General Prowler Discussion Remove Door Panel Help
Author | Topic: Remove Door Panel Help |
Kid Rock Prowler Junkie From:Monroe, Michigan |
posted 08-11-2002 09:14 AM
Sorry to post this here, but I need help fast. Does anyone know what is takes to remove one of the interior door panels. It looks like 3 screws. Thanks Kidrock This message has been edited by Kid Rock on 08-11-2002 at 09:14 AM |
posted 08-11-2002 09:21 AM
Kid Rock: Check out this post http://www.prowleronline.com/ubb/Forum2/HTML/000632.html Thanks, Tami |
posted 08-11-2002 09:56 AM
The trim stick I use isn't probably the same kind as what Jan uses but it works great, here's a picture of it. Al |
posted 08-11-2002 10:14 AM
Thanks!!! |
posted 08-12-2002 08:30 AM
Still have a problem Anyone Do the bezels come off first and then the panel. As far as I can get, is the removal of the 3 screws. The panel does not want to move at all. Kidrock |
posted 08-12-2002 11:57 AM
Heres the deal with the bezels. There are four fingers that hold bezel in place. If not removed per the factory manual be prepared to break them off and order new ones. As follows: using a trim stick to lift front edge of bezel slightly away from the trim panel and sliding the bezel rearward. Take your time or you will break bezel anyway. |
