  Technical Questions & Answers
  Air filter
Author Topic:   Air filter
JH
posted 06-23-2018 11:14 AM     Click Here to See the Profile for JH     send a private message to JH   Edit/Delete Message   Reply w/Quote   Search for more posts by JH
Hi everyone,
Can you advise where to purchase the air filter for a 99?
quincy
posted 06-23-2018 11:29 AM     Click Here to See the Profile for quincy     send a private message to quincy   Edit/Delete Message   Reply w/Quote   Search for more posts by quincy
Hi JH,
Pick up a Purolator 'Pure One' part number PA23465.
Most name brand, large auto parts stores will carry it. Or, try Amazon / online. Good luck with the install, its a bit on the difficult side but doable. Don't loose or mix up the shims under the 10 mm bolts that hold the fender on. The passenger fender must be removed for access to the air box.
CAT-A-TONIC
posted 06-23-2018 12:55 PM     Click Here to See the Profile for CAT-A-TONIC     send a private message to CAT-A-TONIC   Edit/Delete Message   Reply w/Quote   Search for more posts by CAT-A-TONIC
I got a K&N years ago and it's still in place. Not sure if they still make that one!
quincy
posted 06-23-2018 05:07 PM     Click Here to See the Profile for quincy     send a private message to quincy   Edit/Delete Message   Reply w/Quote   Search for more posts by quincy
You still have to remove, wash, air dry, then oil those types of filters every 2 years. I run the Fram Air Hog...
This message has been edited by quincy on 06-28-2018 at 01:34 PM
BradleyG
posted 06-23-2018 05:51 PM     Click Here to See the Profile for BradleyG     send a private message to BradleyG   Edit/Delete Message   Reply w/Quote   Search for more posts by BradleyG
Originally posted by quincy:
Hi JH,
I was able to change mine with only removing the right engine panel. Did not have to remove the fender.
401KAT
posted 06-23-2018 08:24 PM     Click Here to See the Profile for 401KAT     send a private message to 401KAT   Edit/Delete Message   Reply w/Quote   Search for more posts by 401KAT
raise vehicle ...slip under pass side...u can remove and replace without taking any panels off...easy 10 min job...jim
quincy
posted 06-24-2018 01:20 PM     Click Here to See the Profile for quincy     send a private message to quincy   Edit/Delete Message   Reply w/Quote   Search for more posts by quincy
Opps....correct. Engine panel. NOT the wheel fender.
Thinking the Prowler was a conventional vehicle for a moment. It also helps to remove one 10 mm bolt holding the air box to the frame so you have a bit more movement and clearance to maneuver in the tight area. I find it's best to lay down on a old carpet. Kneeling is really tough these days.
JH
posted 06-26-2018 08:11 PM     Click Here to See the Profile for JH     send a private message to JH   Edit/Delete Message   Reply w/Quote   Search for more posts by JH
Thanks Guys! Looks like Purolator is the one.
Thanks again.
