Author | Topic: Lambo Doors....Long drives |
MellowYellow Prowler Junkie From:Houston, Tx USA |
posted 01-29-2008 02:44 PM
Looking at picking up another Kat for my daily driver. Wondering what problems, if any, folks are seeing with Lambo Doors? Also, my commute is about to be pumped up to 90 miles a day. What other things have Prowler owners done to soften, or make the Kat ride smoother for long (daily) trips? TIA Brian |
Pantera POA Site Supporter Prowler Junkie From:Connecticut |
posted 01-29-2008 03:27 PM
Get a Wonderbar......Makes the ride much smoother ------------------ ProwlerStuff.com |
posted 01-29-2008 03:44 PM
I agree on the Wonderbar plus get a set of non runflat tires - those two changes will make a huge difference inn the ride quality. |
GoldMember Prowler Newbie From:London |
posted 01-29-2008 08:47 PM
I am adding Lambo Hinges to my PT, either the LSD Kit or one made by Vertical Lift hinges, Both of these are 100% bolt on. Autoloc also make Lambo as well however they usually are weld on kit that tend to sag. The Bolt on kits use large gas shocks and I have a seen them react diffently in cold weather. i.e the hinges close more quickly in the cold and become harder to lift. I will post some pics once I get mine installed This message has been edited by GoldMember on 01-29-2008 at 08:54 PM |
ProwlerBobWpg Prowler Junkie From:Winnipeg, Manitoba Canada |
posted 01-29-2008 08:57 PM
What is the wonderbar? |
posted 01-29-2008 09:34 PM
Click on this link. http://www.prowleronline.com/ubb/Forum1/HTML/011003.html If you need more info you can PM Larry Lord or do a search and type in wonder bar and be sure to "check all open forums" |
posted 01-29-2008 09:41 PM
There is a Vertical Door Lift Bolt on Kit on ebay for $2300. I never saw this kit in person however I have seen the PT kit. Here is a link to the Prowler Vertical Lift kit http://cgi.ebay.com/ebaymotors/VERTICAL-LAMBO-DOORS-PLYMOUTH-PROWLER-SCISSOR-DOORS_W0QQcmdZViewItemQQcategoryZ42611QQihZ008QQitemZ180115247657 |
LAwil POA Site Supporter Prowler Junkie From:Southern Calif. |
posted 01-29-2008 10:06 PM
I have the lambo doors by vertical lift and am very happy with it. I really like the way it looks. I have the bolt on kit, and I think is the only way to go.JMO ------------------ |
Top Kat POA Site Supporter Prowler Junkie From:Glen Allen, Va U S A |
posted 01-29-2008 11:08 PM
I have the GT Factory...Diablo Kit. IT IS NOT A BOLT ON, but it offer the best entry and exit of any kit I have seen. My doors go STRAIGHT UP verticle. Not slanted in any way. You don't have to step or duck under the door. I have seen only one of the bolt on kits and for my money prefer the weld on kit. Get what works best for you. ------------------ |
posted 01-30-2008 12:02 AM
Not for everyday use JMO. Love the look on the Prowler |
posted 01-30-2008 12:53 PM
on the wonder bar is it hard to install? do you need to have an alignment on the cat when done? |
posted 01-30-2008 01:16 PM
Fairly easy to install and you do NOT need a realignment. |
posted 01-30-2008 02:11 PM
Mello - Non-runflats. By far the largest improvement in ride quality. |
mist302 Prowler Junkie From:Nashotah, WI USA |
posted 01-31-2008 01:58 AM
posted 01-31-2008 10:06 AM
I should have said it is fairly easy if you have the correct tools. lol The plunger is key. |
GOATFALLS POA Site Supporter Prowler Junkie From:OK. 74070 |
posted 01-31-2008 01:32 PM
quote: and putting it on the right car would help too..... |
Melissa Santory Prowler Enthusiast From:North Grafton, MA |
posted 02-01-2008 02:11 PM
I have to agree with Marty and the others. Ours is a daily driver, and when I take it, it's about 70 miles round-trip per day. We also have the Wonderbar and non-runflats. It will never feel nor handle like a "regular" car, but those two things have definitely helped. |
All times are CT (US) Top of Page Previous Page | Return to Prowler Performance/Appearance Discussion next newest topic | next oldest topic |
