Prowler Products By Gary Tom Mills - Plymouth Prowler Parts
  Technical Questions & Answers
  Fixing a Weekender and a Waterfall storage tote
Author Topic:   Fixing a Weekender and a Waterfall storage tote
Stray Cat
posted 09-13-2023 09:26 AM     Click Here to See the Profile for Stray Cat     send a private message to Stray Cat   Edit/Delete Message   Reply w/Quote   Search for more posts by Stray Cat
Hi all,
I explained to Steve that my Weekender is a Gen 1 and that the male piece that inserts into the hitch receiver is hollow. That means that this Weekender is not stable on the back, it wobbles like crazy. I have a U-Bolt I need to find that came with it and is supposed to lock it down. Problem is it is very weak and you actually crush it by tightening it enough to stabilize the Weekender. If I remember correctly, Bob later put a solid piece on these with threads to allow you to completely tighten it down.
Also, I have a used Waterfall tote that has snaps at the top. Were there snaps that had to be installed on this version? I remember my old one had hooks I believe that wrapped around and hooked into the cardboard back on top of the Waterfall. Also is missing a clip I believe would allow you to attach it..... where? Anyone know these issues?
Thanks,
John
alrtg
posted 09-13-2023 11:40 AM     Click Here to See the Profile for alrtg     send a private message to alrtg   Edit/Delete Message   Reply w/Quote   Search for more posts by alrtg
http://www.xrack.us/product/anti-rattle-5-8-threaded-hitch-pin-with-nut-insert/
Listed as "Anti-Rattle 5/8″ Threaded Hitch Pin with nut insert"
Stray Cat
posted 09-13-2023 07:55 PM     Click Here to See the Profile for Stray Cat     send a private message to Stray Cat   Edit/Delete Message   Reply w/Quote   Search for more posts by Stray Cat
Interesting. That looks like a potential solution. Except it says for 2" hitch. These are 1 1/4. Thoughts ?
John
WildCat
From:Oldest kid in the neighborhood..... East side Indy, Indiana, USA
posted 09-13-2023 09:23 PM     Click Here to See the Profile for WildCat     send a private message to WildCat   Edit/Delete Message   Reply w/Quote   Search for more posts by WildCat
John
Actually mine has threaded bolt thru it
You could get correct size nut and bolt to bolt it on
Get a coupler nut, cut to fit snug inside tube and bolt it in place & get welded inside the tube then remove bolt and install on car using bolt will make it tight
Mine is a pain because it has to be threaded all the way through but since it stays on car not a big deal
WildCat
posted 09-13-2023 09:27 PM     Click Here to See the Profile for WildCat     send a private message to WildCat   Edit/Delete Message   Reply w/Quote   Search for more posts by WildCat
John
Here you go
After my post googled it
Stray Cat
posted 09-14-2023 06:49 AM     Click Here to See the Profile for Stray Cat     send a private message to Stray Cat   Edit/Delete Message   Reply w/Quote   Search for more posts by Stray Cat
Thank you! I'll check it out, that 1/2 inch hole is correct ? I'll check. This would be a great fix if it works. This is what I have but it is very thin and weak.
[URL=http://www.harborfreight.com/anti-rattle-hitch-tightener-58134.html?utm_source=bing&utm_medium=cpc&utm_campaign=425671834&campaignid=425671834&utm_content=1159985793876197&ads etid=]http://www.harborfreight.com/anti-rattle-hitch-tightener-58134.html?utm_source=bing&utm_medium=cpc&utm_campaign=425671834&campaignid=425671834&utm_content=1159985793876197&ad setid=[/URL] 1159985793876197&product=58134&store=211&msclkid=40f21d7158aa1686e8957873ab8377d7
John
This message has been edited by Stray Cat on 09-14-2023 at 06:50 AM
tbonelynch
posted 09-14-2023 03:54 PM     Click Here to See the Profile for tbonelynch     send a private message to tbonelynch   Edit/Delete Message   Reply w/Quote   Search for more posts by tbonelynch
This is how I keep mine from wobbling and I leveled it to match the car. A couple of stainless turnbuckles and stainless eyebolts.
Stray Cat
posted 03-01-2024 02:21 PM     Click Here to See the Profile for Stray Cat     send a private message to Stray Cat   Edit/Delete Message   Reply w/Quote   Search for more posts by Stray Cat
That looks like a good fix - I apologize, just now saw that !
Thanks all and tbonelynch!
John
mslc10
posted 03-10-2024 08:03 PM     Click Here to See the Profile for mslc10     send a private message to mslc10   Edit/Delete Message   Reply w/Quote   Search for more posts by mslc10
In the past I have drilled a hole in the hitch receiver then threaded the hole to accept a bolt to use as a ‘snubber’ that when tightened it pushes the ‘hitch’ and keeps it from rattling.
Stray Cat
posted 03-11-2024 07:27 AM     Click Here to See the Profile for Stray Cat     send a private message to Stray Cat   Edit/Delete Message   Reply w/Quote   Search for more posts by Stray Cat
Thank you!
John
