Topic:Replaceing fuel filter
05coachSince the fuel filter is no longer available, has anyone tried to retrofit an after market fuel filter to their prowler?
padrooThere has been talk about it but it is an oddball filter with three openings from what I understand.
This message has been edited by padroo on 08-23-2015 at 11:49 AM
Tom MillsI am working on it as we speak
jwallisThanks Tom
MellowYellowFor what it's worth, my mechanic, when doing my fuel pump replacement, found a Dodge van with the same fuel filter with the three lines.....if anyone needs the part or Model of the van, let me know....
Brian
RPLI'd love to have the part number of that fuel filter.
RDinTN
quote:
Brian
Yes, please.
Landscape Doctor
Brian
Yes,Yes,Yes, We are all waiting impatiently.
robinThis if for a dodge van ...
May look similar but might not fit prowler http://www.autopartswarehouse.com/sku/Hastings/Fuel_Filter/HAGF299.html
second one is for a dodge to.
Robin
This message has been edited by robin on 12-28-2016 at 09:21 AM
Richnew41Tom is a genius... If anyone can pull it off its Tom...
Thanks Tom!!!
phil2237Most likely his mechanic found one that will work, Hope he does post some info
phil2237Has anyone found out what fuel filter from a Dodge van fits the prowler as Mellow Yellow seems to ignore this post
robinI don't think there is a direct fit ...
You would have to alter the lines.
They are not pliable so unless he is altering the fittings in some way .....
prowler
dodge
parts guy bill carries right one unless you break the line .
You only need to back wash prowler filter and re use.
drbuttonMy mechanic and I went through a lot with this issue. We ordered a Dodge Caravan fuel filter and he considered modifying it to fit my 99 Prowler...as Robin implied, the mechanic determined that modification of the fuel lines would indeed be required to make it fit. He became uneasy with fuel line modification as the pressures involved were a safety concern. We sent the Dodge filter back, and I bought a 2000+ filter from Bill ("parts"). Bill was not sure that he had one of these, but he was able to find one. The external fuel filter is a rare part for any year of Prowler, and is actually different on the 1999 vs. later years. We made the 2000+ part work without line modification. I am glad to hear Tom is working on this. There is not really an alternative except for a reproduction/custom unit made by interested party, one who has talent. Tom is one of the few who have such talent.
Brian
