Author | Topic: Ball-joint lubrication |
PROWLAW Prowler Enthusiast From:Miami Beach, FL, USA |
posted 09-01-2010 03:51 PM
What's the best way to remove the caps on the front Upper Ball Joints? (sorry I just realized I posted in the wrong section...no clue how to move it) This message has been edited by PROWLAW on 09-01-2010 at 03:52 PM |
posted 09-01-2010 04:24 PM
I put a 3 inch wide putty knife under the edge of the black plastic cap and pop it off. Putting it back on is a slight adventure also. Not a lot of room to work with. |
posted 09-01-2010 05:10 PM
use care so that you do not break the plastic tabs insid..I have been able to pull off and push on |
posted 09-01-2010 05:13 PM
i'm ashamed to admit that I don't own a putty knife...i've tried to pull it off but it's hard to get a grip on it. Anything else I might use? |
posted 09-01-2010 05:45 PM
pocket knife..or butter knife |
posted 09-01-2010 09:16 PM
Long screw driver but don't twist (rotate) the screw driver. Maybe two old credit cards together would be stiff enough. |
posted 09-02-2010 06:05 PM
The first time I pulled the caps off, I broke one. After looking closer at the cap I determined that I may have had a better chance of not breaking it if I pried up at the head or tail side of the cap. The plastic that flexes to hold the cap on has slots in it on two sides and my thought is that if prying is aligned with the splits, there may be a lesser chance of breaking them. I hope this helps. |
posted 09-03-2010 05:38 PM
Wow what a difference it made. The car's steering esp when parking has been "sticky" for years already and I never knew why. Now the steering has a lot less effort, and the steering wheel rebounds much better after I turn. Anybody have an opinion as to whether or not the ball joints might be damaged from not being properly lubricated? |
Jim Kenney POA Site Supporter Prowler Junkie Personal ScrapBook From:Tecumseh, Ontario, Canada |
posted 09-03-2010 08:43 PM
Don't miss the two fittings on your rear suspension. |
posted 09-04-2010 07:39 PM
YA i got em too. Has anyone ever overfilled leading to the boot exploding? Worried I filled it too much. |
posted 09-04-2010 08:54 PM
quote: Yes, it happened to mine.....they did not explode but they got overfilled and it now makes a mess from time to time. |
posted 09-05-2010 08:07 PM
andria,if youre getting a mess of grease around the boot,you may have split it and didnt realize it.if the boot stays clean,no grease around it its ok.sometimeswhen it has to much grease in it ,it may pop in the next couple days,and will start leaking all over.if thats the case,remove wheel and clean w/a solvent,get rid of all excess grease,find the spilt and clean real well and put some 100 percnet silicone on the split and it will stop the leak.next time you grease it give it just a little.i overgreased one of my frts and used the mentioned process to fix it.holding up very good.to avoid removing wheels to grease the 4 fittings,get a tip for the grease gun that has the grease fitting exit on the side instead of the tip.dont overgrease cause it will split the boot.just enough to expand the boot a little.you dont want to blow it up like a balloon,cause it will burst the boot.ive never tried this,may or may not work.to much grease,push ball on fitting down and squezze boot,may or may not release some grease and pressure off boot,its worth a try. ------------------ This message has been edited by catfish on 09-05-2010 at 08:22 PM |
posted 09-05-2010 10:15 PM
I have two different grease gun tips that Catfish described. Make sure you get a good one. One of mine works great, the other one is terrible. I misplaced one and that is why I have two. |
posted 08-24-2015 09:11 PM
ED, I have one of these side grease gun fittings which doesn't work very well. What brand did you use that worked? |
posted 08-24-2015 10:38 PM
I have two grease guns here at the garage at home, not the side cut-out one, however. I have no idea what brand or where I bought it but I will attempt to find it and see if it is marked. It probably is in a bag or box somewhere and I will need to go buy a third one when I decide to grease the car. That is usually how it works out for me. Sorry |
posted 08-24-2015 10:47 PM
Here is one from Lincoln. Lincoln makes good stuff. I have one somewhere but haven't seen it in years. For those who don't want or need to remove their wheels just to grease your ball joints this fitting slides on the zirk fitting from the side. This message has been edited by padroo on 08-24-2015 at 10:48 PM |
posted 08-25-2015 12:44 PM
I just looked at mine but my grease guns are both straight and wouldn't go on (not enough room). I used a putty knife to remove the cap and a short piece of wood and a rubber hammer to reinstall. I never realized that there were any zerk fittings on the Prowler. Anyone know of any others? ------------------ |
posted 08-25-2015 03:46 PM
There are also two on the rear lower control arms. They have the same covers as the front. Be careful not to over lubricate them and damage the boot. |
posted 08-26-2015 06:11 AM
quote: Thanks, Bob. It is surprising what you can learn after 18 years of ownership. ------------------ |
posted 08-26-2015 08:25 AM
and that's why this site is so important to all Prowler owners. Owners get more help here than anywhere else. It helps protect their investment. I sometimes do a search on how to do something. The site helps and there is more experience available that the shop manual. |
posted 08-27-2015 05:21 PM
My cut-out tip does not have a name on it. Sorry. I don't know where the second on is located. |
