Author | Topic: SRV Removal |
posted 12-17-2011 09:52 AM
I am wanting to remove the Short Runner Valve (SRV) to polish or chrome it. Is it necessary to disconnect the negative cable on the battery before removing it? Thanks! |
posted 12-17-2011 10:23 AM
You do not have to disconnect the battery, although Do Not try to start without it hooked up as it will set a code. |
posted 12-17-2011 04:16 PM
its steel,not polishable,i would be carefull about chroming.it may ruin the valve since it has a vaccum operated valve inside. ------------------ |
Y2KRedProwler Prowler Junkie From:Los Angeles Area, CA,USA |
posted 12-17-2011 08:33 PM
What does a Short Runner Valve do? |
posted 12-17-2011 10:46 PM
And why do the 97's not have one? |
posted 12-18-2011 08:10 AM
"The SRV system operates under WOT conditions above 5000 rpm to maximize engine performance. When actuated by the PCM, the SRV solenoid energizes, allowing mechanical linkage to redirect the intake air flow to six short runners." quote from Service Manual. I don't think the SRV engages until the engine hits 5000 rpms... which I never do unless by accident. Also, I believe there was a post in the past from someone who had removed the SRV and polished it. I tried finding it but couldn't. This message has been edited by George Johnson on 12-18-2011 at 08:14 AM |
posted 12-18-2011 08:19 AM
Obi Wan use to sell these chromed already, but I don't beleieve you can polish them. I took mine off and painted it silver because black paint was chipping off anyway. |
posted 12-18-2011 11:01 AM
George, this might be a stupid question, but what are "WOT conditions?" Make the answer simple so I don't bother you with yet another question!..lol |
posted 12-18-2011 11:22 AM
WOT I believe refers to Wide Open Throttle. |
posted 12-18-2011 11:48 AM
I was able to polish mine. Takes some elbow grease but it can be done... |
posted 12-18-2011 01:30 PM
Curt, you must be mistaken, it is not polishable. lol |
posted 12-18-2011 02:56 PM
fu ed. |
posted 12-18-2011 03:26 PM
Uh, The first thing you do with steel before chroming is to polish it. Any plating will just mimic the surface it's on. |
posted 12-18-2011 03:27 PM
posted 12-18-2011 03:38 PM
quote: Inside the manifold there are two paths the fuel/air mixture can take. One is the long way, around the outer edge and down the individual runners to the intake valves. The other is a more direct route straight down the center of the manifold to the valves. Inside the manifold there are butterflies the same as on the throttle body or a carburetor. During a Wide Open Throttle condition the SRV turns and opens the butterflies so the fuel/air mixture can take the short route. In the old days of carburetors you had short runner manifolds such as "Torkers" and long runner manifolds, typically dual plane manifolds. Each had it's benefits for a certain rpm range of the engine. The Prowler manifold is like have both of these at your disposal when the need arises. ------------------ |
posted 12-18-2011 04:20 PM
posted 12-18-2011 11:01 PM
quote: You are off my "minion" list and are now lumped in with a guy north of me. Sorry about your luck. |
posted 12-19-2011 06:10 AM
quote: Catfish, Pleade put me on the growing fu ed list. |
posted 12-19-2011 06:54 AM
quote: ............................................................
toys This message has been edited by toys on 12-19-2011 at 07:49 AM |
posted 12-19-2011 07:12 AM
Spell check said "fu" was misspelled.....the first three choices were "flu, fun, fur" This message has been edited by Y2KRedProwler on 12-19-2011 at 07:24 AM |
posted 12-19-2011 07:45 AM
quote: Thank you cstall...I knew I had read a post of someone polishing the SRV... |
posted 12-19-2011 09:53 AM
I polished mine many years ago. It does not require much to keep it looking almost as shiney as chrome. |
posted 12-19-2011 12:41 PM
I've been on a few Sh## lists before but not a fu ed list! Roger, what makes you think ed is talking about you? Nice post, I learned something today. This message has been edited by padroo on 12-19-2011 at 12:42 PM |
posted 12-19-2011 01:17 PM
toys[/B][/QUOTE] ABSOLUTELY ZERO People skills is the main requirement. |
posted 12-19-2011 05:39 PM
quote: He's painfully transparent. A fetus would have one up on that clown. |
