Author | Topic: Line Locks are fun |
posted 09-28-2006 07:40 AM
Testing out the line locks now that they are done. This message has been edited by MDProwler on 09-28-2006 at 07:41 AM |
RADCAT RICH POA Site Supporter Prowler Junkie From:SUGAR LAND, TX. USA |
posted 09-28-2006 08:19 AM
Sweeeeeeeeeeeeeeet What does it intail to install?, did you do yourself,what tools /mods necessary? Rich |
posted 09-28-2006 09:14 AM
More 'Pumpkin' photos and Mod Stuff . . . . . . . Our other cars and stuff "I may have to grow older, but I do not have to grow up!" "The Prowler is not a car to go from Point A to Point B. The Prowler is the Point!" |
posted 09-28-2006 10:34 AM
MDP, Are the 'burn out marks' from the Prowler? I notice two trails. I know the Prowler does not have a locking differential, so what gives? |
posted 09-28-2006 01:09 PM
Rich, I did it myself. I believe Marty Usher has it on his also. I will post some pics as soon as I can find them. Norm,explanation I think? Line lock holds the front brakes only so the back are free to burn out! Quicy, The Prowler has an open differential but it always hooks up with both tires. I think if one was in water it would spin the wet one only. This message has been edited by MDProwler on 09-28-2006 at 01:11 PM |
posted 09-28-2006 01:30 PM
Got ya. Thanks. |
posted 09-28-2006 01:40 PM
This is the solenoids set up on a plate and mounted to the frame rail. I used all existing holes and bolts. I prebent all my tubing and tied it into the existing lines. As with most mods it can be removed and put back to stock in a couple of hours. The switch is mounted under the center of the dash. |
posted 09-28-2006 06:35 PM
Nice Gary better start saving tire money. |
posted 09-28-2006 06:58 PM
How come 2 Solenoids?? the Line Locs I remember only had one... |
posted 09-29-2006 05:55 AM
I'm going to give my best explanation here. I think earlier model vehicles (70's) had one brake line for the front and one for the rear leaving the proportioning valve and then they split farther down the line. Todays cars have two front and two rear right off the proportioning valve. I could have put one solenoid before the valve but then the brake fail light would come on every time I used the line locks. I hope that sounds right, maybe Marty has more to say on this. This message has been edited by MDProwler on 09-29-2006 at 05:57 AM |
posted 09-29-2006 08:41 AM
MDP, Thanks for the pics and explain. >i wonder if i could install this,since i have a Paxton S.Chgr. on ?? |
posted 09-29-2006 09:52 AM
I have a set new in the box but I have not installed them yet, how long did it take and did you do it yourself? |
KenG POA Site Supporter Prowler Junkie From:Hamilton, OH, US |
posted 09-29-2006 11:56 AM
I have a line lock on mine too. I put it on about 3 years ago. It is only 1 solenoid. I installed it between the master cylinder and the distribution block and it looks like yours is installed after the distribution block. The only issue I have is that when I use it, the red brake light illuminates on the dash until I press the brake pedal again (after the burn out) It lets you smile when they yell "light em up" and you can smoke em out! |
Ronald Heintschel POA Site Supporter Prowler Junkie From:Maumee OH U.S.A |
posted 10-04-2006 06:19 PM
could you please tell me what brand of line lock do you have ken g and md prowler thanks ron |
posted 10-04-2006 07:21 PM
Ron, sorry i haven't gotten back to you. I used a B&M Launch Kit P/N 46076 and got it from Summit Racing for about $70.
Chris, I probably spent about 8 hours altogether. But I bent all the new tubing to fit the existing tubing. I think if you don't mind the light(could also act as an indicator that the line lock is set) it would be easier to remove the top tube and make a new one then save the original for later. This message has been edited by MDProwler on 10-04-2006 at 07:32 PM |
