Prowler Products By Gary Tom Mills - Plymouth Prowler Parts
  Technical Questions & Answers
  97 Instrument gauge cluster repair
Author Topic:   97 Instrument gauge cluster repair
adacus
posted 12-20-2022 07:24 PM     Click Here to See the Profile for adacus     send a private message to adacus   Edit/Delete Message   Reply w/Quote   Search for more posts by adacus
Can we make this a sticky?
I have photos to complement this.
This was contributed by Jon Hess on FB
I cannot recall how to upload photos on POA
Suvprowler Prowler
1: Lower steering column
2: Pull straight back on corners of dash near the door to unclip lower edge of dash and remove.
3: Unscrew cluster.
Disconnect Red and Blue harnesses. Slightly pull up on harness clips to remove harness plugs.
4: Remove screws and rear cardboard cover on the back of the gauge cluster.
5: Locate capacitor C9 (see photo)
6: Inspect for evidence of leaked capacitor fluid. Ie: brown or black residue at the base of the capacitor or the resistor below and IC above. Corrosion on those parts is possible.
7: Unscrew and remove green circuit board on left. Unplug harness to main board and set aside.
8: Unclip all wire harnesses from main circuit board. Release small clips on each side of ribbon cables and pull clips up to release ribbon cable.
9: Remove screws and main circuit board.
10: Unsolder the 2 capacitor terminals on back side of main circuit board an remove capacitor.
11: Use electrical contact cleaner and Qtip or soft brush to clean residue and corrosion from circuit board and affected components.
12: Install new 68uf 105C (32v or 50v) electrolytic capacitor. Confirm polarity is correct and solder on reverse side of the circuit board. Cut off excess capacitor wires.
13: Reverse above procedure to reassemble cluster.
14: Place cluster in dash and connect Red and Blue harnesses to test repair.
15: Screw in cluster and reinstall dash.
Tony Goertz
Administrating Kat
posted 12-21-2022 05:05 PM     Click Here to See the Profile for Tony Goertz     send a private message to Tony Goertz   Edit/Delete Message   Reply w/Quote   Search for more posts by Tony Goertz
For pics see http://www.prowleronline.com/ubb/Forum1/HTML/024913.html
adacus
posted 12-24-2022 10:26 PM     Click Here to See the Profile for adacus     send a private message to adacus   Edit/Delete Message   Reply w/Quote   Search for more posts by adacus
Thank you Tony.
Can this be made to a sticky
ALLEY CAT
posted 12-25-2022 06:39 AM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
http://www.prowleronline.com/ubb/post_pics_tutorial/picture_post.htm
chasgriffith
posted 09-22-2023 11:32 AM     Click Here to See the Profile for chasgriffith     send a private message to chasgriffith   Edit/Delete Message   Reply w/Quote   Search for more posts by chasgriffith
Back a few years (time flies) I had tried Eastern Electric and it came back that the cluster was not repairable. Just talked to them and they have another cluster in the shop where it looks like it may be the integrated circuit. I am going to send my board to them next week and they will test that. He is trying to find a replacement IC.
He did mention the leaking capacitor caused a variety of problems. This was a great post with the link to the pictures. So now I get to pull the cluster out for the third time.
TLRandall
posted 10-09-2023 09:11 AM     Click Here to See the Profile for TLRandall     send a private message to TLRandall   Edit/Delete Message   Reply w/Quote   Search for more posts by TLRandall
I have a cluster where the C9 replacement did not correct the problem. Would be interested in how this progresses so that I can have this one repaired as a spare.
ed monahan
posted 10-09-2023 02:39 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Tom, I just had mine repaired a month ago for $ 100 at a local TV/Electronic repair joint. Older guy, old time junky shop but it was fixed within two hours. Let me know if you want to try him. You can send it to me and I will take it over, about 15 minutes away.
Marc's Electronic repair on Colerain Ave in Cincinnati if you want to google it. He knows his stuff, I think
TLRandall
posted 02-03-2024 12:48 PM     Click Here to See the Profile for TLRandall     send a private message to TLRandall   Edit/Delete Message   Reply w/Quote   Search for more posts by TLRandall
Thanks to Ed, my spare cluster is now completely functional again. Just tried it in the Silver Prowler this morning and it works perfectly!
Thanks Ed for all the help.
ed monahan
posted 02-03-2024 03:31 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Glad it worked out so well. He said yours was more complicated and charged $ 150 but still worth it. If anyone else needs to have one repaired, I will be happy to take it over to him. Shipping was about $ 50, it weighs nothing but it is wise to put it in an oversized box so it doesn't get damaged. It took a couple of days for the repair this time.
ed monahan
posted 02-03-2024 03:42 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Marc's Electronics (T V repair), 7539 Colerain Ave., Cincinnati, OH 45239, 513 522 3250. If you want to send it directly. Call first to make sure all is the same. He requires a $ 50 deposit.
Landscape Doctor
posted 02-09-2024 01:49 AM     Click Here to See the Profile for Landscape Doctor     send a private message to Landscape Doctor   Edit/Delete Message   Reply w/Quote   Search for more posts by Landscape Doctor
Ed I am assuming this would apply to all years correct?
This thread is archived. Thank You
Page 1 post 4 http://www.prowleronline.com/ubb/Forum2/HTML/006241.html
This message has been edited by Landscape Doctor on 02-09-2024 at 01:51 AM
BeWare
posted 02-09-2024 09:54 AM     Click Here to See the Profile for BeWare     send a private message to BeWare   Edit/Delete Message   Reply w/Quote   Search for more posts by BeWare
I have yet to hear of this capacitor failure in 2000 and newer. Maybe this is the reason.
From another discussion.
The 1999 uses 5010273AB, but there is a 5010273AC. From what I understand, the AB and AC are not interchangeable, that the AC is for 2000 and later models. I have not tested this out yet.
ed monahan
posted 02-09-2024 01:17 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
I don't KNOW. I would be guessing. I have only seen 97s and 99s having the problem.
Landscape Doctor
posted 02-09-2024 07:01 PM     Click Here to See the Profile for Landscape Doctor     send a private message to Landscape Doctor   Edit/Delete Message   Reply w/Quote   Search for more posts by Landscape Doctor
I am going to leave it as is for now. If more specifics come up I will add to it.
ed monahan
posted 04-05-2024 06:35 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
bumping
TLRandall
posted 04-07-2024 09:56 AM     Click Here to See the Profile for TLRandall     send a private message to TLRandall   Edit/Delete Message   Reply w/Quote   Search for more posts by TLRandall
Rich, I did move the clusters between the 99's (both were bad) and my 2001 Silver while I was trying to diagnose the issue and I saw no difference when putting the 2001 into the 1999 or the 1999 into the 2001. The only thing that I did see is that the 1999 cluster was not working in either car, but once repaired, it worked in both. I did not think to look at the part numbers at the time.
