Technical Questions & Answers Ball joints rubber boots . fuel pump. Overheat . Update!!
Author | Topic: Ball joints rubber boots . fuel pump. Overheat . Update!! |
viper&prowler soul Prowler Enthusiast From:Jeddah , Jeddah , KSA |
posted 05-01-2020 09:54 PM
Hi guys I just installed new ball joints before one year ago .. From prowler Store ( The new design ) so I have a crack now on rubber boots ( The new one less than 500 miles of drive after installed ) What can I do for fix that problem ? Notes: very small crack Q2 : my car now it has 50,000 miles .. So what kind of maintenance needed ? Q3 : are there any location should be grease it In the car more than ball joints ? Thanks for all Update !! This message has been edited by viper&prowler soul on 06-06-2020 at 08:33 AM |
posted 05-02-2020 12:04 AM
Tip # 1, don't buy crap from the Prowler Store. It is over priced, lower quality and their return policy is basically non-existent. The only grease fittings are on the wheels. The anti freeze lubricates the water pump so that should be changed if it is old. The timing belt may be about due to be changed but most of them seem to be doing really well. you are much better off buying stuff here on POA than dealing with the Prowler Store, seriously. |
posted 05-02-2020 01:02 AM
Thanks Ed Actually this is the first time I buy from Prowler store .. & The last ! For example I get my new aluminum radiator from superior Company but I did not install it yet ..for 450$ only And another thing .. my fuel pump working excellent . The only problem It has Broken on the top but I fix it temporary .. Do you know from where I can get one whole assembly ? Or the top hat ? This message has been edited by viper&prowler soul on 05-02-2020 at 01:16 AM |
posted 05-02-2020 04:41 AM
For a new fuel pump assembly visit the site of one of our members, Tom Mills, he sells an excellent replacement pump. Last item on the list. https://jeffersonautocollision.com/prowler-parts/ This message has been edited by kees on 05-02-2020 at 04:43 AM |
posted 05-02-2020 09:03 AM
Thanks Kees .. I will contact with him now |
posted 05-02-2020 09:49 PM
I doubt if you have a bad head gasket. Start with the simplest thing, the cheapest fix and if that doesn't work, go to the next easiest thing. Probably a bad thermostat, but the radiator may have been partially clogged. The cars are about 20 years old so if it was not maintained, it may have had some gunk in it, for sure. Good luck. Go with the Tom Mills fuel pump fix. Many satisfied customers over the past few years. |
posted 05-03-2020 07:10 AM
Don't overlook your radiator cap. A pressure test on will let you know if it needs to be replaced. It was a simple fix for me years ago. |
posted 05-03-2020 10:46 AM
Prowlers have a problem with trapped air. There is a procedure in the service manual telling you how to get the air out of the system and it is easy to do. Good luck with your Prowler. |
posted 05-05-2020 12:02 AM
MIKE. padroo .ed .kees Thanks for all of you guys . |
posted 05-05-2020 03:26 PM
I've had owners with over-heating issues tell me that they've bleed the air out of the system yet I typically find air trapped in the cooling system. I see that you're in the middle east. Make sure that you're using the stock grill and try removing the rubber seal at the back of the hood at the cowl. It will help exhaust some hot air. |
posted 05-05-2020 07:06 PM
Good point Bob There is a bleeder valve on top of the engine, front middle of the car. |
posted 05-07-2020 04:59 AM
Thanks Bob & Ed I did the bleeding steam system .. And I found out I have just 1 speed radiator fan (High) . It works when the heat reaches half. And the low speed does not work.. what should I do ? |
posted 05-07-2020 07:40 AM
quote: Check for loose wiring at the fan connection. Check relays to see if the low speed relay is bad. You can swap the low with the high and turn on the AC. The fan should be on when the AC is on. Relay panel is located under the side panel on the driver's side. The relays are the same so moving them around shouldn't be a problem. If that doesn't work, the low speed part of the fan motor or the temperature sensor may be bad. If you don't have the manual for your Prowler, you can find them for sale here on POA. This message has been edited by LSK on 05-07-2020 at 07:46 AM |
Tony Goertz POA Site Supporter Administrating Kat Personal ScrapBook From:Lucan, Ontario, Canada |
posted 05-07-2020 11:59 AM
Quick easy test to see if fan motor is OK... Pull both fan relays - jumper the relay socket with a test wire. One socket at a time. Fan should run each time. Use a heavy wire as the fan draws a lot of power. If both times fan runs - swap the fan relays with the other two relays - (fuel pump and starter). You will know right away if a relay is bad. |
posted 05-09-2020 03:09 PM
Thanks... Lsk & Tony I will test, and tell you the results... |
posted 05-19-2020 04:58 PM
Did you solve the problem? |
posted 05-20-2020 02:16 PM
Hi Ed No not yet because of quarantine .. after 10 days From now All the workshops they will open .. and I know one technician guy (. The appointment has been reserved). I will let him to do all the steps in This page . And after that I will update you & everyone .. and I will try to post some picture . Thanks for your interest |
posted 05-20-2020 09:25 PM
Good luck, hope they get you fixed up in just one trip. Let us know how it goes. |
posted 06-06-2020 08:34 AM
Up |
posted 06-07-2020 07:23 AM
Thanks for update in first post. Good to hear your back on the road. |
posted 06-08-2020 08:21 PM
