Author | Topic: Code - PO123 |
posted 10-29-2017 11:36 AM
Ok we had a Prowler event this week in Ocala and One of the Prowlers broke down .it ran fine from West Palm Fl. to Bellview fl. the if shut off we were able to restart it but ran ruff then would not start at all . So we checked the codes and it had a code of - PO123 - this is the Throttle Pedal Position Sensor , so we replaced it but it was not a fix . so we were down to a bad fuel pump or the Map Sensor ? after some more checking I tried the Map sensor . It never came up with a code but it cost than a fuel pump . and the car ran fine . the map sensor has 2 small O rings and they were hard as a rock not sure if what was the problem ? but replaced with all new sensor . So if You have this problem try the map Sensor first it might save you some money ... |
posted 10-29-2017 01:00 PM
Thanks for documenting this Jim .. Sure is nice to search and find and answer.. Thanks robin |
posted 10-29-2017 06:04 PM
I had a P0123 code last year and the check engine light came on and I replaced my TPS. I ran it through the emissions and it passed the Indiana pollution inspection but to be honest I never really pushed the car to WOT to really test it out. It ran fine with the code set.
This message has been edited by padroo on 10-29-2017 at 06:08 PM |
posted 10-29-2017 07:18 PM
Guess the MAP sensor was not the final fix. They called me in the afternoon and they were broken down again near Orlando. They were looking for phone numbers for Prowler owners close to where they were. Time to replace the fuel pump? |
posted 10-29-2017 08:03 PM
Yes there is still a problem rand fine till they got to Orlando . and they did get to West Palm .. will know more tomorrow after another code scan might be the fuel pump now but one way or another we will find out why .. |
posted 10-30-2017 02:14 PM
Have you checked these; Crankshaft Position sensor or Camshaft Position sensor. |
tomkovacs Prowler Newbie From:Chicago, IL |
posted 06-14-2018 03:31 PM
Guys, I have a 2001 Kat. My engine runs a little high RPM, I have a P0123 error code that comes and goes, when I start the engine it goes high RPM and then back down (every time especially cold) and also it seems that every once in a while the engine 'stumbles' like for a second there is no gas or something. Does this sound like a Map sensor or fuel pump? Or perhaps the manifold needs to be cleaned out from old oil residue? Any hints you can share? Many thanks. ------------------ |
posted 06-14-2018 03:58 PM
JIM... did they find what the problem was? Always good to see what the fix is. |
posted 06-14-2018 07:38 PM
Fuel pump and replaced it with the Tom Mills pump = main thing but changed many other parts also .. |
