Technical Questions & Answers Anyone kow the name of this or part#?
Author | Topic: Anyone kow the name of this or part#? |
posted 07-07-2016 10:58 AM
It has 4 bolts on the bottom that hold the rear suspension braces on... I scraped and bent the bolts coming out of the garage... Part looks replaceable if I can locate one... |
posted 07-07-2016 11:17 AM
I believe that that is the rear cross member. The part number is 4786823. |
NiteProwl64 Prowler Enthusiast From:Florida |
posted 07-07-2016 12:27 PM
I have to agree. Here is the parts diagram... |
posted 07-07-2016 01:57 PM
One of my bolts broke off with the scraping.. Actually, it broke inside the crossmember. Can a new bolt be welded/heliarched or whatever you call welding aluminum back into the old crossmember?? Any thoughts.., Cost of a new one??? Thank you.. Brad |
posted 07-07-2016 09:03 PM
Many thanks RPL & NightProwl64 for the replies and information!!! |
posted 07-07-2016 10:37 PM
You might be able to drill a hole in the top big enough to install a new bolt if the original hole is clear, then you could tighten it through the hole. If it would weaken it too much structurally, it could be reinforced around the hole but still leaving you access to the bolt head. |
posted 07-08-2016 07:32 AM
quote: Such a simple solution. Maybe a large washer under the nut on the bottom. I found the part on EBAY for $151.00 (Seems reasonable). Thank you!!! A further note: I took mine off a few years ago and sanded, buffed and polished it. Still looks great. This message has been edited by BradleyG on 07-08-2016 at 08:17 AM |
posted 07-17-2016 08:30 AM
Update, The part number from RPL was spot on... I found the part on ebay for $134.00 with free shipping and also ordered an extra ... Installation was easy and issue solved... Many thanks to all that helped.. This remains the best site in history!!! |
