Author | Topic: Transmission Pan Removal |
Stroker Prowler Junkie From:Sevierville, Tennessee, USA |
posted 01-10-2018 11:17 AM
Did due diligence and checked the files . Could not find enough info to help me put a trans pan gasket on . My problem is how to remove rear cross member below the pan. Can somebody help? Also what fluid for 99.+3 or +4? Another dealer job went plop. Pan has both red and black silicone. looks like black spread over red with pan still on car. Paid $250 for trans service. My own fault for not checking their work. |
posted 01-10-2018 12:25 PM
Just take out 4 bolts on the center piece of the cross member. Is it possible that the technician used red "on the bench" before replacing the pan and then found that it was noticeable and tried to cover it with black? ATF+4 will be fine. |
posted 01-10-2018 01:04 PM
Check this thread out ....lots of pics. if you can while you have it off get a drain plug installed. http://www.prowleronline.com/ubb/Forum1/HTML/023751.html
This message has been edited by robin on 01-10-2018 at 01:08 PM |
posted 01-10-2018 01:22 PM
11-12 quarts ATF+4
Then make sure you put it threw the gears after pan goes back on..while sitting Stationary...check fluid.
posted 01-10-2018 01:34 PM
Another way to change that is not so messy by Tomcal Its also in the thread above. . Spell correction on my last post should have been "ELIMINATE". [/QUOTE]
This message has been edited by robin on 01-10-2018 at 02:35 PM |
posted 01-10-2018 06:58 PM
Thanks to all who responded!! I am ready to try stopping the leak. Removing the cross member was my biggest problem, Robin and Onecatnodog solved that for me. I already have the pump it was on a free coupon when I bought something else. Looks like I searched the wrong subject. Tony when I take the pan off it will tell |
posted 01-11-2018 09:31 AM
Permatex makes RTF sealant for automatic transmission pans. www.amazon.com/Permatex-81180-Automatic-Transmission-Sealant/dp/B0018PSATO/ref=sr_1_7?ie=UTF8&qid=1515684382&sr=8-7&keywords=permatex+rtv+sealant
posted 01-11-2018 09:36 AM
Just my 2 cents... Some time ago when I was contemplating a change (I believe it was padroo or Robin) that gave a suggestion on a reusable gasket that is also made for the pan... The gasket is metal and comes with a pre-attached inner rubber seal... IE: requires no need for gasket sealer, mess, or worry... It was a bit more pricey but worth it!!!! Torqued it down to the required spec and done!!! No leaks... No hassle... Done!!! I recommend it.. Thanks Rich |
posted 01-11-2018 09:52 AM
I found the part number for the Trans Pan gasket if interested... Sold by any Mopar parts dealer.. Part # 05011114AA Thanks |
posted 01-11-2018 11:49 AM
My filter came with a pan gasket and I used it even though I had the Permatex RTV and decided to go with the gasket. It worked, no leaks. Whatever works for you. |
posted 01-21-2018 06:57 PM
[img]http://www.prowleronline.co m/ubb/image_uploads/img_0702_opt.jpg[/img] Pan gasket replacement was a success. |
posted 01-21-2018 09:28 PM
Sounds like someone glued those pan bolts in place, they shouldn't have been that tight. |
