Author | Topic: stumped on water dripping |
hitmus Prowler Newbie From:Chilliwack,B.C. Canada |
posted 06-27-2005 03:13 PM
After a good "hot" up-hill run... and having parked my Prowler... I notice water dripping underneath from the cross-member behind the oil pan! It's not antifreeze as it dries up on the floor. I've tasted it and it's like water with no smell. It doesn't happen with every drive! Do you think it's a problem from the A/C line or hoses? I've never used the A/C yet, and it is turned off! I'm really stumped..... any advice? |
Bama Kat Prowler Junkie From:Pleasant Grove, AL |
posted 06-27-2005 03:27 PM
do you have a small dog that lives nearby Mike This message has been edited by Bama Kat on 06-27-2005 at 04:04 PM |
Bcoffman Gray Ghost Prowler Junkie From:Marshall,Mo.65340 |
posted 06-27-2005 03:47 PM
quote: Condensation dripping out of the evaporater pan. Not to worry. JMO |
Prowl 36 POA Site Supporter Prowler Junkie From:Palm Bay, Florida, US |
posted 06-27-2005 03:59 PM
Since your tasting it , It's probably battery acid, and you just think you see water dripping on the floor.
Ed W. Prowler Junkie From:Port Huron, MI USA |
posted 06-27-2005 07:12 PM
My vote is the defroster. Regardless of the outside temperature, the compressor will cycle on & off during the usesage of a defroster. This occurs is all factory air conditioning systems regardless of make. This message has been edited by Ed W. on 06-27-2005 at 09:33 PM |
posted 06-28-2005 05:58 PM
To Prowl 36.... Yea!...I should have known it's from the A/C... when you get a new toy, you get spooked very easily! Thanks for the advice....I'll try and stay away from the battery acid I personally prefer good Whiskey! |
posted 06-29-2005 01:31 AM
OH you better believe we have all |
V-Rod POA Site Supporter Prowler Junkie From:Kesgrave,Suffolk,UK |
posted 09-18-2016 01:35 PM
I know this is an old thread but I found it from a search as mine did this today. really hot day but no aircon as hood was down. Put it in the garage and saw the trail of water. There is a hose that comes out the bulkhead, water drips down onto the cross member. I never know the cooler would cycle with the air con turned off. Pleased as I was worried it might be a coolant leak. |
posted 09-18-2016 04:25 PM
I'll start, what color is it? |
posted 09-18-2016 05:05 PM
Like it is posted above. Did you have it set on defrost from last drive maybe? Comp. comes on in defost mode. |
posted 09-19-2016 03:26 AM
Overflow from windshield wiper fluid, since it came from going uphill. Just a guess. |
posted 09-27-2016 12:30 PM
quote: Update - found it selected to 'screen', hence air con had been on. |
