Author | Topic: Question |
Larry King Prowler Enthusiast From:Kenmore, WA |
posted 10-14-2004 07:06 PM
Anyone know what the trim piece around the radio and heat/AC vents is called. Is it still available from a dealer. Thanks, LK |
posted 10-14-2004 07:14 PM
what year is your car I have one for a 97-99 block-buster ------------------ |
posted 10-14-2004 07:21 PM
Mine's a 2000. Are they different. |
posted 10-14-2004 07:59 PM
Larry - yes, they are slightly different. The 2000 and newer cats have a cut-out for the automatic audio control switch. Called dash center bezel,,,most likely an available part through Mopar parts department. I just recently got the top adjustable A/C vent vanes for our cat. |
posted 10-14-2004 08:46 PM
Thanks for the tip! LK |
posted 10-14-2004 10:21 PM
LK - since the 97-99 bezel doesn't have the opening for the auto volume switch, you could always cut out an opening...break out the Dremel! FWIW... |
posted 10-15-2004 01:47 AM
I'm wanting one to modify for a stereo/nav unit install. I don't need the opening for the auto volume adj. Just wanted to keep my original so I could go back to stock if needed. I'll not only need the ole dremel but some bondo and lots of elbow grease. If it turns out well I'll post some pics when finished. Thanks for everyone's comments... the POA site! LK |
posted 10-15-2004 08:09 AM
If you want a stereo/navigation radio, why not use the Mopar RB1. Yeller Cat can help you with the wiring connector if I'm not mistaken. That way you can use the existing bezel without modification. It fits in the same hole. |
