  Technical Questions & Answers
  Installing cool air induction kit?
Author Topic:   Installing cool air induction kit?
weswman
posted 06-26-2004 04:54 PM     Click Here to See the Profile for weswman     send a private message to weswman   Edit/Delete Message   Reply w/Quote   Search for more posts by weswman
How easy is this to do on my own? I'm pretty knowledgable but it didn't come with any directions. Can someone send me a pic of their kit on the car? This would be a huge help. Also, can I install this from the top of the engine or do I have to get under the car? Any help would be great. Thanks, Wes.
ALLEY CAT
posted 06-26-2004 05:19 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
wessup - there are several models out there on the market,,,,which did you buy?
I have the MTD brand cool air induction system, and it does require most of the work to install from under the car.
weswman
posted 06-26-2004 05:37 PM     Click Here to See the Profile for weswman     send a private message to weswman   Edit/Delete Message   Reply w/Quote   Search for more posts by weswman
It's similar to the RSI setup. Just a chrome elbow tube with a K&N cone air filter at the end. The company said I Just need to remove the stock air box and replace it with the new one. I didn't realize the box was closer to the bottom than it was to the top. I don't know which way to point this thing either. Instructions would have been nice from this company. Let me know if anyone can help. Thanks, Wes.
GRROWL
posted 06-26-2004 06:30 PM     Click Here to See the Profile for GRROWL     send a private message to GRROWL   Edit/Delete Message   Reply w/Quote   Search for more posts by GRROWL
Most people break the stock airbox when taking it out. If you want to not break it, I suggest removing the side panel and the coolant "overflow" tank. After that, it's easy. It works best if you combine the air intake changeout with a coolant change since you'll need to "burp" the cooling system if you remove the tank.
For details, see: http://www.prowleronline.com/ubb/Forum2/HTML/001144.html
-GRROWL
P.S. - In hindsight, I sometimes think that I should have stopped with the K&N filter in the stock airbox due to the high underhood temperatures going into the "cold"-air intake. There were active discussions on this in the past if you want to research it.
Northern Cat
posted 06-26-2004 08:03 PM     Click Here to See the Profile for Northern Cat     send a private message to Northern Cat   Edit/Delete Message   Reply w/Quote   Search for more posts by Northern Cat
It's very easy....remove your passenger side panel....three
bolts..(make sure the same bolts go back in the same holes
when reinstalling the panel) bring the top of the panel
toward you , lift and remove,
This will give you access to the cold air box..two bolts
if I remember ...go easy and you won't break the box in
case you ever want to reinstall it..
Don..
Bob Goetz
Mr. Real Rod
posted 06-28-2004 07:28 AM     Click Here to See the Profile for Bob Goetz     send a private message to Bob Goetz   Edit/Delete Message   Reply w/Quote   Search for more posts by Bob Goetz
FYI anyone that has bought a cold air kit for less than $150 take a close look at the air cleaner, the cheap kits are not using brand name air cleaners but cheap knock offs and when the glue gets hot the element falls off the backer plate.
< CLICK HERE FOR NEW REALROD.COM PARTS >
< Click on my banner to go to realrod.com >
weswman
posted 06-28-2004 12:03 PM     Click Here to See the Profile for weswman     send a private message to weswman   Edit/Delete Message   Reply w/Quote   Search for more posts by weswman
Does anybody have a pic of theirs installed? It seems that the stock air box points down, this new air intake has a bent tube and I don't know which way to point it. A pic would be a huge help. Let me know, Wes.
pumpkin
Visit Waleke's World
posted 06-28-2004 01:20 PM     Click Here to See the Profile for pumpkin     send a private message to pumpkin   Edit/Delete Message   Reply w/Quote   Search for more posts by pumpkin
This is what ours looks like - looking from the bottom up:
From behind the side panel:
Current mods: Mopar dual exhaust & front mudflaps; MacMotorsports Air Intake;
Real Rod Air Patrol; Graphics by Balistek Designs; ($8) Chrome grille; Chrome
tire valve-stem covers; Painted rear bumper lettering; Prowler Pro Gears; Synthetic
Oil; Raybestos Ceramic Brake Pads; TGF Door Panel Inserts & Headrest Covers;
SheepskinExpress Sheepskin Seatcovers; Grille Light; Pinstriping by Bo Boring;
Painted Valve Cover; Window Tinting; Windshield Visor Banner; Front Bumper
Removal / Relocation of Front Turn Signal Lights; Real Rod Transmission Cooler
Cover, Sill and Carper Covers, Aero Front Covers and Roadster Rear Pan, rear
bumpers removed; rear mudflaps; painted calipers; Prowler Products by Gary
Drilled Rotors, front and rear; Painted tach; Jay's Aluminum Billet Center Caps
w/shimmers, Chrome Lugnuts and Chrome Radio Bezel Shimmer; Dash Rings;
Windshield Wiper Arm Removal; Fender Trim; Speaker Replacement; Painted
Plenum; Painted Radiator Crossmember; Painted Rear Mudflaps; Air Patrol
graphics; Aluminum engine compartment support bars; PlasmaGlow 7-color LED
Underbody Kit; Dash Designs Dash Mat.
More 'Pumpkin' photos . . . . . More cars and other stuff
New pictures in Personal Scrapbook (02/23/03)
"I may have to grow older, but I do not have to grow up!"
"The Prowler is not a car to go from Point A to Point B. The Prowler is the Point!"
weswman
posted 06-28-2004 02:04 PM     Click Here to See the Profile for weswman     send a private message to weswman   Edit/Delete Message   Reply w/Quote   Search for more posts by weswman
Thank you so much. That's what I needed. Wes.
Pipes
Prowler Enthusiast
posted 06-28-2004 07:23 PM     Click Here to See the Profile for Pipes     send a private message to Pipes   Edit/Delete Message   Reply w/Quote   Search for more posts by Pipes
Just a word of caution, if you have the same assembly as Pumpkin showed in his picture. (Speaking from experience.)
Be careful to position the shield so it doesn't rub on any of the wiring. It will cut through insulation and cause all sorts of problems.
Bob
AKA Pipes
pumpkin
posted 06-28-2004 07:35 PM     Click Here to See the Profile for pumpkin     send a private message to pumpkin   Edit/Delete Message   Reply w/Quote   Search for more posts by pumpkin
Bob
AKA Pipes
very true.
pumpkin
Bob
AKA Pipes
very true.
weswman
posted 06-28-2004 09:31 PM     Click Here to See the Profile for weswman     send a private message to weswman   Edit/Delete Message   Reply w/Quote   Search for more posts by weswman
Hmmm. Mine is the same except my heat shield goes all the way around the filter. Should I cut the heat shield away from the filter on top? Seems that's where the wires are resting against the filter. Let me know, Wes.
Black Tie 161
posted 06-29-2004 07:11 AM     Click Here to See the Profile for Black Tie 161     send a private message to Black Tie 161   Edit/Delete Message   Reply w/Quote   Search for more posts by Black Tie 161
If mine had a shield that went all the way around, I would be tempted to leave it as is....extra protection against wires rubbing raw on the element.
For the record, my MTD 2.2 filter intake seperated from the base due to cheap glue. I refit it with 3M tape.
GRROWL
posted 06-29-2004 05:59 PM     Click Here to See the Profile for GRROWL     send a private message to GRROWL   Edit/Delete Message   Reply w/Quote   Search for more posts by GRROWL
Originally posted by GRROWL:
Two problems with the MTD -
1. They fall apart and allow unfiltered air into the engine, it's been posted a lot, you can find it with a search.
2. There has been a lot of discussion about how it takes in HOT underhood air vs. the stock airbox taking in ambient air through the doorframe, a search will also show this.
Best option may be a free-flow filter in the stock box.
-GRROWL
This is the piece that falls off when the glue melts from the high underhood temperature:
