  Technical Questions & Answers
  door panel inserts
Author Topic:   door panel inserts
toocool
Prowler Newbie
posted 06-19-2018 12:23 PM     Click Here to See the Profile for toocool     send a private message to toocool   Edit/Delete Message   Reply w/Quote   Search for more posts by toocool
Getting ready to install the door panel inserts I purchased last year and wondering what other's results were. Happy with them ? Installation tips ? Do they stay attached well ? Appreciate any insight.
kayaksrfr1069
posted 06-19-2018 02:44 PM     Click Here to See the Profile for kayaksrfr1069     send a private message to kayaksrfr1069   Edit/Delete Message   Reply w/Quote   Search for more posts by kayaksrfr1069
They say the doors need to be 100% perfectly clean for that 3M tape to work, I used alcohol to clean the mounting area and they still did not stick, the tape either came off on the door or from the insert itself. I wound up stripping them off, cleaning the tape off and using construction adhesive to attach... Havent had a problem since.
This message has been edited by kayaksrfr1069 on 06-19-2018 at 02:44 PM
alprowl
posted 06-19-2018 03:52 PM     Click Here to See the Profile for alprowl     send a private message to alprowl   Edit/Delete Message   Reply w/Quote   Search for more posts by alprowl
I had the same problem with mine last year after I had them wrapped for a color change...tried 3 different types of tape...finally used a silicone sealer, still solid as a rock!
mslc10
posted 06-19-2018 09:26 PM     Click Here to See the Profile for mslc10     send a private message to mslc10   Edit/Delete Message   Reply w/Quote   Search for more posts by mslc10
I used what came with inserts ,no problem yet. apply the inserts from top down, so that any imperfections in size will be on bottom ,out of sight.
kayaksrfr1069
posted 06-19-2018 09:31 PM     Click Here to See the Profile for kayaksrfr1069     send a private message to kayaksrfr1069   Edit/Delete Message   Reply w/Quote   Search for more posts by kayaksrfr1069
Also let me add that using construction adhesive (or silicone sealer as alprowl suggested) will allow you to reposition the insert to exactly where you want it... Once its in place, use painters tape to hold it in place for 24 hours. with the 3M, once its stuck its stuck, and if you find you have to pull it up to adjust it you'll weaken the tape's adhesion.
This message has been edited by kayaksrfr1069 on 06-19-2018 at 09:32 PM
toocool
Prowler Newbie
posted 06-22-2018 04:39 PM     Click Here to See the Profile for toocool     send a private message to toocool   Edit/Delete Message   Reply w/Quote   Search for more posts by toocool
Thank you all for the insight and application tips. Just what I was looking for. Hoping the supplied tape works as advertised. Curious as to how many owners have made this cosmetic mod to their cats.
Thanks again.
