Technical Questions & Answers LED HEAD LIGHTS AND DASH LIGHT CONVERSION (Page 1)
Author | Topic: LED HEAD LIGHTS AND DASH LIGHT CONVERSION |
BrianP1999 From:BUFORD, Georgia, USA |
posted 06-01-2021 07:47 AM
I convert all my lights to LED, I took it out this weekend at night and very very happy with it. Very easy installation. For head lights low and high beam same 9005 bulbs. Dash T10 Cool blue. |
A2H POA Site Supporter Prowler Junkie From:Menomonee Falls, Wisconsin, United States |
posted 06-01-2021 01:54 PM
That's really nice. I also just upgraded the headlights to LED (i followed your advice on which brand to use). For the dash lights: how hard is it to replace them and if not something really hard, where did you buy the bulbs and how many do you need ? Also, are the Cool Blues the same color as original or are they different ? |
posted 06-02-2021 08:58 AM
quote: The dash light is easy to replace but takes about an hour. Buy any T10 LED bulbs on Amazon. I used Cool Blue which is a bit lighter and brighter. You will need 6 of them. This message has been edited by BrianP1999 on 06-03-2021 at 08:34 AM |
posted 06-02-2021 09:53 PM
Thanks. Will think about doing that. As you say it looks complicated but after reading a few posts is not as much. |
tbonelynch POA Site Supporter Prowler Junkie From:Fayetteville, GA, usa |
posted 06-24-2021 12:25 PM
I like the cool blue dash lights. Would look good in the Mulholland Blue dashboard. Do they dim with the knob? Also, what brand headlamps did you buy? There are so many different manufactures, and some are good in one car, but not in another. All of the car's headlights are shaped differently and the reflectors react differently to the placement of the LED's on the shaft of the bulb. Reading the comments on Amazon will confuse you. Just wanted to know your opinion on the ones that you bought. Thanks for sharing. |
posted 06-28-2021 01:48 PM
quote: search on amazon for Zoncar 9005/hb3 led bulbd 15000LM 6500K xenon white. It is 50% off now from $30. It is bright at night especially high beam, so bright that I could see far and far away. As for the dimming the dash light, I haven't try it yet because I love the brightness. |
posted 06-28-2021 04:52 PM
Thanks for that info. I just ordered 8 bulbs. http://www.amazon.com/ZonCar-Headlight-Halogen-Replacement-Extremely/dp/B081YVL3CB/ref=trb_chk_auth?dchild=1&keywords=zoncar+9005%2Fhb3&qid=1624916330&sr=8-4&openid.assoc_ |
metschers POA Site Supporter Prowler Junkie From:Billings, Missouri , USA |
posted 07-07-2021 06:17 PM
BrianP1999, Thanks for the info. I just got mine installed…Wow you’re right, they’re amazing. FYI….when I was installing both top covers, I was having problems getting some of the screws to start. Then I realized that some of the screws are different.There are some of the screws that are pointed and some that have blunt ends. After I figured out the blunt end screws go into the plastic and the pointed screws go where there are metal “J” clips, problem solved. Thanks again, Sm |
SteelCityProwler POA Site Supporter Prowler Junkie From:Greenville, OH, USA |
posted 07-08-2021 09:05 AM
quote: I ordered these as well. They look like a quality, well put together light. Easy installation and they really look great. I'll admit, I am a little gun shy because I'm scared of the heat these will put off. They have built-in fans which is great, but I've still heard some horror stories of LED's melting wiring harnesses. Thoughts? ------------------ |
posted 07-08-2021 09:44 AM
I have used LED in just about anything and in all my cars, boats. Never have a problem. These shouldn't have as much heat as halogen bulbs, in fact it is much cooler.
posted 07-16-2021 07:10 PM
I finally got around to installing 4 of them in the '97. I am impressed by how bright they are BUT it is still daylight here so I expect I will be more impressed in another couple of hours. Thanks again for posting the info. I really appreciate. The hardest part of the install is getting your hands inside such a small place. They even furnish gloves so you don't touch the bulb. I should have bought 12 of them instead of 8, I think. |
posted 07-16-2021 10:55 PM
After dark I discovered I need to align my lights a bit, especially the passenger side. They are a whole lot brighter for sure. No one flashed their lights at me, but I wasn't in much traffic. So I guess they are not obnoxious. |
posted 07-19-2021 09:06 AM
Ed, have you try your high beam yet? I think you will like it. I can see 1/2 mile away. Brian
posted 07-19-2021 01:04 PM
I really haven't driven it at night. In the garage it is really a totally diff. look. I tried adjusting it in the garage and I think I have it now. What are the little white square pieces of (tape?) for? I need to re-read the instructions before I do the next one to see what I missed. |
posted 07-19-2021 01:50 PM
I don't recall any piece of white tape but then again I didn't read the instruction either. It was just plug and play. I doubt it is that crucial. I enjoyed cruising in the evening and at night now. Brian
posted 07-20-2021 02:56 AM
We took a ride tonight, right at dusk and into the night. HUGE difference for sure. Sandy said she was seeing signs that she had never noticed before. I should have bought more. They will fit her PT, also. |
onecatnodog From:Arvada, CO, United States |
posted 07-21-2021 03:23 PM
Just my opinion and experience with the LED Bright as heck lights.. I have changed several back to stock and yes there is a big not as bright look when you go back to stock.. Just a couple of issues that I have run into was that if you are in a group of Prowlers on a cruise at night. The guy with the bright lights will drive you nuts in your side mirrors as they are for sure bright if he is behind you even if they are adjusted correctly. You should run out front with you Prowler with these lights and be the front car if you have them.. If you are coming towards them in traffic they are also blinding..(again my opinion) When a car is behind you, you can block some of the new bright light from the review mirror by using the night/day angle on the mirror but not from the side mirrors. Also noted that some of the plastic around the bulbs (the back side connecter) as that is were the heat is on LED bulb. It's on the plastic plug side, not on the bulb side. I noticed them breaking down, melting the bulb socket and even the wire covers were noted with the crusty feeling.. Easy test is to put the new bulb in and hold the socket at the plastic side and check the heat after 15 min before you instill them in the car.. LED lights use much less battery power so it will have little effect on draining the battery. Also the LED light is more of a straight beams of lights and it's critical that they are not adjusted to high as you can really see the signs on the highway down the road or two low and shining on the ground to close to the car and you are out driving them at speed.. Factory lights are more forgiving on adjusting them. Now maybe things have changed in the industry since then with these bulbs. It was about 6 years ago when I changed the last ones out.. It may not be a issue now with the extra heat coming off of the back side of the bulb. But you can check it easily.. Again this is just my opinion and what I have found.. John(onecatnodog) |
posted 07-21-2021 04:38 PM
To expand on that a little, I think the Prowler sits so low that a lot of the lights look to be much brighter than they appear to be when I am in other cars. But I agree with almost everything OneCat just posted |
PROWLEN From:Vancouver , WA, USA |
posted 08-03-2021 07:25 PM
I too have purchased the ZonCar 9005/ HB3 LED headlamp bulbs and installed them in my 2016 Ram Sport to try them out. Ordered another set for the Prowler, my original intention, but drive the Ram more than the Prowler so tried them there first. Great look and light output with the projector headlamps but still have the same concern as with the Prowler. My concern being with the Prowler like others is the amount of heat the LED's put out even with the built in cooling fan. 15,000 LMs has to be generating a lot of heat. Thinking they are enclosed housings so just blowing hot air around? But hopeful they'll work okay and giving them a try. 20 years ago I upgraded the bulbs in the Prowler and melted my wiring harness so very leery about trying something new. So I realize its only been a matter of weeks since some of you have installed this same ZonCar LED bulbs and may not have much night driving time in yet, but my question for others here that are running the same lamp, have you had any issues yet? Unless you smell melting plastic you may not know there is an issue unless you open the housing and check your harness and plug connections for damage before a complete melt down. Fortunately the headlamps had a short pigtail that melted and not the entire harness and was a fairly easy fix 20 some years ago. May not be so easy to find those pigtails now days. So my other concern with the LED's and the projector housings is the clocking of the bulb. Does it matter in a projector housing that has a dome type reflector? They suggest clocking at 3 and 9 o'clock, plus aiming not to blind the other guy. In my Ram they were not adjustable and installed at 12 and 6 o'clock in the projector housing. After a ton of research and height adjustment they appear to have a normal uniform beam pattern with an even cut-off line. They light up the road nicely with a good throw and no one has flashed me. Hoping for the same with the Prowler's projector housings. Any feedback on the wiring harness issues as time progresses with your new bulbs or clocking thoughts with LED's in a projector housing appreciated. Thanks! ------------------ PROWLEN.... John |
posted 08-03-2021 08:07 PM
I have driven VERY little with the lights on, not many miles in total really, on that Prowler. Sorry to not be of any help. I don't think you can change the positioning. There are three tabs and slots, only one way to put them in unless you do some extra work but I didn't look into that. |
posted 08-04-2021 08:39 AM
Here is my opinion for what its worth. I replaced LED virtually every car I own from headlights to interior lights. I haven't had any issue except some not so good died prematurely but that is easy fix. I have not experience any melting or heat issue. LED technology nowadays is way far more advance than 20 yrs ago. As far as blinding other drivers, most cars now have LED lights so one more prowler won't bother them lol. |
posted 08-07-2021 03:01 AM
No! Sorry but I must disagree on the use of these ZonCar 9005/HB3 light-bulbs in the Prowler. I had high hopes for these lamps based on the many positive reviews and believing that the technology had came a long way in the past 20 years as well. The specs are impressive, and they look great on paper. What's not to like? They are awesome, bright white and really give a modern updated look to the Prowler. The before and after comparison is night and day. I was loving them. As previously mentioned, I installed these in my 2016 Ram Sport projector headlights a couple of weeks ago as well. 9005's in both low and high beams. Look great and the high beams are awesome on dark country roads. The great specs and compact size being the attractive features for the Ram, being able to fit them under the dust covers with no modifications, plug and play is great. Finally a bulb that fits. Now I'm concerned about those as well. Like the Prowler, the Ram has sealed projector beam housings with no ventilation. But the lamps have the turbo cooling fans and should be fine?? Will maybe, I'm still monitoring them. So, here's my experience with the Prowler after the installation last night. I installed these in the low beams only and was quite impressed with the difference and the look. Awesome I'm thinking. I do a brief check on the garage door for beam pattern and height adjustment. It appears a touch high but anxious to road test and decided to drive around the Lake. Less than 2 miles. I had idled in the driveway for about 5 minutes and stopped at the park for some quick photos, idling another 5, and back to the garage. Before calling it a night I feel the tops of the headlight housings. Wholly crap, the top painted surfaces of the housings are piping hot. Not just warm but uncomfortably hot. I pop the hood and feel around checking for temperature and heat dissipation. The black headlight covers are extremely hot above the low beam bulb locations and the covers screw heads are nearly burning hot to the touch! I expected some heat as normal with the Prowler, but my alarm bells are going off as "not good" and uncomfortably warm for such a short test drive. Maybe they would be fine long term, but my common sense is telling me to remove these hot puppies before any damage occurs. Thinking a longer drive down the Interstate could lead to a disastrous meltdown! I don't do much night driving so I'll leave them in a while longer and reassess them, but pretty sure they have to go, or move them over to the high beams. Also, on the Prowler low-beams, what I thought to be aimed a little high on the garage door was actually disappointing output on the road. Only a couple of car lengths illuminated ahead with the feeling they were aimed too low. I will experiment with aiming but thought they were dialed in pretty close. I did like the cool blue led dash lights and followed suit. Very cool look. Quite a process getting to them, but doable with some patience and finesse. The tachometer took a special bulb and the foot wells illuminating cool blue add a nice touch. For now, as much as I love the look of these LED headlights, I would not recommend them for the Prowler. Also, important to note ZonCar's fitment guide for the Prowler are for high beams only on Amazon's site. Same for the Ram. Maybe some LED's with less wattage and lumens wouldn't get so hot, otherwise back to some premium halogens soon. This message has been edited by PROWLEN on 08-07-2021 at 03:16 AM |
posted 08-07-2021 11:01 PM
I have looked for over a week on and off for the melted headlight images that I have but have had no luck in finding them. You guys probably don't drive your cars much at night like you said, but when I ran the Mile Hi Prowler club it wasn't uncommon to do Trail Ridge Road once or twice a year and sometimes it required us to have our lights on for 3 hours at a time to get home in the dark.. Then there are times when we would all go to event's held in other states and you really are using the lights to get super long travel times in.. Again this is just my opinion, and what I have experienced.. John(onecatnodog) |
posted 08-08-2021 12:33 AM
Thanks for the feedback Prowlen. I need to re-asses the situation, I guess. |
posted 08-08-2021 12:49 AM
Sweet engine! |
