Author | Topic: What am I doing wrong. |
thomas leuschner POA Site Supporter Prowler Junkie From:e.islip,ny.,usa |
posted 01-04-2004 10:19 AM
Happy NEW YEAR everyone. Question. Why wont the headlight assy. come off the Kat after I removed the two torx bolts and plastic nut? My Tom M ills bumper kit is waiting installation. Can I remove the bumpers from the top side of the Kat or do I have to put it on a lift? Tom |
posted 01-04-2004 10:38 AM
I'm doing this from memory, but I believe there's a third fastener on the bottom. You also need to remove the grill as the headlight assembly slides forward to release. IMPORTANT: count the shims when you remove the screws or you'll have to play with it quite a bit for it to look right. -GRROWL Back for an edit. I checked the manual (this was BURIED) and now remember that the bottom fastener is an elongated plastic nut over a stud (again, check for shims here as well). Manual does say to remove grill, LIFT UP ON THE FRONT to clear the lower stud, and pull forward. That should do it. Also, don't need a lift to remove the bumpers, but a short ratchet is very helpful for that last bolt (I used a Craftsman 1/4" ratchet, which just fit). This message has been edited by GRROWL on 01-04-2004 at 10:52 AM |
condor Prowler Junkie From:Frankfurt a.M. , Hessen, Germany |
posted 01-04-2004 10:51 AM
I removed the front bumpers just over the bumper srcews. The two on the outside are not easy to get off. First time it tooked me over one hour. Later,I did not put the outside screws back on.So , if i switch between the Tom Mills Set or the org. bumpers , it takes now only 20 minutes for the change. |
posted 01-04-2004 12:07 PM
Tom, I am also going from memory...but absolute there is a big plastic nut UNDER the assembly that has to come off! It is about 3 inches from the front of the housing, be careful it is delicate. Also I believe ther are 3 Torks that have to come off not 2 Mike This message has been edited by thedqman on 01-04-2004 at 12:10 PM |
posted 01-04-2004 12:25 PM
Tom there is a PLASTIC nut on the bottom side of each headlight. |
posted 01-04-2004 01:52 PM
Why are you guys removing the headlight assembly to remove the bumpers? Didn't have to do that to get mine removed. Just wondering what advantage that is, when you have to go back and replace shims and alignment. |
posted 01-04-2004 04:00 PM
Thanks for replies both E Mail and on the board. I looked in from top side of kat and cannot see the other two bolts. Is this job a blind feel method. I promise not to beat this post to death. Maybe I am so anxious to do this I am not seeing the forest for the trees. Tom |
posted 01-04-2004 04:10 PM
quote: two on top, plastic nut on bottom. You need to jiggle it to break it loose (2 or 3 "fingers" need to release in the bottom rear when you pull up and forward). You do need to remove the grill. -GRROWL |
posted 01-04-2004 04:21 PM
I was able to remove the bumpers with a standard lenght Craftsmen combination wrench. A shorty was not needed. Once you get the three out that you can reach easily, tilt the bumper down and the last bolt is easier to get to. You have to reach under and around to reach the last bolt. ------------------ |
