Topic:Window regulator
Kelley AustinDoes anyone know if there are any drivers side windo regulators in stock ANYWHERE. I was qupoted $565.00 for a new one. This is not what I was really wanting to hear.
stevedymoTry directmopar.com
Left side window reg 480.00
or
Wholesalemopar.com 484.00
If you get one be sure to do the fix (reinforce) before installing.
cstall
quote:
Originally posted by stevedymo:
...If you get one be sure to do the fix (reinforce) before installing.
You may even be able to fix the one you have (provided it's not too far gone), before you spend $$$ on a new one.
quincyKelley,
There are several options to repair the current regulator. Perform a search in this site and do a bit of analysis homework. Tom Mills makes a bullet proof replacement regulator made with real steel and real gears. If I remember correctly his is in the $600 range as well (but worth it). If you never want to hassle with these cable driven devices again look for a set from Mr. Mills.
ed monahanTom Mills' regulators are $ 320 each and are much better than the original. they don't use plastic parts.
On the main purple menu, at the bottom, "select a vendor"
and choose Tom Mills Jefferson Auto. You will see it there.
They are highly recommended by most folks who have had a problem.
http://www.prowleronline.com/ubb/Forum1/HTML/018495.html
This message has been edited by ed monahan on 04-30-2012 at 06:35 PM
idiveIf you want to stay stock I'll sell you a driver side for the same price as Mills' plus shipping. I have the passenger side too. Same deal.
garysssI just fixed Passenger side on mine Thursday. I used a rubber hose and clamps on tubes on both sides of motor. It was broke at the elbow. Working great so far and don't for see any problems, hopefully.
ALLEY CAT http://www.prowleronline.com/tommills.html#PWRU
Prowler Window Regulator Upgrade Kit:
Replace the broken plastic tube and cable drive assembly with a quality gear and lever drive that won’t let you down like the factory replacement parts will. Includes all parts necessary to make the change to the new style drive, including a new motor, detailed instructions and assembly pictures.
Now in stock, will fit all Prowlers, Right and Left sides available at $320.00 each
Plus Shipping
Tom Mills/Jefferson Auto
Best bet, IMO
Tom MillsIMHO. The plastic tubes on the original regulators are the weak parts that give up and my opinion is that if you replace it with an original regulator it may give up in short order again. Some have replaced several in each door. The plastic tubes get hard and brittle over time so if you replace it with a new one that has been around for a while it will give up even sooner. I have seen new ones that were so brittle that the tubes broke when you bend them to install it in the door. Again just my observation
Kelley AustinThanks guys that sure beats the $500+ for an original. I'll get in touch with Mills. How hard are they to replace if I try it myself? I had to put plastic wire ties on the one that broke to keep it up. Broke just before I was heading to Gatlinburg last week.
Mr.McgooIf you have basic mechanical ability it is easy especially with the detailed instructions ,,,,
silverprowler2000My passenger side window went kaput a week or so ago. Just received my new one from Tom Mill yesterday. Will get it installed in a day or so. Everything was wrapped in bubble wrap with zip lock bag with screws, misc parts and detailed instruction. First impression is spot on. Can't wait to get it installed
This message has been edited by silverprowler2000 on 05-05-2012 at 07:34 AM
silverprowler2000Got my new regulator installed last night. It was a little tough and took forever. Glad I didnt' try it on my own. The other side will be so much faster. I will do the other side soon since it is fresh on my mind. 3 hours into the replacement we were checking fit on both side. My friend accidently hit the door lock button, we didn't realize it. Until both doors were closed and we were locked out of the car. Went to the shop that he worked at to get the bar to unlocked the door. After 4 hours it was done. The new unit is so much better than the factory design.
alrtgMine was done with the top down, no problems (unless you call all the help I had a problem)
This message has been edited by alrtg on 05-08-2012 at 08:36 PM
beachcat
[/B]
That's funny! Things like that happen to me all the time.
I gotta ask though, why was the top up? or do you have a hardtop on?
BeWareHe said be was checking the fit.
beachcat
quote:
ah gottcha!
silverprowler2000Alrtg,
We did the install with the top down. Than put it up to check for fit. So how did you do the complete install wtih the top down?
garysss
quote:
Originally posted by silverprowler2000:
Alrtg,
I helped Andria and also just did mine 2 weeks ago with top down. I repaired mine and made circle around all bolts I remove so I knew where to put it back.
alrtg
Alrtg,
We did the install with the top down. Than put it up to check for fit. So how did you do the complete install with the top down?
My top did go up to test the fit but the installation was done with the top down. After posting I did realize my top was actually up for some of the installation but did not edit it.
SEE, it was down! That is Goop Of Oil helping me while Garysss was slacking off.
That silver stuff you see on the door is Dyna Mat which was installed throughout the car including the inside of the door skin then again between the door and door panel. (yes someone got carried away with the stuff.)
This photo was taken at an ECP Maintenance session hosted by MDProwler. Another one is coming up real soon.
This message has been edited by alrtg on 05-10-2012 at 05:15 PM
beachcatIs goop of oil related to the duke of earl?
alrtg
quote:
No, he is related to the Wizard of OZ!
idiveGarysss was what???
This message has been edited by idive on 05-10-2012 at 11:11 PM
