General Prowler Discussion new explosive valve stem caps...
Author | Topic: new explosive valve stem caps... |
posted 12-27-2014 10:52 AM
These will set off (Pardon the pun)any prowler rim. Hand made through a long intensive complex aluminum very small lathe. Hand threaded. JustKKKKiiiding I present to you Grenade style valve cover caps. silver.. maroon.. gold.. purple.. black.. green.. blue.. robin
posted 12-27-2014 01:11 PM
Don't give the Prowler any new ideas. lol Do they have the o ring inside, if not I would put one in there? |
posted 12-27-2014 03:21 PM
I like!!! |
FastLane POA Site Supporter Prowler Junkie From:Florida |
posted 12-27-2014 03:35 PM
quote: why would it be needed? i have a slow leek, and i am assuming its from the O ring. |
posted 12-27-2014 04:52 PM
Very nice. I like em. |
posted 12-27-2014 07:28 PM
I have been running them for a year and no problem so far. They are threaded right to the top so they go on good and snug. Never had a low tire light. I guess you could add o rings if you wanted. Fastlane I would try the o ring agiain and if it stops your slow leaky that may be part of the problem .Maybe just the valve needs tightening or cleaned. If it continues have the stem replace and the wheel reseated. Robin
posted 12-27-2014 08:51 PM
quote: Try spaying some windex or window cleaner on the stem, if it bubbles its leaking, could have a leak somewhere on the tire. Could change the core in the valve stem also instead of dismounting tire to get at valve stem if the core is leaking. |
posted 12-27-2014 09:42 PM
I had a tire a few months ago that had a slow leak and it was actually a loose valve core. |
posted 12-27-2014 10:26 PM
quote: That is more common than you think. |
posted 12-28-2014 09:34 AM
I would forego the O-rings, personally. Had them in set of original LogoCaps that would unseat when being put on and then would put pressure on the center valve pin and actually cause the slow leak I experienced. Got rid of o-ring, got rid of problem, kept the LogoCaps |
posted 12-28-2014 12:51 PM
I was quoting tirerack.com. an I reuse my Original Equipment (O.E.) TPMS sensors instead of buying new sensors when I purchase new wheels? A vehicle’s O.E. sensors can be reused with new wheels. A qualified installer will need to remove the sensors from the previous wheels and install them on the new. The following parts will need to be replaced by your installer when reusing O.E. sensors: Rubber grommet seal I actually had the same problem Ray, I had a slow leak and I found the O-ring jammed in next to the schrader valve causing the slow leak. I still use them with the o ring but now I look, it's all about the details. |
