Author | Topic: radio |
posted 05-27-2011 08:01 PM
I have a humming noise on the radio when car is at idle . It stops at around 15 mi. per hour .. Bad ground ?? any one with this problem ???? if so what was the fix ?? |
posted 05-28-2011 08:04 AM
Jim, my humming was related to the ground wire in the front close to the battery. I took it loose and cleaned then put it back on and the humming stopped. |
posted 05-28-2011 08:49 AM
OK thanks George .. I will take a look and see if that is the fix .. |
posted 05-28-2011 10:02 AM
If you have a Prowler Service Manual, on pages 8W-90-2 and 8W-90-3 it shows 14 grounds on the car. My manual is for a 99. It also references them to a nice picture so you can locate them. If you are a do-it-your-selfer like I am, the book will answer a lot of your questions. This forum as you know has a valuable knowledge base with years of experience as well. I have found that when you have a problem and you can get 2 or more references you will probably find your answer. If you don't have the book a subscription to |
