Thread Closed  Topic Closed
  Question on DekProTec removal
Post New Topic
Author Topic:   Question on DekProTec removal
whealy
posted 09-10-2002 02:37 PM     Click Here to See the Profile for whealy     send a private message to whealy   Edit/Delete Message   Reply w/Quote   Search for more posts by whealy
I got my chrome DekProTec a few weeks ago. I decided to order another as I didn't like the way my installation went. ( Previous Post ) So now I need to remove the old one. Any words of wisdom out there on how to remove?
Marty Usher
posted 09-10-2002 03:42 PM     Click Here to See the Profile for Marty Usher     send a private message to Marty Usher   Edit/Delete Message   Reply w/Quote   Search for more posts by Marty Usher
How about carefully!! How's that for a smarta$$ answer.
Actually, see what others post but I would heat with a hair dryer to get adhesive pliable and make every effort to pull off in one piece.
Good luck with it.
Marty
YellowFever
unregistered
posted 09-10-2002 03:48 PM           send a private message to Marty Usher   Edit/Delete Message   Reply w/Quote   Search for more posts by YellowFever
Good luck with it.
Marty
A heat gun (alot hotter then a hair drier) works wonders on adhesive and won't harm the paint provided you don't leave it in one spot too long. I've used them for years. You can find them at hardware stores like Home Depot.
whealy
posted 09-10-2002 04:20 PM     Click Here to See the Profile for whealy     send a private message to whealy   Edit/Delete Message   Reply w/Quote   Search for more posts by whealy
Thanks guys,
But is this really an adhesive? There isn't any adhesive when you put it on. Does the soap and water combine with the vinyl to create an adhesive? I was thinking of getting it real wet again.
Marty - is the heat gun how you got your first one off?
GRROWL
posted 09-10-2002 04:36 PM     Click Here to See the Profile for GRROWL     send a private message to GRROWL   Edit/Delete Message   Reply w/Quote   Search for more posts by GRROWL
My point of reference is going back about 25 years, but I doubt that anything has changed. The 3M reflective film at that time acted the same way - you could move it all around, but once you pressed it in place, that was it. The way they did it was that the adhesive was encapsulated in microscopic beads that burst when pressed down. The end result was a very even, full-area glue lamination.
Can anyone confirm or deny whether this is still the case?
-GRROWL
fixumm
posted 09-10-2002 06:24 PM     Click Here to See the Profile for fixumm     send a private message to fixumm   Edit/Delete Message   Reply w/Quote   Search for more posts by fixumm
GO TO ANY PAINT/AUTOBODY SUPPLY. WE HAVE AN STRIPE REMOVER THAT GOES ON THE END OF A HIGH SPEED DRILL....LOOKS LIKE AN ERASER.... ON ANY CLEAR COAT (ONLY) PAINT IT WILL TAKE ANY GLUE OR STRIPE TAPE OFF WITH OUT HARMING THE PAINT, I HAVE BEEN USING THEM FOR YEARS AND NEVER F-UPED ANY PAINT JOB.............FIXUMM
EDITED FOR SPELL CHECK,, NOW I KNOW WHAT THAT BUTTON DOSE
This message has been edited by fixumm on 09-10-2002 at 06:26 PM
Marty Usher
posted 09-10-2002 06:32 PM     Click Here to See the Profile for Marty Usher     send a private message to Marty Usher   Edit/Delete Message   Reply w/Quote   Search for more posts by Marty Usher
fixumm's reply sounds likegood advise. I will ask our grahic dept what they use to remove vinyl when they reletter trucks.
ALLEY CAT
posted 09-10-2002 10:03 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
"W" - DO NOT do what Ed did to get his off,,,,,,oxy/acetylene torch is not the tool for that job.
growl
posted 09-11-2002 01:16 AM     Click Here to See the Profile for growl     send a private message to growl   Edit/Delete Message   Reply w/Quote   Search for more posts by growl
Somewhere I remember that in the DekProTec (sp) posts that they said after two years it's a difficult
trick. I'd ask the DecProTek folks. My guess is that a hair drier or heat gun of any kind is not a good choice. My first try would be to use the the original solution, ivory soap diluted with lottsa water.
Put down a plastic drop and spray the hell out of it.
Pick at the corners and if it comes up... spray and pick.... carefully. Lots of water and soap and keep the water/soap out of the car.
When you put it back, be careful of the little point in the spine of the P. Wipe drivers side to passenger side until things dry. There are some flimmsy things in the middle of some of the letters... careful... watch the alignments.
~bg
ed monahan
posted 09-11-2002 02:35 AM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Soap and water is not going to do a thing, in my opinion. It is not going to get under the vinyl and you have a great chance of scratching the paint unless you have a loose edge. WD-40 will loosen the adhesive if you can get it started. I think heating it will make it a little more pliable. (The oxy/acetylene torch took if off clean as a whistle. No runs, no drips, no errors) Fixxum is in the business so I would venture to say he knows the most. WAIT A MINUTE, did I really just say that? Let me go check my meds to see if I am under the influence of something.
fixumm
posted 09-11-2002 06:36 AM     Click Here to See the Profile for fixumm     send a private message to fixumm   Edit/Delete Message   Reply w/Quote   Search for more posts by fixumm
OMG ed i think your loosing it LOL. But when it comes to a paint finish i would not steer or stear (what ever) you wrong....
fixumm
posted 09-11-2002 06:44 AM     Click Here to See the Profile for fixumm     send a private message to fixumm   Edit/Delete Message   Reply w/Quote   Search for more posts by fixumm
this is one kind of a stripe remover tool, but you can buy one that goes in the end of a drill for about $18.00
This message has been edited by fixumm on 09-11-2002 at 06:46 AM
whealy
posted 09-13-2002 10:49 PM     Click Here to See the Profile for whealy     send a private message to whealy   Edit/Delete Message   Reply w/Quote   Search for more posts by whealy
Thanks to everyone for their advice. I also placed an email to Paul (the seller/manufacturer) and he gave me the following advice. If for some reason, he has an issue with this, I’ll pull his comments from my post.
Bill, use a hair dryer to heat the surface of the chrome vinyl being sure to
not apply too much heat to the surface. Your goal is just to warm it up.
Using your fingernail, you should be able to lift an edge of the vinyl.
Continuing to warm the surface ahead of where you're pulling, apply
continuous pulling pressure which will SLOWLY allow you to lift it off the
car.
I'd next use 3M's glue and adhesive remover from a car parts store. READ AND
FOLLOW 3M's instructions. I believe if you follow their use directions you
can remove any remaining adhesive that does not come off with the vinyl. And
that's about it.
Good luck.
Paul
I took his advice except I used a heat gun (thanks YellowFever) and it all came off fine. The key piece was the 3M adhesive remover. That stuff worked great. The second application went much better. I still think the use of the Pledge Grab-it towel made all the difference in the world at removing the dust.
Special thanks to GRROWL for his description of how the adhesive worked. No one validated you description, but for me that made sense. It also helped on the re-application as I realized I was probably putting down the adhesive with the squeegee not just pushing out the bubbles. So I touched every square inch, not just the parts where I though I had bubbles like I did the first time. Hey I never claimed to be an expert.
Also, thanks to fixumm. That stripe remover looks cool. However, I was way too intimidated to buy one for my drill (not that I found one in the Indy area nor would I necessarily know where to look) and work with it on my car without assistance. I thought about driving up to Chicago and having his guys take it off for me, but ultimately I took the path I/Paul described here.
This message has been edited by whealy on 09-13-2002 at 10:50 PM
GRROWL
posted 09-14-2002 08:17 AM     Click Here to See the Profile for GRROWL     send a private message to GRROWL   Edit/Delete Message   Reply w/Quote   Search for more posts by GRROWL
whealy,
You have a real gem buried in there that I wish I knew about before I did mine:
Originally posted by whealy:
. . . . the use of the Pledge Grab-it towel made all the difference in the world at removing the dust.
Consider this a nomination to the "Inventors Hall of Fame" (if it ever comes off). See:
http://www.prowleronline.com/ubb/Forum11/HTML/000089.html
-GRROWL
GRROWL
posted 09-14-2002 08:21 AM     Click Here to See the Profile for GRROWL     send a private message to GRROWL   Edit/Delete Message   Reply w/Quote   Search for more posts by GRROWL
whealy,
-GRROWL
ALLEY CAT
posted 09-14-2002 08:39 AM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
I used the 3M adhesive remover to remove the factory decals off a '83 toyota pick-up many years ago, and it worked very good. It can be bought at most automotive paint & body shop supply houses, or any CARQUEST Auto Parts store,,,think it sells from $12 to $16 for a can of it.
ed monahan
posted 09-14-2002 07:32 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Common lighter fluid or WD 40 will work. Decals are basically the same as bumper stickers or plastic electrical tape. The soapy water is to be able to move them around a little and has nothing to do with them sticking.
whealy
posted 09-14-2002 09:54 PM     Click Here to See the Profile for whealy     send a private message to whealy   Edit/Delete Message   Reply w/Quote   Search for more posts by whealy
Well Ed, the 3M adhesive remover did smell a lot like gasoline or turpentine. So I don’t think you’re too far off. I mainly went with the 3M product because I felt it was safer and worth the $12.
Post New Topic
