Author | Topic: WATER LEAK HELP!! |
kittycat 713 Prowler Enthusiast From:houston, tx. harris |
posted 12-04-2017 02:19 PM
Drove home today , parked the prowler , small amout of steam coming from under the hood and saw a little water coming out the top hose. i changed the hose, replaced with new clamps , toped of with radiator fluid. started the car up. then, water started to leakunder the car on the car (passenger side mid section of the moter, Anybody have any feed back? |
posted 12-04-2017 02:30 PM
Is it your air conditioner condensation? |
posted 12-04-2017 03:16 PM
no,.... it was cold when i started her up, the it a small stream , not drip, drip, drip |
quote: As long as it isn't antifreeze you are good. If it is antifreeze, there are several small heater hoses that could cause a leak and there are hoses at the coolant reservoir bottom. This message has been edited by padroo on 12-04-2017 at 03:20 PM |
posted 12-04-2017 03:28 PM
Good point, Dale....If it isn't colored (antifreeze) it ISN'T coming from your cooling system....It IS condensation. |
posted 12-04-2017 04:07 PM
no, it was anitfreeze leaking from under there. |
posted 12-04-2017 04:30 PM
The coolant tank is mid way pass side, it has a overflow if tank fills up. Was ovewflow tank full? Might be over heating. |
posted 12-04-2017 07:20 PM
Now we have confirmed it is antifreeze, do you know about the trapped air that the Prowler is known for? There is a process to bleed trapped air out of the cooling system. If you don't get the air out it will overheat and push antifreeze out of the overflow tank. |
posted 12-04-2017 11:33 PM
After rereading your original post I almost guarantee you have air in your cooling system. This is a common problem on a Prowler. Here is a link that tells how to bleed air out of the cooling system. This message has been edited by padroo on 12-04-2017 at 11:45 PM |
posted 12-05-2017 09:19 AM
ok, ill try it then let you know , |
