Technical Questions & Answers fuel pump replace in Des Moines area
Author | Topic: fuel pump replace in Des Moines area |
Mike Downey POA Site Supporter Prowler Junkie From:Ankeny, Iowa, United States |
posted 02-20-2024 04:34 PM
looking to replace fuel pump around Des Moines. thanks |
posted 02-20-2024 07:29 PM
First you will need a fuel pump. Here is the link to Tom Mills site. http://www.plymouthprowlerparts.com/ Are you going to change it or have it done. |
posted 02-21-2024 07:44 AM
don't know if I will attemt it myself or have it done, Looked at video from john in Denver. fuel dripping on floor when car is running. any idea of labor cost to hire it done |
WildCat POA Site Supporter Prowler Junkie Personal ScrapBook From:Oldest kid in the neighborhood..... East side Indy, Indiana, USA |
posted 02-21-2024 08:41 AM
quote: I changed mine 16-17 years ago Not hard to do & most DIY people can follow the instructions & do in hour or so. If you’re not comfortable doing it then find someone who is. While changing should check all rubber lines to insure they are still in good condition Should be plenty of info here on changing the fuel pump ------------------ |
ALLEY CAT POA Lifetime Site Supporter Prowler Junkie From:mesa, Arizona, USA |
posted 02-21-2024 09:17 AM
Hi Mike,,,, retired by now? Been a long time since we chatted.. .
Pick some to call and ask if they are familiar with replacing the fuel pump in Chrysler products....maybe a Prowler or Viper to see if they have worked on these types of cars. But first, do as WC said,,,check for a hose leak instead of a fuel pump problems. Good luck,,, ------------------
posted 02-21-2024 05:21 PM
Larry I retired 15 years ago. Living in Iowa still but now in Des Moines suburb. will check fuel hoses first Good to hear you are still going strong ------------------ |
HelRaiZer POA Site Supporter Prowler Junkie From:Pahrump, NV, US |
posted 02-23-2024 06:48 PM
Fuel Pump Replacement Video |
Tom Mills POA Site Supporter and Vendor Prowler Junkie Tom Mills / Prowler Parts www.plymouthprowlerparts.com From:Niles, Michign, USA |
posted 03-13-2024 07:23 PM
quote: This video is an example of making a simple job into night mare. A lot of un necessary work. We have a complete pump assembly that is a simple drop in replacement. Basically remove the pump retainer ring and disconnect the fuel lines and wiring and pull the pump out and install the new one. They are taking the pump assembly all apart to replace the pump in the canister which is a big job. Email me and I can send you the instructions. jeffersonauto@earthlink.net http://www.plymouthprowlerparts.com/ This message has been edited by Tom Mills on 03-13-2024 at 07:25 PM |
