Technical Questions & Answers Speed output sensor signal - gears
Author | Topic: Speed output sensor signal - gears |
posted 10-22-2018 12:56 PM
The Electronic Ratio Adapter (ERA) Box has stopped working on my 1997 Prowler. I initially thought it was the transmission output sensor that went bad, but I removed the ERA box and reconnect the speed output wire back to factory input on the TCM (Trans Control Module) and the speedometer work great; it's fast by 27%. I bought a replacement ERA Box from Abbot and I cannot get the signal to work. Speedometer is not working; 4v and 3 ohms comes from the trannys output sensor, 13.8v coming to the ERA Box, box is grounded to the negative terminal on the battery. 0 volts & 3 ohms on the output wire. I have since removed the new ERA box and put back factory wire and the speedometer works; it's just off by 27%. If someone can provide any insight on this issue I would greatly appreciate it? |
posted 10-22-2018 01:55 PM
Maybe they can offer some help here. http://www.bobsspeedometer.com/1/120/ratio_adapter.asp Here are the specs for the G force gears. I know you have Pro gears!!!! Engine rpm at any given speed will be 27 % higher with G-Force gears installed This message has been edited by robin on 10-22-2018 at 01:57 PM |
posted 10-22-2018 02:09 PM
Try toggle ALL the DIP switches in the ERA to make sure none are stuck half way ON - OFF . Double check the 4 dip bank as well - both switches are marked which way is ON (1). |
