  Technical Questions & Answers
  Noise in the radio / speakers (Page 1)
   Bottom of Page
This topic is 2 pages long:   1  2
next newest topic | next oldest topic
Author Topic:   Noise in the radio / speakers
Guenter
Prowler Newbie
posted 07-20-2016 04:45 AM     Click Here to See the Profile for Guenter     send a private message to Guenter   Edit/Delete Message   Reply w/Quote   Search for more posts by Guenter
when I hear cd or cassette I have a strange howling noise
in the speakers, maybe it`s a noise filter or capacitor,
but where the sitting?
When I repeatedly turn teh radio on and off the noise is sometimes away
Can someone help me please ?
JOYRIDE
posted 07-20-2016 08:11 AM     Click Here to See the Profile for JOYRIDE     send a private message to JOYRIDE   Edit/Delete Message   Reply w/Quote   Search for more posts by JOYRIDE
I had the same thing,
Had to change my radio.
Going to get my factory radio checked ,to see if its something inside
Maybe a louse solder or something.
Stroker
posted 07-20-2016 12:13 PM     Click Here to See the Profile for Stroker     send a private message to Stroker   Edit/Delete Message   Reply w/Quote   Search for more posts by Stroker
Could it be alternator whine?
Used to be a condenser to quiet that.
Haven't heard about them for years.
LSK
posted 07-20-2016 08:02 PM     Click Here to See the Profile for LSK     send a private message to LSK   Edit/Delete Message   Reply w/Quote   Search for more posts by LSK
I posted this in May, 2016.
For the past couple of months, I have been experiencing some AM radio noise and a random misfire engine code on my 2002 Prowler. After some research, I found that the Prowler engine has 2 ignition capacitors which are located on each side of the engine block. I picked up 2 of these at the Chrysler distributorship. Mopar #04606866AA @ about $14 each. The 2002 Service Manual, page 8I-4 shows the locations and removal/installation procedure. After replacement, the radio noise along with the random misfire code have stopped. I have also noticed an increase in mileage and acceleration.
You might try this.
dskatt
posted 07-20-2016 08:13 PM     Click Here to See the Profile for dskatt     send a private message to dskatt   Edit/Delete Message   Reply w/Quote   Search for more posts by dskatt
Does the noise stop when you put the shifter into 2nd gear or reverse?
Guenter
Prowler Newbie
posted 07-21-2016 12:11 AM     Click Here to See the Profile for Guenter     send a private message to Guenter   Edit/Delete Message   Reply w/Quote   Search for more posts by Guenter
Thanks to all and especially to Stroker and DSKatt.
I will check it
Yesterday i have a normal radiosound, no disturbing noise
YELLER CAT
posted 07-24-2016 09:22 PM     Click Here to See the Profile for YELLER CAT     send a private message to YELLER CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by YELLER CAT
​to be sure an intermittent connection and grounds are always the first consideration... making sure ALL the audio equipment has a 'chassis' ground... it may look connected but check for corrosion under the terminals... hard to see, but most likely the problem.​
Rayman
Prowler Enthusiast
posted 08-21-2016 11:47 AM     Click Here to See the Profile for Rayman     send a private message to Rayman   Edit/Delete Message   Reply w/Quote   Search for more posts by Rayman
Hi Günter you have a pm
padroo
posted 08-21-2016 12:16 PM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
Is this what the capacitor looks like?
Does the noise change with engine RPM?
This message has been edited by padroo on 08-21-2016 at 12:34 PM
Rayman
Prowler Enthusiast
posted 08-22-2016 12:00 PM     Click Here to See the Profile for Rayman     send a private message to Rayman   Edit/Delete Message   Reply w/Quote   Search for more posts by Rayman
Thank you for your help padroo
Yes, the engine RPM is dependent noise.
also has the speakers a pulsating noise when I drive on a
rough road.
which would also interest me, where is the capacitor
installed.
best regards from Germany
Rayman
Guenter
Prowler Newbie
posted 08-22-2016 01:10 PM     Click Here to See the Profile for Guenter     send a private message to Guenter   Edit/Delete Message   Reply w/Quote   Search for more posts by Guenter
Hello
sorry for my late answer. Thank you for all your help, i will check it next week.
padroo
posted 08-22-2016 02:35 PM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
I have never located them yet but this may help.
http://www.prowleronline.com/ubb/Forum2/HTML/005389.html
Rayman
Prowler Enthusiast
posted 08-23-2016 02:37 PM     Click Here to See the Profile for Rayman     send a private message to Rayman   Edit/Delete Message   Reply w/Quote   Search for more posts by Rayman
Thank you for your efforts. I found out where places the capacitors. left and right built into the height of the cylinder head.
I will replace the capacitors, and report whether an improvement is.
greetings Raymann
Scott99
posted 09-16-2016 01:50 PM     Click Here to See the Profile for Scott99     send a private message to Scott99   Edit/Delete Message   Reply w/Quote   Search for more posts by Scott99
Thanks to LSK for his post on this topic in May of this year!
I have been suffering with this problem forever and didn't want to upgrade my stereo for fear I would have the same problem. Yes, I also had the experience of the radio noise going away once you put the car in reverse. That was strange to say the least!
Note the picture below... the new capacitor is slightly larger and the large tab is integrated INTO the capacitor.
The older tab shown is bent where it mounts to the cylinder head because there are 2 raised knobs on the mounting surface. I used my dremel tool to level off these knobs so the new capacitor can mount flush. (on both sides of the engine). So far the driveway test shows NO radio noise from the engine with the top up. I will update this post once I go for a driving test.
9-17-16 update...
My driving test revealed that the high pitched whine in the speakers is STILL there. So....No noise in the driveway, but noise on the road. (Perhaps that eliminates the alternator atleast.) At this point I can only believe that the radio is defective. Could be a ground issue for the radio itself. I'm out of ideas for now.
This message has been edited by Scott99 on 09-18-2016 at 01:23 AM
padroo
posted 09-16-2016 04:46 PM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
Thanks for the update and a picture is truly worth a thousand words. Give us another update after you are sure one way or the other.
Rayman
Prowler Enthusiast
posted 09-17-2016 04:34 AM     Click Here to See the Profile for Rayman     send a private message to Rayman   Edit/Delete Message   Reply w/Quote   Search for more posts by Rayman
Hello together. I tried to order the ignition capacitors in USA.
Currently I have no dealer found the delivers to Germany.
I'll try these parts in a Chrysler dealer in the neighborhood to order
@ Scott99 Thank you for showing the pictures
quincy
posted 09-19-2016 05:45 PM     Click Here to See the Profile for quincy     send a private message to quincy   Edit/Delete Message   Reply w/Quote   Search for more posts by quincy
Great post! Thanks for the excellent photos and explanation of the issue. Can someone please post a photo of where these puppies are located on the engine?
padroo
posted 09-19-2016 08:55 PM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
This is the location for the Passenger Side Capacitor
If you notice, both have a Dark Green & Orange wire going to them.
This is the location of the Drivers Side Capacitor
This message has been edited by padroo on 09-19-2016 at 09:06 PM
waynec
Prowler Enthusiast
posted 09-20-2016 01:45 PM     Click Here to See the Profile for waynec     send a private message to waynec   Edit/Delete Message   Reply w/Quote   Search for more posts by waynec
I bought mine from Advanced Auto Parts last week.
padroo
posted 09-20-2016 06:27 PM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
Can you post a link to the Advanced website or their part number? I would have never guessed that you could get one from anyone but the dealer.
Rayman
Prowler Enthusiast
posted 09-21-2016 01:24 PM     Click Here to See the Profile for Rayman     send a private message to Rayman   Edit/Delete Message   Reply w/Quote   Search for more posts by Rayman
Hello all prowler enthusiasts,
First I'd like to thank all those who share their knowledge with the newbies.
The helpfulness here in the forum is unique, special thanks to padroo
Today I have installed the capacitors it was very simple.
tomorrow I'll do a test drive,
I am confident the noise is past
best greetings Raymann
Scott99
posted 09-21-2016 01:35 PM     Click Here to See the Profile for Scott99     send a private message to Scott99   Edit/Delete Message   Reply w/Quote   Search for more posts by Scott99
Please note my update above dated 9/17/16. My noise did NOT go away during the driving test.....Back to the drawing board.
Scott
quincy
posted 09-21-2016 01:36 PM     Click Here to See the Profile for quincy     send a private message to quincy   Edit/Delete Message   Reply w/Quote   Search for more posts by quincy
Thank you Padroo for the photos showing the location! What a great bunch of helpful owners and friends!!
Originally posted by padroo:
[B]This is the location for the Passenger Side Capacitor
This is the location of the Drivers Side Capacitor[/B]
padroo
posted 09-21-2016 07:54 PM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
I have heard grounds being a problem for radio interference.
I found this in the Prowler manual under Audio Systems, page
8F-1
Here is the Audio Diagnosis page 8F-3
This message has been edited by padroo on 09-21-2016 at 08:01 PM
Greg and Veta
posted 09-23-2016 11:29 AM     Click Here to See the Profile for Greg and Veta     send a private message to Greg and Veta   Edit/Delete Message   Reply w/Quote   Search for more posts by Greg and Veta
Been meaning to reply as I had the radio noise issue several years ago. Here is what I did and what I found.
My noise was a constant buzz, not related to engine speed, and was not present in reverse or 2nd gear. After reading others suggestions I cleaned all grounds and even disconnected the radio and checked connections there. The noise did go away but I was unsure what really helped. After a year or so the noise came back. I did some more work at it and discovered my problem was the connection behind the radio where the bundle of wires plug in. Every year or so the noise comes back, but I now can easily fix the problem by reaching my hand up under the lower dash and working and securing the connection. Has been working for me so far.
