Topic:Noise at rear of car
mslc10After a drive home from car show I heard what sounds like a rod knock but comes from rear of car , in park , noise follows engine rpm. I'm guessing bell housing bearing .....?
BradleyGA few years ago, I had similar noise, but it was only while I was moving. I bought a used driveshaft and transmission input housing, but did not need them because the noise was loose drive shaft bolts. I have these parts if you need them. Below is the link to my issue. Good luck. Two.one.four. 557.1084. Brad
http://www.prowleronline.com/ubb/Forum2/HTML/004151-2.html
mslc10Good info ! Thank you!
Landscape DoctorAny luck with finding out were the noise is coming from?
mslc10Haven't explored any further...
This message has been edited by mslc10 on 10-28-2016 at 08:36 PM
mslc10Started Kat today to get it ready for show tomorrow and no noise. Seems to be only when warm.....
