Topic:window adjustment
Club2425Does anyone know if there is any adjustment on the window mechanism. When I put it up all the way there is a gap on the top right hand corner. it also seems to be coming up at the wrong angle. Can this be adjusted?
This message has been edited by Club2425 on 12-03-2003 at 07:51 PM
ALLEY CATThe Club - did it just start to do this? That is what my window did just before the regulator/plastic crap part broke.
BeWareFrom the manual. It also has a chart which I cannot duplicate
Note: Verify the door is properly adjusted to the body prior to adjusting the door glass,
Note: Convertble top must be up and latched securely
Fore-Aft Adjustment
1)Lower glass to mid position in order to access the glass attch bolts.
2)Loosen the rear glass attaching bolts
3)Ajust glass fore-aft by sliding glass assembly forware and backward
Note: Glass attach bolts will move in slots of rear window regulator plate,
Up-Down Tilt of Glass
1) Loosen rear guide rail upper attaching nut and lower jack screw attaching nut.
2) Remove top seals
3) Tighten rear guide rail upper attach nut
4) Align top edge of the glass to top seal
5) Tighten both jack srew nuts
6) Replace top seals
Cross-Car Adjustment
1) Loosen front and rear lower jack screw nut
2) Adjust jack screw with 3mm allen wrench to move upper edege of glass inboard or outboard as neede.
Note: counter clockwise for inboard adjust abd clockwise for outboard adjust.
3) Tighten lower guide rail jack screw nuts
Full-Up Position Adjustment
1) Loosen up stop fastner
2)Remove convertble top weatherstrip
3) Adjust window to specifications in Door Glass adjustment Sequence Chart
4} Tighten up stop fastener
5) Replace convertible top weather seals
6) Verify thet the top edge of the door glass is beneath the lip of the weatherstrip with the glass in the full up position
Club2425yes just started doing it AlleyCat. Beware, thanks for the tech help, do they give any tips on removing the door panels, I don't want to damage anything.
idivewell, my post WAS under AC's... WTH happened to it?
OOPS... I posted to the same topic in the general discussion forum.
This message has been edited by idive on 12-03-2003 at 11:15 PM
catfishYOU WONT NEED TO REMOVE W/STRIPS.
jd2ksilverYou got mail Bruce, pretty large file, ,,
This message has been edited by jd2ksilver on 12-04-2003 at 10:59 PM
ed monahanI thought no one ever put the top up, therefore the windows should be down, also. lol. I still drive with the windows up and the top down. Of course I still wear black socks with white gym shoes.
BeWareEd, are you the weird uncle referred to in another post?
GenoTexWas there ever a doubt Rich?
catfished,i thought they stopped wearing those in the 50s.oops i forgot this is still the 50s,dont we wish.
