This topic has been transferred to: Technical Questions & Answers |
Author | Topic: Gas Fumes |
Butch POA Site Supporter Prowler Junkie From:So Dartmouth Mass |
posted 03-27-2006 06:49 PM
Hi Guys- Does anyone else have this problem? Thanks, |
posted 03-27-2006 06:58 PM
Butch, go to search an type in gas smell. A lot of talk on ths subject. Hope this helps |
posted 03-27-2006 07:19 PM
I do not experience this. My guess is that you have a gas leak somewhere |
posted 03-27-2006 07:25 PM
The car only has 11,000 miles? I don't see anything on the garage floor? This message has been edited by Butch on 03-27-2006 at 07:26 PM |
posted 03-27-2006 07:41 PM
I'll ask the silly questions: Are you topping off your tank? Don't. Are you making sure your gas cap has clicked at least three times? Do. Does it smell after sitting in the hot sun or garage? Could be cold fuel from station (deep in ground) heating up and expanding into the vapor canister? Could be a vapor recovery hose came loose? |
posted 03-27-2006 08:08 PM
Thanks for the help I don't top the tank off. right now it's at 1/2 tank it doesen't seem to matter how much fuel is in the tank. I know the cap is tight. where is the vapor recovery hose? |
posted 03-27-2006 10:01 PM
Don't drive your car and have it checked. An unrelated story. I smelled gas coming from my stove. I called the appliance company and they sent out a service rep who could not detect any leak. I still smelled the gas. I then called the gas company. There service rep checked the stove and immediately found the leak. He turned off the gas going to the stove. He then said the stove might of exploded. The moral of this story. Please get your car checked out by a qualified technician. |
DR PROWLER POA Site Supporter Prowler Florist From:TORONTO,ONTARIO,CANADA |
posted 03-28-2006 04:03 PM
Have to watch those bean consumption,it'll do it to you... Anyway,sorry I can't give you a definite answer on this one...haven't had any problems with it. |
prowlrman Prowler Junkie From:Phoenix, AZ USA |
posted 03-28-2006 04:53 PM
http://www.prowleronline.com/ubb/Forum2/HTML/000408.html
posted 03-28-2006 07:18 PM
Thanks Guys Now I have a few things I can check |
posted 04-17-2006 12:04 PM
No more gas smell It was the large nut on top of the gas tank I removed the access cover on top of the tank Started the car and you could see the gas weep through the top of the nut. it was't very tight? I removed it with my hands! I replaced the O-Ring while I had it apart and put everything back together. No leak I want to thank you guys for the help Thanks Butch |
posted 04-17-2006 02:40 PM
Remove the carpet in the rear storage area and undo the bolts holding on the fuel pump access panel (just behind the driver) My guess is you will see stains from fuel leaking from the O Ring gasket just under the large (about 6" diameter)black plastic ring that seals the fule pump. The O ring could be pinched or torn. It will quit leaking at about 1/4 tank. The O Ring is about a $8.00 part plus labor if you don't have a tool to remove the black plastic ring. Good luck |
