Author | Topic: Speaker problem is back |
Rayman Prowler Enthusiast From:Munich / Germany |
posted 04-16-2018 02:32 AM
Hello everyone. I was in this season again for the first time on the road. everything was fine.at a road unevenness a chirping noise came from the front speaker passenger side. When I switched the radio off and on it was gone again until the next rough road.I replaced the capacitors last year. I am grateful for any idea. Thanks |
posted 04-16-2018 08:19 AM
Here are some ideas from the past. http://www.google.com/search?q=radio+noise+site%3Aprowleronline.com&rlz=1C1CHFX_enUS573US573&oq=radio+noise+site%3Aprowleronline.com&aqs=chrome..69i57.11813j0j8&sourceid=chrome&ie =UTF-8 This message has been edited by padroo on 04-16-2018 at 08:20 AM |
posted 04-16-2018 11:11 AM
is it the front upper dash speaker? If it is make sure you line the hole with some foam so the wire or the connection isn't touching anything. |
posted 04-17-2018 12:35 PM
@ padroo. thanks for the compilation.I'll read it maybe I can find a solution. @ Robin |
posted 04-17-2018 01:24 PM
Removing the dash board is no big deal. It does take some physical force, especially the first time. You need to really give it a good pull but you will get it out without breaking anything. Re-installing it you have to watch for the trip odometer but it is still really a simple procedure. |
posted 04-17-2018 01:40 PM
Thanks ed monahan. that encourages me.I will check the upper right Speaker. |
posted 04-17-2018 02:03 PM
http://www.facebook.com/ProwlerCar/videos/1738478156209844/
This message has been edited by robin on 04-17-2018 at 02:16 PM |
posted 04-19-2018 12:46 PM
Hey @ all I removed the Dashboard today to search for the cause loudspeaker chirping. Roman |
posted 04-19-2018 04:27 PM
touching is not good..just put a little spacer at the bottom foam . an maybe around the speaker it self and if they are still functioning you should test that . This message has been edited by robin on 04-19-2018 at 04:28 PM |
posted 05-06-2018 01:12 PM
I've swapped the dashboard speakers, now everything is fine The speaker has no contact now betweenMagnet and sheet metal Body. Thanks again for your help Roman |
chasgriffith POA Site Supporter Prowler Junkie From:Irving TX USA |
posted 08-19-2018 11:30 PM
What dash speakers did you go with?. I was just searching and saw infinity, kicker and pioneer, jbl. Price for all range about 35 to 50 bucks for the pair. I was passing by a Best Buy Saturday and thinking that might have something, but they don't carry any. |
posted 08-20-2018 02:18 AM
Hello chasgriffith
https://www.amazon.de/Lautsprecher-87mm-2-Wege-Koax-System/dp/B004FOSSCY I hope this helps you My speaker problem was a ground problem, the negative pole on the battery had loosened, Rayman |
posted 08-20-2018 10:04 AM
Thanks, I have the dash off due to instrument cluster problem and my front speakers are toast. From the pics it looks like most will work. How many prowlers are in Germany? bet that gets some looks. |
posted 08-20-2018 03:20 PM
with pleasure chasgriffith, the Prowler is very rare here, mine is from Houston TX. my best regards to Texas |
posted 08-21-2018 01:04 PM
Stick with infinity with 2ohm coil. Most will be 4 ohm and you will loose volume in those speakers . I'll look on web Infinity-Reference-REF-3032 This message has been edited by mslc10 on 08-21-2018 at 01:32 PM |
posted 08-22-2018 10:28 AM
How many people have had their speakers go bad when it wasn't the result of a deteriorated foam ring? |
