  Technical Questions & Answers
  Turn Signals and Flashers Not Working (Page 1)
   Bottom of Page
This topic is 2 pages long:   1  2
next newest topic | next oldest topic
Author Topic:   Turn Signals and Flashers Not Working
Blown632Monte
posted 11-30-2011 01:52 PM     Click Here to See the Profile for Blown632Monte     send a private message to Blown632Monte   Edit/Delete Message   Reply w/Quote   Search for more posts by Blown632Monte
My wife told me the other day that the turn signals are not working. Nothing happens when you flip the lever next to the steering wheel up or down. Nothing on the dash or on the outside of the car. Flashers don't work either.
We noticed the left rear brake light appears to be out also. Can't believe a bulb would cause the problem, but I guess it could. Seems more like a relay or connection somewhere. Any suggestions?
BeWare
posted 11-30-2011 04:01 PM     Click Here to See the Profile for BeWare     send a private message to BeWare   Edit/Delete Message   Reply w/Quote   Search for more posts by BeWare
It could be the clock spring. Just a guess.
http://www.prowleronline.com/ubb/Forum2/HTML/001964.html
http://www.prowleronline.com/ubb/Forum1/HTML/016391.html
http://www.prowleronline.com/ubb/Forum2/HTML/002181.html
This message has been edited by BeWare on 11-30-2011 at 04:04 PM
catfish
posted 12-02-2011 12:44 PM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
usually if the clockspring goes bad the airbag lite will come on also.being part of the srs,the lite will come on when any part of the srs goes bad.ck fuse,ck flasher,ck multi funtion switch.
This message has been edited by catfish on 12-02-2011 at 12:54 PM
TFischer
posted 12-02-2011 01:29 PM     Click Here to See the Profile for TFischer     send a private message to TFischer   Edit/Delete Message   Reply w/Quote   Search for more posts by TFischer
This happened on one of our cars - was the turn/flasher fuse that plugs in down by the brake pedal.
Blown632Monte
posted 12-04-2011 09:44 PM     Click Here to See the Profile for Blown632Monte     send a private message to Blown632Monte   Edit/Delete Message   Reply w/Quote   Search for more posts by Blown632Monte
I'll check that the next time I have the car out. What was the cause of the blown fuse? Usually there is a cause...
TFischer
posted 12-05-2011 11:45 AM     Click Here to See the Profile for TFischer     send a private message to TFischer   Edit/Delete Message   Reply w/Quote   Search for more posts by TFischer
We never could find a cause and it hasn't happened again. Not sure if there was some sort of a surge or what.
catfish
posted 12-05-2011 12:22 PM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
many parts fail due to age.
idive
posted 12-05-2011 12:26 PM     Click Here to See the Profile for idive     send a private message to idive   Edit/Delete Message   Reply w/Quote   Search for more posts by idive
and when one fails you need to replace every part on the car cause they will not be far behind.
REBUILD YOUR PROWLER NOW!
stprinz
posted 12-06-2011 03:37 AM     Click Here to See the Profile for stprinz     send a private message to stprinz   Edit/Delete Message   Reply w/Quote   Search for more posts by stprinz
I HAVE THE SAME PROBLEM WITH THE TURN SIGNALS WHEN THE CAR HAD BEEN FIRM FOR A WHILE. AFTER DRINING IT FOR 5 MIN - TURN IT OF AND ON AGAIN - EVERTHING WORKS AGAIN RIGHT ????? I HAVE NON IDEA WHY -
stprinz
posted 01-17-2012 05:52 AM     Click Here to See the Profile for stprinz     send a private message to stprinz   Edit/Delete Message   Reply w/Quote   Search for more posts by stprinz
DOES ANYBODY KNOW FROM WHAT CHRYSLER CAR IST THE PROWLER CLOCKSPRING FROM OR IS IT SPAZIAL CLOCKSRING ONLY FOR THE PROWLER?
MINE FAILED AND MAY HAVE SOME PROBLEMS TO FIND ONE IN EUROPE. I THINK THE STRREING WHEEL FROM THE PROWLER IS FROM A JEEP SO IT MIGHT BE ALSO A JEEP CLOCKSPRING !!!! ???
Koastal Cat
posted 01-19-2012 10:14 AM     Click Here to See the Profile for Koastal Cat     send a private message to Koastal Cat   Edit/Delete Message   Reply w/Quote   Search for more posts by Koastal Cat
Might be an old battery issue?
Low voltage could be the cultrate. Once the alternator charges up the battery the voltage is back to 12v
Just an idea
- Kcat
stprinz
posted 01-19-2012 10:17 AM     Click Here to See the Profile for stprinz     send a private message to stprinz   Edit/Delete Message   Reply w/Quote   Search for more posts by stprinz
CHANGED THE BATTARY 6 MONTH AGO AND UNTIL NOW EVERTHING WORKED.....
ALSO GOT THE AIRBAG LIGHT ON IN THE DASH.......
Blown632Monte
posted 01-27-2012 10:17 PM     Click Here to See the Profile for Blown632Monte     send a private message to Blown632Monte   Edit/Delete Message   Reply w/Quote   Search for more posts by Blown632Monte
Got the car out today and had a look at this.
Cause was a blown 15A fuse for the hazard flashers in the underhood fuse panel. Interestingly enough, this fuse will take out your hazard lights, turn signals and brake lights.
The owner's manual was little help. It said the underhood fuse panel was behind the battery. The panel is actually up by the master cylinder and slightly under it. I guess technically "behind the battery" is correct since just about everything in the engine compartment is "behind the battery."
You have to have some tiny hands to get to that panel as well. The brake lines coming off of the master cylinder kept me from doing too much from the top. I had to reach up under the car and feel my way around to take the panel's lid off and put it back on. Used a pair of long needle nosed pliers to change the fuse.
Everything is good for now...
catfish
posted 01-28-2012 09:01 AM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
next time remove 3 bolts on side panel,much easier,
This message has been edited by catfish on 01-28-2012 at 04:49 PM
garysss
posted 01-28-2012 10:35 AM     Click Here to See the Profile for garysss     send a private message to garysss   Edit/Delete Message   Reply w/Quote   Search for more posts by garysss
Thanks for updating us.
beachcat
BANNED
posted 01-28-2012 04:08 PM     Click Here to See the Profile for beachcat     send a private message to beachcat   Edit/Delete Message   Reply w/Quote   Search for more posts by beachcat
Originally posted by catfish:
next time remove 3 bolts on side panel,much eadier,
Blown632Monte
posted 01-28-2012 07:25 PM     Click Here to See the Profile for Blown632Monte     send a private message to Blown632Monte   Edit/Delete Message   Reply w/Quote   Search for more posts by Blown632Monte
Not sure if that's sarcasm or what, but I wouldn't think that's easier.
Today I bought an exceptionally long pair of needle nosed pliers and opened up the fuse panel again to check the others and inventory what's in there so I can get spares. Much easier with the right tool...
garysss
posted 01-29-2012 12:37 AM     Click Here to See the Profile for garysss     send a private message to garysss   Edit/Delete Message   Reply w/Quote   Search for more posts by garysss
I don't it was sarcasm. It should be easier to get to with side panel off.
Blown632Monte
posted 01-29-2012 05:22 PM     Click Here to See the Profile for Blown632Monte     send a private message to Blown632Monte   Edit/Delete Message   Reply w/Quote   Search for more posts by Blown632Monte
Yeah, it's got to be, but are the panels that easy to remove? I would have thought they might need some realignment of the gaps when they are put back on.
Just curious as to what Roger seems to think is so funny...
beachcat
BANNED
posted 01-29-2012 05:48 PM     Click Here to See the Profile for beachcat     send a private message to beachcat   Edit/Delete Message   Reply w/Quote   Search for more posts by beachcat
Sorry blown but you just have to look at the panels and they come off. 3- 13mm bolts I think and you will find amazing access. They go back on just about as easily.
It's just a bit funny that you went to the lengths you did.
catfish
posted 01-29-2012 06:11 PM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
pay attention to the gaps before removing side panels,that way when you reinstall you will know what they look like,yes you will have to align them,which is easy,just 2 adjustments in and out and frt to back.
Blown632Monte
posted 01-29-2012 06:34 PM     Click Here to See the Profile for Blown632Monte     send a private message to Blown632Monte   Edit/Delete Message   Reply w/Quote   Search for more posts by Blown632Monte
I'll keep the panels in mind for the next time I need to get at something back up in the engine compartment. Good to know it comes off with three bolts. I knew there would be some adjustment on the gaps though. However, with the long needle nosed pliers, getting to the fuse panel is really easy. Definitely easier than taking the side panel off and making the requisite adjustments. It's all about having the right tool(s).
Roger, I'm glad you found someone trying to figure out the best way to do something as funny. I didn't see you jumping in with any constructive suggestions to solve this problem, but I guess the next time I want to know the proper way, I'll give you a call.
This message has been edited by Blown632Monte on 01-29-2012 at 06:38 PM
Blown632Monte
posted 01-29-2012 06:35 PM     Click Here to See the Profile for Blown632Monte     send a private message to Blown632Monte   Edit/Delete Message   Reply w/Quote   Search for more posts by Blown632Monte
This message has been edited by Blown632Monte on 01-29-2012 at 06:36 PM
beachcat
BANNED
posted 01-29-2012 06:38 PM     Click Here to See the Profile for beachcat     send a private message to beachcat   Edit/Delete Message   Reply w/Quote   Search for more posts by beachcat
humor is spontaneous blown. Sorry to ruffle your ego.
Blown632Monte
posted 01-29-2012 06:41 PM     Click Here to See the Profile for Blown632Monte     send a private message to Blown632Monte   Edit/Delete Message   Reply w/Quote   Search for more posts by Blown632Monte
My ego? Not quite. Even though you got a nice laugh out of it, I managed to find a way that's even easier than removing the side panels, which is apparently what you would have done.
The point is, you for some reason feel the need to act as a threadcrapper and throw your BS in. If you haven't got anything constructive to say, then stay out of the topic (especially if it's a technical one) and move on.
