  portable mid-rise lift
Author Topic:   portable mid-rise lift
RADCAT RICH
posted 03-10-2004 09:25 AM     Click Here to See the Profile for RADCAT RICH     send a private message to RADCAT RICH   Edit/Delete Message   Reply w/Quote   Search for more posts by RADCAT RICH
has anyone had any experience /purchase a portable mid-rise lift for the Prowler/other
Eagle sells one thru Eastwood for $1699. delivered.
-it requires that collapsed is 4 1/2 in clearance(i measured last nt, and is within tollerences)
ANY THOUGHTS?
CJ
posted 03-10-2004 12:48 PM     Click Here to See the Profile for CJ     send a private message to CJ   Edit/Delete Message   Reply w/Quote   Search for more posts by CJ
Interesting concept......especially if the garage doesn't have enough ceiling clearance for a full size lift.....
Lift-Portable Mid-Rise 60
Item No. - 43695
Perfect for low ceilings. One hp/110 VAC hydraulic pump lifts up to 6000 lbs 48.5" in 40 seconds. Overall length 90". Width w/support arms retracted 39". Width with arms fully extended 65". Mechanically locks at 16", 32", and 48". Minor assembly required. Includes instructions FREE Extension Adapters ($129.00 value) making total lift 54", and FREE truck shipping within the continental US. Requires a 4" thick reinforced concrete garage floor and 1 1/2 gallons of SAE 10 weight hydraulic oil. Made in Japan. 1 yr man. warr. Shipped by truck. Requires 3 men and an engine hoist or fork truck to unload.
Regular Price: $1,699.99
http://eastwood.com/itemdy00.asp?T1=43695&I1.x=34&I1.y=22
This message has been edited by CJ on 03-12-2004 at 07:49 AM
RADCAT RICH
posted 03-10-2004 03:37 PM     Click Here to See the Profile for RADCAT RICH     send a private message to RADCAT RICH   Edit/Delete Message   Reply w/Quote   Search for more posts by RADCAT RICH
thanks for posting the pic/site CJ.
if i remember correctly, with the garage door CLOSED, (depending on the electric door chain/opener positioned) you can lift the Prowler 42 inches off of the floor!!!
you can do alot of work at that max ht.
**thanks to tim k,& Dr.Phil k for the mail!!
PAXTON S.C.,PROWLER PRO GEARS,BORLA CAT BACK EXHAUST,CARLINI CHROME w/BLK FRONT GRILL,REAR MUD FLAPS, TRAILER HITCH,WEEKENDER WITH SPECIAL MODS!, PROWLER SCRIPT&CAT LOGO ETCHED WINDOWS, EYEBROWSREMOV w/ TOM MILLS TURN SIG. RELOC.KIT, CHROMED TRANSMIS.PAN, POLISHED REAR END ALUMFRAME ,- HAVE OWNED ORIG.SINCE OFF OF SHOWRM FLOOR JAN 02....INCA GOLD!!!!
CTProwler
posted 03-10-2004 07:11 PM     Click Here to See the Profile for CTProwler     send a private message to CTProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by CTProwler
You can do a lot of work under it! Yea if your a midget!
lbs34rod
Prowler Newbie
posted 03-11-2004 11:18 AM     Click Here to See the Profile for lbs34rod     send a private message to lbs34rod   Edit/Delete Message   Reply w/Quote   Search for more posts by lbs34rod
Go to Team Lift and see their products. They have a 4 post lift for $ 1745.00 + Shipping, and their products are made in the USA!!!
RADCAT RICH
posted 03-11-2004 01:35 PM     Click Here to See the Profile for RADCAT RICH     send a private message to RADCAT RICH   Edit/Delete Message   Reply w/Quote   Search for more posts by RADCAT RICH
thanks,dont have the room for 2 or 4 posts that stay there all the time!
WildCat
posted 03-11-2004 03:49 PM     Click Here to See the Profile for WildCat     send a private message to WildCat   Edit/Delete Message   Reply w/Quote   Search for more posts by WildCat
alot of shops use this type lift
I would think it would be OK for the prowler
it is an option if you do not have the room for a regular lift
YellowFever
unregistered
posted 03-11-2004 05:57 PM           send a private message to WildCat   Edit/Delete Message   Reply w/Quote   Search for more posts by YellowFever
Looks like the car could be kinda tippy and there is no way to work under it (basically, a lift to change your tires)
WildCat
posted 03-11-2004 06:20 PM     Click Here to See the Profile for WildCat     send a private message to WildCat   Edit/Delete Message   Reply w/Quote   Search for more posts by WildCat
they do have safety locks.
alot more stable than you think. I know of a `67 Hemi GTX that sat on one for over a year as it was being worked on.....the owner took the tires home so it could not be moved
YellowFever
unregistered
posted 03-11-2004 06:31 PM           send a private message to WildCat   Edit/Delete Message   Reply w/Quote   Search for more posts by YellowFever
I do understand about the locks but, there is an aweful lot of the vehicle hanging over both ends and was thinking the whole thing could tip forward or back depending on the weight distribution (or lack thereof)
CTProwler
posted 03-12-2004 03:02 AM     Click Here to See the Profile for CTProwler     send a private message to CTProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by CTProwler
Rich---only kidding about the midget joke! It would be very handy if you wanted to do tire and brake work. Waxing it would be easier. It has its uses for sure. If your limited to garage height i think its GO!
RADCAT RICH
posted 03-12-2004 08:26 AM     Click Here to See the Profile for RADCAT RICH     send a private message to RADCAT RICH   Edit/Delete Message   Reply w/Quote   Search for more posts by RADCAT RICH
CT, no problem, god knows your not a midget !
The height is great for tire work, frame work/cleaning/polishing,instead of lying on my back straining neck muscles,etc.
i,m thinging about it seriously.
THANKS for all the input!
if anyone else has any info ,feel free to post.
Bcoffman Gray Ghost
posted 03-12-2004 02:50 PM     Click Here to See the Profile for Bcoffman Gray Ghost     send a private message to Bcoffman Gray Ghost   Edit/Delete Message   Reply w/Quote   Search for more posts by Bcoffman Gray Ghost
You think the guy that took his tires home ever figured out that there are a lot of other wheels and tires that would fit?
