Author | Topic: drive shaft noise |
cowpie636 POA Site Supporter Prowler Junkie From:Molalla , oregon usa |
posted 12-03-2017 11:36 AM
[I have a noise coming from my drive shaft that is a metallic sound , it is there all the time but louder when in gear . I am thinking about changing out the driveshaft . The Prowler has 14,600 miles on it .Any one else had this problem ? |
posted 12-03-2017 12:10 PM
Have you checked the oil level in the rear bell housing reservoir. The front bearing right off the flywheel is known to go bad and it is a sealed bearing. You need to get the car up in the air with the rear wheels off the ground to get a better idea of what is going on. I would think a driveshaft is rather expensive. The Prowler doesn't use regular universal joints either. |
posted 12-03-2017 12:26 PM
Yes I have checked all 3 oils in rear end and all were full, I have a lift in my barn and have had it on the lift several times and the sound is coming from the middle of drive shaft the best I can tell. . I did buy a used drive shaft from a wrecking yard but it is a major job to change it out , you have to move the transaxle back to get the driveshaft out and need a transmission jack to do so, which h I do not have. It is in a shop getting the timing belt replaced and I may have the shop change it out. |
posted 12-03-2017 12:53 PM
Question . If the front bearing is bad , do you have to pull the motor out to replace it ? |
posted 12-03-2017 01:16 PM
Conversation from the past. has anyone changed the solid rubber spacers on driveshaft, one on the front and the one on the rear? sunbird Prowler Junkie posted 02-12-2003 11:03 PM Click Here to See the Profile for sunbird send a private message to sunbird Edit/Delete Message Reply w/Quote Search for more posts by sunbird The rubber dodads allow the slight misalignment and movement to exist without binding and breaking that would occur with a truly solid connection. KatAddict
posted 02-13-2003 03:10 PM Click Here to See the Profile for KatAddict send a private message to KatAddict Edit/Delete Message Reply w/Quote Search for more posts by KatAddict |
posted 12-03-2017 01:28 PM
Here is another good post you should read through. http://www.prowleronline.com/ubb/Forum2/HTML/004151-2.html posted 01-01-2011 09:36 PM Click Here to See the Profile for BradleyG send a private message to BradleyG Edit/Delete Message Reply w/Quote Search for more posts by BradleyG Normally, as I look for a cause to what is wrong. I suggest to look for the easiest solution first. ((This has once again proved to be the best path to finding the fix)). BUT.. I did not follow my own advice, wasted money and did not drive my Prowler for 3 months. I asked for guidance here.. talked to a few of you, lay under the car while it was on jack stands and running in gear to pinpoint the area making the knocking noise. I concluded that the noise came from from the rear of the drive shaft as this is where I heard it the loudest. I used a rubber hose to listen with and determined the noise was not coming from the engine output shaft or the transmission input shaft, but from the drive shaft its self. It would have been pretty hard to put the hose against the drive shaft while it is spinning.. LOL. Here is a hint of the where the noise was coming from.. Noise can travel down the full length of a shaft and make you believe it is knocking at the back door when it is actually knocking at the front door. Sooo. I decided that the only way to find the problem was to go ahead and remove the transmission back so that the drive shaft could be removed. I was convinced that the drive shaft was bad OR that the transmission input housing holds the problem. These items new are pretty expensive, so I began to look for good deals. I found a wrecking yard which specializes in Vipers to have two wrecked Prowlers for parts, so I bought a drive shaft and just for an "In case" I bought the transmission input housing for $550.00 total.. I saved a lot of money by purchasing the used parts. So here I was.. Parts in hand and took the Prowler to the local Dodge dealer which has a Viper/Prowler technician. My instructions to him were to find the cause and let me know so we could decide what to do. With it on the rack, he could not determine where the noise came from either, so it is time to tear it down (At this point, I left to go to work). First to come off is the exhaust system. GOOD NEWS!! With the exhaust system removed, you can access the drive shaft front rubber coupler. He found the six bolts attaching the drive shaft to the transmission were loose. HE torqued them to specifications, put the exhaust back on and NO MORE KNOCKING NOISE!!! Did not have to do any more than that. Now, I have a good used drive shaft with rubber couplers and a transmission input housing for sale. $550.00 and I will pay the shipping within the 48 states. I am back on the road and this is a good start to what will be a much better year than 2010 was. Thanks to you all for your support and words of encouragement during the last year and a half. Brad Grubbs Bottom line is that the drive shaft rubber coupler bolts were loose on the front of the drive shaft. This message has been edited by robin on 12-03-2017 at 05:04 PM |
posted 12-03-2017 05:38 PM
quote: I heard you do have to pull the motor. A few here may chime in with a better answer. |
posted 12-03-2017 07:10 PM
I remember that member Catfish (RIP) had that problem,,, They had to pull the motor to fix. Expen$ive job as I recall. |
posted 12-03-2017 11:15 PM
John onecatnodog a.k.a. John Collins has a lot of experience with Prowler motors and some others will chime in. I was looking in the shop manual and Chrysler refers to what most call a drive shaft a "propeller shaft". Some trivia, they were being used in boats before cars used them so they used the same name. The first cars were mostly chain drive then in 1903 Clearence Spicer patented the first universal joint used in cars. This message has been edited by padroo on 12-03-2017 at 11:20 PM |
posted 12-22-2017 12:10 AM
Has anyone R&R a prowler driveshaft. I think that is what I am going to do. I bought some Sweet Thunder mufflers ,but I need to replace the driveshaft before I put them on. |
posted 12-22-2017 11:03 AM
Drive shaft noise could be coming from LOOSE bolts on the front & rear of the drive shaft. Loose bolts have been found several times on the Prowler members cars. You might want to check before you tear it apart. The drive shaft can be removed from the car. Takes a little time to do it but it is removable. Check your pinion bearing for up & down movement as this will also cause a noise & they are prone to failure also. Check the bearing before you decide to pull out the drive shaft. I doubt very much that you will find anything wrong with the drive shaft itself. There is also a bearing inside the bell housing that also could be your noise. Do some searching before you spend hours tearing it apart. This message has been edited by phil2237 on 12-22-2017 at 11:05 AM |
posted 12-22-2017 12:04 PM
Checking the torque on the rubber coupler bolts is easy and cheap. I had my output bearing changed (Under Warranty) and they did pull the engine to do it. IF you have to do this assure that they torque the rubber coupler bolts. Took about a year until they became loose. I still have a used driveshaft and transmission input housing for sale if anybody needs them. Make me an offer. |
posted 12-28-2017 03:00 AM
Well guys I finely putin the used driveshaft and what a job it was , had to remove complete exhaust system , remove transmission cooler, had to remove cross members and brackets, then unbolt transaxle and move it back 2-3 inchs . I changed oil, all three, replaced transmission filter and put a drain plug in trans pan. While putting it back together my Sweet Thunder mufflers came so we installed them. good news the noise is goon . We did find a loose bolt on driveshaft to rubber bushing, don't know if that was making the noise, but the noise is goon |
Beachkat2 POA Site Supporter Prowler Junkie From:Wasaga Beach, Ontario, Canada |
posted 12-28-2017 07:59 AM
This tells me that you shouldn't have to remove the engine to replace the bell housing bearing. |
posted 12-28-2017 08:48 AM
Glad you got it fixed, but I would have tried tighten the drive shaft bolts first. |
posted 12-30-2017 09:00 PM
Question....is it possible to have a loose exhaust hangar that would allow exhaust to rub the drive shaft creating this knock? Reason I ask is mine had a sound that was in relation to engine rpm that could have been described as a bearing knock. When the guys did my timing belt I had them see what noise was and they fixed whatever it was but was described as “ hangar was loose, we fixed it with some rubber strap or something”. I have not been able to get car lifted to see what was done . Or maybe they tighten driveshaft bolts....who knows. They didn’t charge me or described it on the bill. This message has been edited by mslc10 on 12-30-2017 at 09:01 PM |
posted 12-30-2017 11:06 PM
Rubbing driveshaft NO but loose hangar could be making the knocking noise. |
