Want to register? |
What is the code? This message has been edited by padroo on 05-31-2018 at 10:15 AM Next, try Swapping high speed fan relay with low speed relay and see what happens. This will determine if it's a relay problem or something else. Fuses and Relays are in the Power Distribution Center( PDC) located under hood on divers side. Label on inside cover of PDC shows locations. To check the actually relay you will need a Multi-meter to measures continuity, resistance and voltage. Try relay swap and let us know results. Let me hit the schematic in service manual tonight. I'll be back in touch after a little research. This message has been edited by padroo on 05-31-2018 at 07:55 PM Basically you have two sensors that control fan. One is coolant temperature sensor and the other A/C Pressure Transducer. Both sensors are routed to PCM (Powertrain Control Module) which then sends signal to fan speed relays to turn fan on. One of these sensors is possibly defective, or the PCM is defective (lets not go there on PCM) or there could be a short somewhere in the wiring. To test you would need to disconnect wire plug on each sensor, one at a time to see which is causing the problem. Access to A/C pressure transducer is by removing passenger side, side panel. Look for it by A/C lines near firewall. Coolant sensor is located below/near upper radiator hose where it connects to engine. (so manual says) I did a quick look and could not locate it. Perhaps another member could help with location. So... remove coolant temperature sensor connector and see what happens. Replace connector, then do the same for A/C sensor. BTW... check the temperature gauge and see if it's functioning. Is it bottomed out when cold, or is it reading something cold? Tomorrow I'll give you wire color code for both sensors to help you better locate them. Do you have a multi-meter? This message has been edited by Tomcal on 05-31-2018 at 09:29 PM A/C Pressure Transducer sensor is three (3) wires; Violet with white tracer Tan with Black tracer Good luck and keep us updated on your progress. This message has been edited by Tomcal on 06-01-2018 at 01:45 PM jimvbell 2000 getting a 2nd aux fan code error. The fan starts as soon as you turn on the engine and does not shut off. Appreciate any help... padroo quote:
Originally posted by jimvbell:
2000 getting a 2nd aux fan code error. The fan starts as soon as you turn on the engine and does not shut off. Appreciate any help...Tony Goertz For starters - Can be bad temp sensor in engine or transmission. Either will cause computer to turn on fans.
Also a bad (missing) high speed fan relay or fuse will cause low speed fan to come on immediately. I'd check the fuses and relays first. jimvbell Thanks Guys I'll start there...Appreciate the help... CAT-A-TONIC Coolant temp sensors can go bad but not likely. There's a property inside them that connects the two sides of the wires together. This property create resistance between the two sides of the wires up to where it's connected by the plastic plug in. This property is calibrated so that when coolants mostly cold there's the most resistance and least amount of voltage that gets through. when engine is warming up resistance drops and once within range, the amount of voltage that is allowed through will trigger a signal to the relay and presto, on come the fans. Once the engine cools down via the fans(s), resistance increases and they turn off. It continues this cycle as the engine is running. I would look at the fan relays first. jimvbell The code is P0482.. What is the best way to test the relays? Tomcal
First, Check to make sure you don't have A/C turned on. This will turn on fan instantly.jimvbell OK Swapped them and AC is off.. No Change Tomcal
All right. That rules out it being a relay failure.padroo Information on code P0482
http://www.obd-codes.com/p0482 Tomcal OK, I've looked at the schematics for cooling fan circuit. jimvbell Thanks Tomcal,
It will take me some time to get check this out. This BS called work keeps getting in my way of the important things. I will get back to you as soon as I can. I really appreciate you going out of your way to help...
Thanks again
JimTomcal When you have a chance, the wiring color codes for sensors are as follows;
Dark Blue
Black with Light Blue tracer
Coolant Temp. sensor, two (2) wires;
