Prowler Performance/Appearance Discussion Out with Crap Infinity Door Spkrs, In W/ JBL GX628
Author | Topic: Out with Crap Infinity Door Spkrs, In W/ JBL GX628 |
RADCAT RICH POA Site Supporter Prowler Junkie From:Sugar Land, Texas, USA |
posted 08-05-2023 03:45 PM
Finally got around to replace the Crap Infinity Drivers Door Spkr 6.5 in. Replaced with JBL GX628 , 2.3 OHMS , 180W, Peak 60 wrms Retrofited the Spkr Connector Pins so can use the same door Molex f/m connector . |
CAT-A-TONIC POA Site Supporter Prowler Junkie From:santa clara, california, us |
posted 08-10-2023 05:05 PM
I'm not so sure I'd refer to the original speakers as crap. They were what they were at that time, and they sounded pretty darn good! The foam rings can be replaced and will sound good as new. BUT.....like you, I asked myself, do I replace/fix the originals or do I replace them with something a bit more up to date. T went with a replacement Infinity 2 way. It was close to the factory ohm as well. |
posted 08-10-2023 07:01 PM
Tchootch From:Brandon Twp, MI, USA |
posted 09-02-2023 02:23 PM
I've just replaced my door speakers with JBL Club 6520 speakers. The door speakers had already been replaced once, so weren't in bad shape. I replaced them to match the JBL Club 322F speakers I put in the IP and in the rear bulkhead. The subwoofer was still in good condition, so it stayed. Not easy to find a good new subwoofer that will fit in the available space. The bulkhead mounting is quite shallow and most subwoofers are very large. The IP mount is also quite shallow and the new speakers do touch the body panel underneath the IP. I installed with spacers under the speakers, so speakers don't seal to the panel, but there is sufficient clearance to the top pad still. All these are 3ohm so reasonably matched to the system. |
posted 09-06-2023 07:58 PM
FYI: http://www.prowleronline.com/ubb/Forum1/HTML/026417.html |
All times are CT (US) Top of Page Previous Page | Return to Prowler Performance/Appearance Discussion next newest topic | next oldest topic |
