Author | Topic: Air Filter |
JH POA Site Supporter Prowler Junkie From:ST. Pete Beach, Florida USA |
posted 08-07-2018 12:51 PM
Does anyone know of a video on how to change the Air Filter without taking off the side panel? |
posted 08-07-2018 01:31 PM
shows both http://www.youtube.com/watch?v=0uGhP-UEKCg
This message has been edited by robin on 08-07-2018 at 01:32 PM |
koolkty POA Site Supporter Prowler Junkie From:Oxford, MI, United States |
posted 08-09-2018 05:27 PM
After watching the video, if you have a lift so you can easily work under the car, then maybe you could do this without removing the side panel. But if only lifted on jack stands I think this would be a lot more difficult especially if it is your first time doing it. Mine still has the original filter but I only have 7500 miles on it. Planning to try replacing the filter before I prep it for winter. This message has been edited by koolkty on 08-09-2018 at 05:28 PM |
posted 08-10-2018 09:28 AM
I just changed mine and drove up my ramps and was able to go underneath and change it |
posted 08-16-2018 06:28 AM
Thanks Guys. My garage guy had it on the lift and tried to remove without taking off side panel but was unsuccessful. Guess I will give him your thoughts and see how we go forward. Thanks again. |
posted 08-16-2018 07:43 AM
Why don't you want to remove the side panel? Not criticizing, just curious. |
posted 08-16-2018 08:45 AM
I don't think removing side panel helps. |
posted 08-16-2018 11:54 AM
While yes you can jack the car up and get to the filter, what, three bolts and the panels off!! Not only that, once off the filter housing is right in front of you. And here's one other thing that you'll get out of taking the panel off. And that's you're being able to inspect all the surroundings for any potential problems that with the panel on you can't see all that well,or at all. Either way!! |
posted 08-16-2018 06:06 PM
Pulling the panel made it very easy on my 97. Don't know how later models are. |
prowlerstud74 Prowler Newbie From: |
posted 08-18-2018 07:19 AM
Hello. I just did mine so I can put the modified air filter. I did not jack the car up but I did have to remove the side panel. If you do not remove the side panel it would be a big pain. The side panel is super easy to remove. 3 Screws and its out. |
posted 08-24-2018 03:20 PM
Thank you. |
