  Technical Questions & Answers
  Lateral Link Seals (ball joint type)
Author Topic:   Lateral Link Seals (ball joint type)
aoprowler
Prowler Newbie
posted 01-03-2012 07:58 PM     Click Here to See the Profile for aoprowler     send a private message to aoprowler   Edit/Delete Message   Reply w/Quote   Search for more posts by aoprowler
Help! I only have 14,000 miles on my 2002 CAT and the dust seals on the 4 rear Lateral Links (ball joint type) are shot *#@% Does anyone know where to buy these seals? Also someone posted here that you can run these dry since they have nylon surrounding the bearing inside, if that the case maybe i can just remove the old seal & grease and re-install them dry.
This message has been edited by aoprowler on 01-03-2012 at 08:00 PM
George Johnson
posted 01-03-2012 08:08 PM     Click Here to See the Profile for George Johnson     send a private message to George Johnson   Edit/Delete Message   Reply w/Quote   Search for more posts by George Johnson
You can't replace just the rubber boots, and probably the bushings could be bad. Contact Bob Longstreth (RPL), he was selling the after market rear lateral links, which are a much better quality than the OEMs.
quincy
posted 01-04-2012 05:46 PM     Click Here to See the Profile for quincy     send a private message to quincy   Edit/Delete Message   Reply w/Quote   Search for more posts by quincy
aoprowler,
Are you referring to the links under the hood, near the front of the vehicle, close to the battery? Or the rear links viewable thru the spokes of the rear wheels? The rears, I believe, have bushings (rubber) that crack and deteriote causing them to skew and most likely clunk. RPL does have good quality replacements for the rears. The front Heim joints, under the hood, can be cleaned of any grease and ran dry. They have a nylon sleeve internal to the female cup. Not much movement occurs in the front units; it would most likely take a life time to 'wear them out'.
aoprowler
Prowler Newbie
posted 01-04-2012 08:57 PM     Click Here to See the Profile for aoprowler     send a private message to aoprowler   Edit/Delete Message   Reply w/Quote   Search for more posts by aoprowler
quincy,
I am referring to the rear links the newer ball joint type.
Originally posted by quincy:
aoprowler,
catfish
posted 01-05-2012 03:33 PM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
in the frt,are you talking the frt.swaybar.there are no lateral links in the frt.if still available the 99 rr. links will work on the rr ,at way way less money,something like 36.00 each.
This message has been edited by catfish on 01-05-2012 at 03:59 PM
aoprowler
Prowler Newbie
posted 01-05-2012 07:45 PM     Click Here to See the Profile for aoprowler     send a private message to aoprowler   Edit/Delete Message   Reply w/Quote   Search for more posts by aoprowler
Catfish, I have 2002 that have the ball joint type lateral links (located in the rear) would rather not use earlier type (bushing type). I just need the dust/grease seals.
catfish
posted 01-05-2012 08:37 PM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
the 99 links will last just as long,if not longer than the
newer style,i have 135.000 miles on mine here in hot az,and they are still in great shape,choose your poison,you cannot buy parts for the links,you must buy the entire link,and yours are not cheap.your list price is around 550.00 each.x 4.whichever way you go adjust the new ones to match the length of the old ones or you will have to do a wheel alignment.
spoons
posted 01-20-2012 01:19 PM     Click Here to See the Profile for spoons     send a private message to spoons   Edit/Delete Message   Reply w/Quote   Search for more posts by spoons
I don't think there are any of the 1997 & 1999 style rear lat links left in Mopar inventory. OEM links for 2000+ prowlers with cost you $2000+ for all four. Control Freak Suspensions makes and aftermarket set for around $600. You can buy the aftermarket rear lat links from Control Freaks or Bob (RPL). Its the same part and the same price.
Control Freaks Phone # 407-696-2772
This message has been edited by spoons on 01-20-2012 at 01:20 PM
stprinz
posted 01-21-2012 09:27 AM     Click Here to See the Profile for stprinz     send a private message to stprinz   Edit/Delete Message   Reply w/Quote   Search for more posts by stprinz
I JUST INSTALLED THE REAR LATERAL LINKS FROM CONTROL FREAK - AWESOME PRODUCT - I ALSO GOT THE FRONT LATERAL LINKS FROM SPOONS - ALSO AWESOME PRODUCT - THE CAR CHANGED COMPLETTLY, IS A ALL NEW CAR DRIVING IT. ALSO THE CHRYSLER DEALER WHICH INSTALLET THE LINKS SAID THAT HARE THE BEST LINK'S HE EVER SEEN......
THNAK'S TO SPOONS BY THIS WAY ......
CCJ
posted 05-22-2014 12:42 AM     Click Here to See the Profile for CCJ     send a private message to CCJ   Edit/Delete Message   Reply w/Quote   Search for more posts by CCJ
Good info to know. Thank you
RPL
posted 05-22-2014 07:36 AM     Click Here to See the Profile for RPL     send a private message to RPL   Edit/Delete Message   Reply w/Quote   Search for more posts by RPL
No one has figured out that mine are less costly for fellow Prowler owners.....Don't tell anyone it's a secret.
Control Freak makes great products.
This message has been edited by RPL on 05-22-2014 at 07:39 AM
golfboy
posted 05-22-2014 12:59 PM     Click Here to See the Profile for golfboy     send a private message to golfboy   Edit/Delete Message   Reply w/Quote   Search for more posts by golfboy
Control Freak lateral links and Spoons' VSLs make my Kat handle much better when going around curves at speed. I recommend both.
RJGR0713
Prowler Enthusiast
posted 06-01-2014 06:31 PM     Click Here to See the Profile for RJGR0713     send a private message to RJGR0713   Edit/Delete Message   Reply w/Quote   Search for more posts by RJGR0713
Bob how much are the Control Freak Lateral Links from you?
RJGR0713
Prowler Enthusiast
posted 06-01-2014 06:32 PM     Click Here to See the Profile for RJGR0713     send a private message to RJGR0713   Edit/Delete Message   Reply w/Quote   Search for more posts by RJGR0713
Just ordered the Front Stabilizer links from Spoons
aturner104
posted 01-08-2020 10:33 AM     Click Here to See the Profile for aturner104     send a private message to aturner104   Edit/Delete Message   Reply w/Quote   Search for more posts by aturner104
What exactly is a "Front Stabilizer Link"? Does it go by any other name?
mslc10
posted 01-08-2020 08:36 PM     Click Here to See the Profile for mslc10     send a private message to mslc10   Edit/Delete Message   Reply w/Quote   Search for more posts by mslc10
In the below, they are the two thin rods that connect the sway bar to suspension .
And in this link is more:
http://www.prowleronline.com/ubb/Forum21/HTML/000060.html
This message has been edited by mslc10 on 01-09-2020 at 01:53 PM
aturner104
posted 01-09-2020 10:55 AM     Click Here to See the Profile for aturner104     send a private message to aturner104   Edit/Delete Message   Reply w/Quote   Search for more posts by aturner104
Does the often-mentioned "Wonderbar" replace these parts?
aturner104
posted 01-09-2020 10:57 AM     Click Here to See the Profile for aturner104     send a private message to aturner104   Edit/Delete Message   Reply w/Quote   Search for more posts by aturner104
By the way, thanks so much for responding to my question.
mslc10
posted 01-09-2020 01:44 PM     Click Here to See the Profile for mslc10     send a private message to mslc10   Edit/Delete Message   Reply w/Quote   Search for more posts by mslc10
yessir . the wonder bar replaces the large thick "sway bar" in the pic I posted. you will still need the two thin rods "front stabilizer links".those can be replaced by the ones from member "spoons". The stock sway bar is solid vs. the wonder bar is essential a tube, allowing the suspension to "give" and not be so stiff in corners and going over rough roads. there have been Complaints of car just "changing lanes" as it hits a pot hole or such.The wonder bar is developed to cure that. Doing your homework you will find depending on what year seems to decide how beneficial it is. Earlier models seem to have a better response to the wonder bar, 2000 being the line of depreciating gains. I have a 2000 with the wonder bar and its worth the money.
On another note: the front frame tie bar that ties the front "towers" together didn't do anything noticeable to mine. It didn't cost much, just a bar of aluminum and drilling some holes, so no big outlay.
This message has been edited by mslc10 on 01-09-2020 at 02:00 PM
aturner104
posted 01-10-2020 04:15 AM     Click Here to See the Profile for aturner104     send a private message to aturner104   Edit/Delete Message   Reply w/Quote   Search for more posts by aturner104
Many thanks for the additional information.Very glad I joined ProwlerOnline!
Chose
posted 01-22-2020 04:32 PM     Click Here to See the Profile for Chose     send a private message to Chose   Edit/Delete Message   Reply w/Quote   Search for more posts by Chose
http://www.prowleronline.com/ubb/Forum1/HTML/025042.html
You whant this?
Chose
posted 01-25-2020 04:01 PM     Click Here to See the Profile for Chose     send a private message to Chose   Edit/Delete Message   Reply w/Quote   Search for more posts by Chose
Lateral link dust seal kit for Prowler 2001 95,00$ canadian cheap dollars... Shippping not included
