Author | Topic: Keyless Remotes |
aiki99 Prowler Newbie From:Tamarac, Florida, USA |
posted 01-06-2013 09:33 PM
need help with remotes....I lost the only remote that came with the car and looking to replace it.....The remote came with 3 buttons and the Chrysler pentastar on the face of the remote...Is this orginal or was this a replacement from Chrysler ?? Is it suppose to be blank ?....Let me know...Car is a 2001 Plymouth....Thanks |
posted 01-06-2013 09:44 PM
One on the right came from previous owner, and he said that was an original remote. One one left, I purchased it 2 months ego from Chrysler Dealer. Cost about $110 Plus about $50 or $80 to program it to the car. both are the same my prowler is 2000 This message has been edited by DrillinU on 01-06-2013 at 10:01 PM |
blackcat POA Site Supporter Prowler Junkie From:atlanta, ga |
posted 01-06-2013 09:49 PM
Both my originals have a pentastar (2000). |
posted 01-06-2013 09:58 PM
here is a link where you can get either one 97-99 has star This message has been edited by DrillinU on 01-06-2013 at 10:02 PM |
posted 01-06-2013 10:22 PM
quote: Ditto on my '99 ... original owner. |
posted 01-07-2013 07:34 AM
You can find them also on Ebay ... |
posted 01-07-2013 07:42 AM
There are some on ebay now for Prowler $4.74 up I picked up one there for $8.50 a while back .. |
posted 01-07-2013 12:25 PM
quote: Yes, I did the same. Have not yet tried to program it. |
posted 01-07-2013 04:12 PM
I'm not 100 % sure because I'm not the original owner. I think the original remote has the pentastar which is the same as any other Chrysler from that year. The key however I think is different for the Prowler. I got a few keys with the pentastar and and two keys with a cat on them. |
posted 01-07-2013 06:29 PM
For what it is worth regarding Remotes and Keys: IF you have one working remote for your car, you can program additional remotes by following the instructions found in the owner's manual. You can program up to four remotes to operate the car but they must all go through the process within a specified time including the remote you used to initiate the programming process. IF you do not have a working remote, you will need to get at least one programmed by the dealer. Another point to keep in mind is to ALWAYS try to maintain a factory original key if possible. Always make copies from original factory keys then KEEP the original as a spare key to make additional copies from as needed. Use the duplicate keys for daily use because it is better to lose them, damage them, or wear them out instead of an original. If you no longer have an original key, a compitent Locksmith should be able to decode what you have and make a new one to factory specifications that you can then treat an an original. The dealer often uses a clipper with varying degrees of accuracy so I would reccommend the Locksmith route. |
posted 01-08-2013 02:59 PM
So The peanut shape remote with the Chrysler Pentastar is original for a 2001 Plymouth.......Thanks Guys |
posted 01-08-2013 10:12 PM
Does the peanut shaped one have the Chrysler pentastar on the back side? |
RichO POA Site Supporter Prowler Junkie From:Nashville |
posted 01-08-2013 11:04 PM
I have the two original remotes for my '01. Both are peanuts with no pentastar. The back has DaimlerChrysler and is made by TRW in Canada. P/N 04686481 |
posted 01-09-2013 09:26 AM
There are two different models of the peanut shaped remotes. I think it makes a difference which one you need. The model numbers are different. This was discussed 10 years or so ago so you might want to do a search to see about the diff. numbers. there are some numbers for the diff. models on this thread. http://www.prowleronline.com/ubb/Forum6/HTML/006379.html This message has been edited by ed monahan on 01-09-2013 at 09:46 AM |
