  service bulletin 09-002-03
Author Topic:   service bulletin 09-002-03
Lee Sylvester
Prowler Newbie
posted 02-12-2004 09:12 PM     Click Here to See the Profile for Lee Sylvester     send a private message to Lee Sylvester   Edit/Delete Message   Reply w/Quote   Search for more posts by Lee Sylvester
Service bulletin 09-002-03, group: engine, date: march 14, 2003
This bulletin involves decarbonizing the combustion chamber and installing new exhaust valve springs. 1999-2002.
Dealer is suggesting that these repairs should be made if engine begins to misfire. I would assume this begins after your engine has carboned up. (too late!) Repair procedure involves decarbonizing procedure and replacing exhaust valve springs (p/n 04892082AA). I have a copy of the service bulletin that clearly indicates that Prowler engines are involved. I personally would like to have the exhaust valves replaced prior to my engine being full of carbon. Does anyone else have any information or experience with this problem? I am not anxious to have my engine opened up with only a few thousand miles but maybe it would be better now than later.
Thanks
Lee
MDProwler
posted 02-12-2004 09:25 PM     Click Here to See the Profile for MDProwler     send a private message to MDProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by MDProwler
If it's a TSB they will do nothing unless you have a problem. Not the same as a recall. I'll take my chances. I'd rather not have them tear into my engine this soon anyway.
Gary K
idive
posted 02-13-2004 12:13 AM     Click Here to See the Profile for idive     send a private message to idive   Edit/Delete Message   Reply w/Quote   Search for more posts by idive
I think it is Rich Diamond "RADKAT" that is going thru this right now. Sorry if I'm wrong. You might email him at theinterconnect@ev1.net
Does your TSB state what year model Prowlers are involved?
This message has been edited by idive on 02-13-2004 at 12:15 AM
RADCAT RICH
posted 02-13-2004 08:34 AM     Click Here to See the Profile for RADCAT RICH     send a private message to RADCAT RICH   Edit/Delete Message   Reply w/Quote   Search for more posts by RADCAT RICH
Lee- what problems are you having, that you are looking at this tsb(valve springs replac.)
PAXTON S.C.,PROWLER PRO GEARS,BORLA CAT BACK EXHAUST,CARLINI CHROME w/BLK FRONT GRILL,REAR MUD FLAPS, TRAILER HITCH,WEEKENDER WITH SPECIAL MODS!, PROWLER SCRIPT&CAT LOGO ETCHED WINDOWS, EYEBROWSREMOV w/ TOM MILLS TURN SIG. RELOC.KIT, CHROMED TRANSMIS.PAN, POLISHED REAR END ALUMFRAME ,- HAVE OWNED ORIG.SINCE OFF OF SHOWRM FLOOR JAN 02....INCA GOLD!!!!
ken736cc
posted 02-13-2004 09:47 AM     Click Here to See the Profile for ken736cc     send a private message to ken736cc   Edit/Delete Message   Reply w/Quote   Search for more posts by ken736cc
It sounds as if using a combustion chamber cleaner added to fuel is a good idea. I would want to avoid having the cyl. heads removed. Do any of you auto techs have any thoughts on fuel additives?
ETMIDZT
posted 02-13-2004 09:54 AM     Click Here to See the Profile for ETMIDZT     send a private message to ETMIDZT   Edit/Delete Message   Reply w/Quote   Search for more posts by ETMIDZT
4 oz. transmission fluid to every 1-Gal. of gas! I do this every 4th -5th fill up on my LHS & GM truck & Lincoln!!
Lee Sylvester
Prowler Newbie
posted 02-13-2004 09:51 PM     Click Here to See the Profile for Lee Sylvester     send a private message to Lee Sylvester   Edit/Delete Message   Reply w/Quote   Search for more posts by Lee Sylvester
Service Bulletin 09-002-03
I'm not having any engine problems yet. But if this carbon problem is going to show up eventually, then I would prefer to replace the exhaust valve springs now. I'm not sure that Chrysler would perform service bulletin work out of warranty. Since some owners have very low mileage, warranty could expire before the problem shows up. I talked with someone at Chrysler today who was very rude and argumentative and assured me that these repairs would not be made by Chrysler as a preventive measure. I am discussing this matter with local dealer and district rep next week, also confirming which engines are involved. I will post more as soon as I have more information.
Thanks-
Lee
