  Will changes void warranty?
Author Topic:   Will changes void warranty?
Dali
posted 01-18-2004 01:11 PM     Click Here to See the Profile for Dali     send a private message to Dali   Edit/Delete Message   Reply w/Quote   Search for more posts by Dali
Hey all !
I was looking for your feedback on whether a couple of changes I would like to make will void my warranty.
First, I want the car to sound a little more throaty. Thinking of removing the baffles. Any other suggestions without spending alot of money?
Second, would like to replace the stock air filter with a larger filter area. I hear this improves airflow, adds a more throaty sound, and increases horsepower.
I do no want to entertain the idea of superchargers, NOS, and the like. Just a little more sound is all I want.
Any help, advice, or suggestions, will be greatly appreciated.
Thanks alot,
Dali
"Dali" is Dr. Mike & Mrs Jo-Jo S. near Dallas, Tx. <A HREF="mailto:dealer@suttonplacegallery.com">Email Here</A> suttonplacegallery.com Owner of a 2002 Inca Gold Prowler named "Picasso".
GRROWL
posted 01-18-2004 01:24 PM     Click Here to See the Profile for GRROWL     send a private message to GRROWL   Edit/Delete Message   Reply w/Quote   Search for more posts by GRROWL
The only way anything could void your warranty is if the dealer could prove it was directly responsible for a failure. NOS and Superchargers are pretty provable; removing the baffles would be impossible to prove as the cause of a failure - they do not change anything that would harm anything else. Adding an aftermarket Mopar exhaust would reduce the backpressure more than removing the baffles. I share your view and have held off of on gears or supercharger for the same reason. I did pull the baffles, and I am glad that I did.
On the air intake, you may want to rethink it, but only partially for warrantee reasons.
First, there seems to have been an inherent defect in the filter itself from the most popular aftermarket air intake - the hotmelt glue that held the aluminum end-cap on it melted in the underhood temperature, the element separated, with the result that there was NO AIR FILTER at all. Several members, including myself, were highly upset.
Secondly, the jury is out if a "cold-air" intake improves or hurts performance. You should search the subject on this site. The tradeoff seems to be higher airflow, but MUCH hotter air. The stock airbox takes in ambient air through the doorjamb area; the aftermarket takes it in from the engine compartment. Some enterprising members have measured the underhood temperature to be about 60 degrees above ambient. This may be a case where stock is actually better than aftermarket. If you JUST HAVE TO DO SOMETHING, I'd suggest a high-flow filter (such as K&N) in the stock airbox.
Is this more of an answer than you were looking for?
-GRROWL
Gary C
posted 01-18-2004 01:24 PM     Click Here to See the Profile for Gary C     send a private message to Gary C   Edit/Delete Message   Reply w/Quote   Search for more posts by Gary C
Nope, go for the mods, but if you want piece of mind call your dealer.
Dali
posted 01-18-2004 05:17 PM     Click Here to See the Profile for Dali     send a private message to Dali   Edit/Delete Message   Reply w/Quote   Search for more posts by Dali
Thank you both. It is exactly the info I wanted. Baffles will come out. K&N airfilter in. No other mods except flaps, 65watt xenon, and fuzzy dice.
Thanks alot,
Dali
CJ
posted 01-18-2004 05:42 PM     Click Here to See the Profile for CJ     send a private message to CJ   Edit/Delete Message   Reply w/Quote   Search for more posts by CJ
LOL! That's what we all said.....heheheh!!
Except Ed, of course, his cat is totally stock..except for the mods!
CJ - The One and Only
1999 Black - PPROWLR 2002 Deep Candy Red - CJPROWLN
Classic/Beautiful - I'm referring to the Cat of course!
GRROWL
posted 01-18-2004 06:16 PM     Click Here to See the Profile for GRROWL     send a private message to GRROWL   Edit/Delete Message   Reply w/Quote   Search for more posts by GRROWL
Thanks alot,
Dali
Sounds good. One additional STRONG recommendation is ceramic brake pads in the front - DRASTICALLY cuts down on the black brake dust on the wheels. Raybestos Quiet Stop part # PGD730QS (make sure there's the "QS" on the end) are the most popular.
And, even though there's no more mods in your future, you just might want to GLANCE at "Top 10 Modifications?" at:
http://www.prowleronline.com/ubb/Forum1/HTML/008214.html
-GRROWL
This message has been edited by GRROWL on 01-18-2004 at 06:17 PM
idive
posted 01-18-2004 08:20 PM     Click Here to See the Profile for idive     send a private message to idive   Edit/Delete Message   Reply w/Quote   Search for more posts by idive
Air filter test/comparison... http://www.bobistheoilguy.com/airfilter/airtest1.htm
Mickey
1997 Plymouth Prowler #156
Custom car cover
Mopar front splash guards
Real Rod stainless steel transmission cooler cover
Mopar Trailer hitch and harness
Real Rod weekender
Infinity Kappa 63.5i door speakers
1992 Plymouth Grand Voyager SE
Leather steering wheel cover
Longhorn scratches
Boomerschlobber
jkburns
posted 01-18-2004 09:00 PM     Click Here to See the Profile for jkburns     send a private message to jkburns   Edit/Delete Message   Reply w/Quote   Search for more posts by jkburns
Dr. Mike:
Don't forget to put KISS in your CD changer!
Kevin
Kevin, Jo Ann, Jordan and Sadie Burns
2002 Inca Gold
Borla Exhaust — K & N Air Filter — MTD Suspension Braces — Ceramic Brake Pads — Front and Rear Mud Flaps — Gold Shimmers — Real Rod Trans Cooler Cover — Fuzzy Dice — KISS in the CD Changer
Marty Usher
posted 01-18-2004 09:11 PM     Click Here to See the Profile for Marty Usher     send a private message to Marty Usher   Edit/Delete Message   Reply w/Quote   Search for more posts by Marty Usher
As stated before by others, mods will NOT void the warantee unless they contribute to a problem. For your own piece of mind, you may want to check with your service manager when considering performance mods.
I wouldn't know because I have kept mine absolutely bone stock and don't drive mine much.
2000 Black with hand painted blue faded to purple flames
DR PROWLER
Prowler Florist
posted 01-19-2004 12:08 PM     Click Here to See the Profile for DR PROWLER     send a private message to DR PROWLER   Edit/Delete Message   Reply w/Quote   Search for more posts by DR PROWLER
i totally agree with the air filter,exhaust etc.
You have to add a little artistic expression somehow to go along with the user name-perhaps instead of fuzzy dice have fuzzy Picasso or something like that...
MY TOY
posted 08-08-2004 11:00 AM     Click Here to See the Profile for MY TOY     send a private message to MY TOY   Edit/Delete Message   Reply w/Quote   Search for more posts by MY TOY
I just removed my baffles today and it was one of the easiest thing I have ever done to a car. A couple of whacks with a small chisel, punched the rest of the rivet into the baffle with a small torque bit, grabbed it with a pair of vise gripes and it came right out. Took about 10-15 min tops. Don't really see a difference in sound but will leave them out. Why do I need to reset my computer as was stated in previous posts.
Gene
posted 08-08-2004 11:29 AM     Click Here to See the Profile for Gene     send a private message to Gene   Edit/Delete Message   Reply w/Quote   Search for more posts by Gene
Kevin will the Beach Boys disc work?
