Author | Topic: Wheel center caps |
Bcoffman Gray Ghost Prowler Junkie From:Marshall,Mo.65340 |
posted 11-24-2004 03:17 PM
I am getting ready to glue 4 of the clips that broke off the center caps. I know to reinforce at the bases with hot glue by building up a thicker amount at the bottom. My question: what kind of glue to reattach at the break? Maybe a model airplane glue (polypropalene)? Or should I use the same hot glue that I'm using for the bases? Is it as strong at the break as the airplane glue? Are there different kinds of hot glue to look for? |
posted 11-24-2004 03:29 PM
I used cyanoacrylate model glue (CA) to tack the broken tabs back in place. There are different viscosities. I used medium thickness with a spray called a kicker to fast cure the glue. The joint is strong, but brittle. I've used the hot glue sticks and industrial silicone for reinforcement. In the long haul, I think the silicone will hold up better if you have the time to wait for it to cure. |
FL Phil POA Site Supporter Prowler Junkie From:Kissimmee, FL USA |
posted 11-24-2004 03:33 PM
I used the epoxy that has 2 tubes connected together that you squeeze out and is supposed to hold a ridiculous amount of weight. Went to get the name and found out I am out so I got it at Home Depot and will have go back and get some more. I'm sure you know to let that dry for 24 hours then add the hot glue if you want. This message has been edited by CA Phil on 11-24-2004 at 03:35 PM |
vipercat Prowler Newbie From:Ostrander, Ohio, USA |
posted 11-24-2004 04:01 PM
Hi, I am a relatively new Prowler owner. I have not had the center caps off yet. Is there something I should know about them? Thanks much! -Jim ------------------ |
posted 11-24-2004 04:28 PM
be carefull and keep the glue handy ! i siliconed mine on so i wouldn't loose them..the little clips inside are fragile... |
posted 11-24-2004 06:31 PM
A big snot of RTV Silicone Works the best, Just let them set at least 24hrs or longer it is very strong, flexible yet very forgiving. and if you screw up it can almost be peeled off or trimed with a razor knife and resiliconed. I have done lots repairs with it with great success. toys |
posted 11-24-2004 07:25 PM
When you take your caps off, use a clothes-pin half and not a screw driver(for the slot between wheel and cap). You'll protect the wheel and have a better "feel" for getting the cap off...Buddy ------------------ |
posted 11-24-2004 07:34 PM
quote: V/C - the tabs on the center caps break easy,,,,,may be broke on your cat now and you don't know it until you remove them. I've seen broken ones fly off a cat at highway speeds,,,,,just like a flying saucer, lol. Best to remove and "hot glue",,,let cure for a day, and re-install. Do a search feature on "Hot glue center caps" by MADMAX,,,,,to get the scoop. |
posted 11-24-2004 09:24 PM
I just took an old toothbrush handle and taper filed it to fit the the small slot to open it up a little and then used a 2" wide putty knife to pry it off even the rest of the way. And When you pull your center cap if the tabs aren't broken back them with a snot of silicone anyway, by the way i have tried hot gluing them and it sucks. silicone is the best fix. toys |
posted 11-29-2004 01:55 AM
It also helps to put some liquid soap on them just before putting them on the car. It acts as a lubricant so they slide on a little easier and possibly prevents breaking them again. |
