy of Mike Krehel: If you don't drive your Prowler for extended amounts of time or store during the winter months, you should invest in a battery tender. Follow the link to Mike's picture and description of use - http://www.prowleronline.com/ubb/Forum1/HTML/003237.html
posted 07-24-2001 12:43 PM
Automatic door locks: This tip stolen from "Midlife Prowler" "The 2000 Kats have a special feature that is never mentioned in the owner's manual. 1)cycle the ignition switch 4 times between the off and on position (do not start car) 2)leave in the off position after the 4th Go here for the complete story! http://www.prowleronline.com/ubb/Forum2/HTML/000048.html Rich ------------------ This message has been edited by OhioSilverCat on 07-24-2001 at 12:45 PM |
posted 07-24-2001 12:56 PM
When at car shows, gatherings etc., and you are showing off the Prowler's features, and discussing the finer points of 'you either get it or you don't', DO NOT forget to latch the clamshell truck, as a couple of drivers did considerable damage to their rides at about 20 MPH! Rich ------------------ |
Steve Marcus Prowler Junkie From:Ft. Lauderdale, Florida |
posted 07-24-2001 01:00 PM
When washing underneath the rear bumpers be careful not to cut the top of your hands on the exhaust pipes. They are very sharp. ------------------ |
This topic is 3 pages long: 1 2 3 All times are CT (US) Top of Page Previous Page | Return to General Prowler Discussion next newest topic | next oldest topic |
