General Prowler Discussion My Prowler is broke down at a friends house....
Author | Topic: My Prowler is broke down at a friends house.... |
posted 08-25-2002 11:30 AM
My Prowler has been getting a little hot on the highway with the air on. So I decided to flush the raditor. So off to the parts store I went, I bought Napa antifreeze and some purple stuff to make it a little cooler. So about an hour and a half later I'm done, I burped it, checked it, cleaned it and even tested it. Everything was fine so I went home and checked it again. The gauge still went above the halfway mark but seemed ok. So I took the car to work the next morning everthing was ok. I left work going over to a friends house and I look over at the gauge and I was running HOT!! so I pull in the drive way and water was flowing out of the car NOT HAPPY. I wait till The car cools down and fill it back up with water. After about an hour I get back in the the car and get about 4 blocks in the car keeping my eye on the gauge going in the red, so I turned around and asked my friend if I could keep it here till Monday when the dealership opens.
PANTHER CITY PROWLER POA Site Supporter Prowler Junkie From:Ft Worth, Tx |
posted 08-25-2002 11:39 AM
cnote- Let us know what they find, mine seems to be running a little warmer than it had in past summers and I'd like to know what they find with yours. |
Chris - if it went HOT in four blocks, sounds like a thermostat problem. Al Becker just went through an extensive 'overheat' problems,,,,finally, new water pump and thermostat got the cat cooled down. Maybe email him to chat about it,,,,,he is now highly schooled in this area. ------------------
posted 08-25-2002 12:12 PM
Chris: Sounds like a stuck thermostat, have replaced many - not a tough job on the ones I've worked on, but couldn't tell you about the cat. Good luck and let us know what happens! Tami |
posted 08-25-2002 12:22 PM
quote: This happened to me once right after I changed the antifreeze. Apparently, the flush and fresh antifreeze can clean out old accumulations that were plugging leaks. In my case, it was the waterpump. Seems more than a coincidence that it happens right after a change. -GRROWL |
posted 08-26-2002 09:19 AM
Sorry to hear about your problems Chris. Hope you get bthe KAT bcak running "cool" soon. Marty |
posted 08-26-2002 10:27 AM
Flushing radiators can stir up a lot of junk to clog up those fine coils.... |
posted 08-26-2002 10:42 AM
remember the post that said that there was a lot of casting sand left in the block? maybe it made it's way into the rad core. I've had the antifreeze changed a couple of times. I seem to be running cool. |
posted 08-26-2002 10:59 AM
This message has been edited by cnote6 on 08-26-2002 at 11:03 AM |
posted 08-26-2002 02:01 PM
Chris - did you get the KAT repaired? |
posted 08-26-2002 10:32 PM
sounds the same as my problem of a month ago, CNote. New thermostat and no problems since... Good Luck ! Aggravating, (mine had about 8000 miles on it then) but proved to be only temporary. Since then, went to Woodward and back, over 10,300 now, still no problems |
Ray unregistered Personal ScrapBook Admin Use |
posted 08-27-2002 09:32 AM
You guys may have this one diagnosed, but also check the relay for the electric fan. That was MY car's problem after only a 1k miles and when driving around town got VERY hot and then puked all fluid ... was fortunately at the DC dealer when it happend. New relay, no over heat problem now. |
posted 08-28-2002 12:14 AM
Fan is OK, bought a New thermostat and will install it in the morning. $17.00 Hope it works. |
posted 08-28-2002 01:36 AM
Had over heating problems in AZ this weekend... put into a local shop Monday as it was getting worse. "They" said the Kat had the wrong fluid and an air bubble... cooler but still not "right" going back "in" soon. |
posted 08-28-2002 01:46 AM
Chris, If the stat don't work, have the pressure checked. Had my checked after overheating problem and it turned out that I was only holding about 4 lbs. of pressure. Should be about 17, I was told. Replaced cap and all is well so far. ------------------ |
posted 08-28-2002 06:15 PM
After a 3 hours outside and the car apart everything seems to be ok. The drive to the house the Kat was running hot for about 10 min. them it seemed to cool down to half way. I will check it in the morning. |
