Technical Questions & Answers Only voltmeter working on ‘99
Author | Topic: Only voltmeter working on ‘99 |
akboy POA Site Supporter Prowler Junkie From:Apollo Beach,FL,USA |
posted 04-15-2020 11:09 AM
Only get voltmeter pulled dash checked printed circuit board, capacitors,ribbons, all looked. Checked grounds at batt, and pcm. Volt and tach only work. Need help. |
posted 04-15-2020 01:47 PM
Did you do a cluster self test ? Hold down trip mileage reset button and then turn key on. Should see the gauges move and also the PRNDL display leds go through tests. If the test fails - I would closely check the capacitor on the circuit boards. Have repaired a few . If pass - check BCM |
posted 04-15-2020 09:19 PM
I had the same problem with my '97. Discussion in link below. |
Nick00800 POA Site Supporter Prowler Junkie From:Ridgefield, WA |
posted 04-15-2020 10:40 PM
I also had the same issue. I could see a bad capacity and sent it in. They said it was a bad capacitor plus a bolt issue with the circuit board http://www.prowleronline.com/ubb/Forum1/HTML/024913.html |
posted 04-16-2020 01:12 PM
I didn't know about the self check, but will do it. As I posted I've already pulled the dash for the capacitor check no problems were visible. Cleaned batt grd,PCM grd wire checked and cleaned. All fuses good. Don't know of any way to check BCM, but to replace it. Thanks for all the help. Looking for a BCM. Talked to Module Experts(Jacksonville FL) and got hung up on they have a bad rating anyway. |
posted 04-16-2020 02:39 PM
Tony, did the cluster self check, only the speedo display flashed some wierd stuff. |
posted 04-16-2020 08:06 PM
Exactly what I had on 2. Both repaired by replacing capacitor. On one you could see that capacitor had leaked. other one looked like nothing was wrong. Original capacitor was 16V 68uF stripe on casing tells you polarity of the pins. |
posted 05-09-2020 10:32 PM
Thanks,Tony. I'm doing this on a friends '99. I'll tell him and see what he wants to do. Stay Safe |
posted 05-10-2020 12:54 PM
An earlier post .. |
