Thread Closed  Topic Closed
  Recalibrate tire pressure sensors?
Post New Topic
Author Topic:   Recalibrate tire pressure sensors?
spoons
posted 04-18-2001 11:31 AM     Click Here to See the Profile for spoons     send a private message to spoons   Edit/Delete Message   Reply w/Quote   Search for more posts by spoons
Hey all,
My annoying "low tire" pressure light keeps coming on when I drive the Prowler and I spoke to my prowler tech and he says he need to recalibrate the tire pressure sensors or I may have a bad sensor! I know a new sensor cost about $200!! My car just went off the 36/3yr warranty, but are the sensors cover under any warranty like the tires still are? My car only has 9000 miles on it.
Can I recalibrate my tire sensors myself? Seems weid the sensor went off right around 9k miles.
Thanks for all your help, you guys are the best!
Brian K. Richardson
West Palm Beach, FL
http://mycat.50megs.com
1997 Purple W/ 1997 Mopar Trailer
Splash Guards
Ceramic brake pads (front)
"Cracked Ice" shimmers on rear bumpers
2001 Prowler Ignition Key
"Quality NOT Quantity"
Joe Rad
posted 04-18-2001 11:37 AM     Click Here to See the Profile for Joe Rad     send a private message to Joe Rad   Edit/Delete Message   Reply w/Quote   Search for more posts by Joe Rad
Brian....
Heard from another Kat owner to take air pressure up to 50 Lbs then back down the pressure to correct lbs.
This over-inflation is supposed to "reset" the pressure sensors.
I have not had any sensor problems, so I do not know first hand, but worth a try for FREE.
Let us know if this technique works.
spoons
posted 04-18-2001 11:48 AM     Click Here to See the Profile for spoons     send a private message to spoons   Edit/Delete Message   Reply w/Quote   Search for more posts by spoons
Thanks Joe
I will try that and let you know if that works.
Brian K. Richardson
West Palm Beach, FL
Splash Guards
Todd Cameron
unregistered
posted 04-18-2001 11:59 AM           send a private message to spoons   Edit/Delete Message   Reply w/Quote   Search for more posts by Todd Cameron
As expensive as our Cars are to repair, extended warranty's are a must have IMHO.
2000 Black, 2001 Black Tie, 2001 Orange
FL Phil
posted 04-18-2001 04:25 PM     Click Here to See the Profile for FL Phil     send a private message to FL Phil   Edit/Delete Message   Reply w/Quote   Search for more posts by FL Phil
Have you talked with your dealer on if they would cover the sensor work under warranty? If they won't I would ask for the DC Zone Manager and discuss the matter with him/her.
Dealers and DC have been pretty good with the warranty work.
neal
DC Certified Prowler Tech
posted 04-18-2001 08:33 PM     Click Here to See the Profile for neal     send a private message to neal   Edit/Delete Message   Reply w/Quote   Search for more posts by neal
hey brian,try to get them to warranty it, its called goodwill we do it all the time for cars slightly out of warranty. ask them is this part designed to break at 36,ooo that gets them everytime hope this helps neal
ed monahan
posted 04-18-2001 09:55 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Get another Prowler owner to switch wheels with you and have him take it in, while he is under warranty. Then reswitch wheels. Tell them BIG FOOT sent you.
ALLEY CAT
posted 04-18-2001 10:25 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
Wolfman - great idea, why didn't I think of that? Its no wonder the City of Cinci kept you on payroll so many years, how much money did you save them?
Make sure you break all the center caps, so that sensor adjustment will only cost $220.
You don't think they would check the numbers on the tires, do ya? NA..
Larry Salzman
Call 911 - there is a Prowler in my garage....
spoons
posted 04-19-2001 06:34 AM     Click Here to See the Profile for spoons     send a private message to spoons   Edit/Delete Message   Reply w/Quote   Search for more posts by spoons
Hey Guys,
IT REALLY worked!!!!!! I pumped my tires up to 50 PSI turned on the car, turned it off and the deflatted the tires to the correct air pressure. (30 psi front and 32 psi rear). I drove the car about 10 miles and the light never came on! Wow it only cost me $0.50 to pumps the tires up at the gas station. So that is how you recalibrate your tire pressure sensor. Thanks Joe for the tip.
Brian K. Richardson
West Palm Beach, FL
Splash Guards
Post New Topic
