Technical Questions & Answers How to remove and install convertable pin insert
Author | Topic: How to remove and install convertable pin insert |
Jim C Prowler Junkie From:Corona, Ca |
posted 08-24-2011 06:43 PM
How do I safely remove and replace the convertible pin insert on the top of the wind shield? These are the ones that guide the pins to the top on the wind sheild before you latch the top down. On order expensive little plastic part, $21.97 a piece! This message has been edited by Jim C on 08-24-2011 at 09:35 PM |
posted 08-25-2011 01:01 AM
it snaps in place.if its loose or you break a tab,use some 100 percent silicone sealer or something similar,will hold it in place. ------------------ |
posted 08-25-2011 10:40 AM
quote: catfish, thanks how about the removal of the old ones? the tops are almost completely gone I don't want to damage that bezel. |
posted 08-25-2011 01:10 PM
Ask your dealer for the same part for a Sebring. They told me the Prowler part was back ordered,so I bought the Sebring part, which they had in stock. It fit perfectly and cost a lot less. |
posted 08-25-2011 01:24 PM
tried to send you a pm,but its blocked. ------------------ |
quote: Where did you order that piece from i have one that is cracked was thinking about some krazy glue. |
posted 08-25-2011 03:24 PM
quote: Yes I did same number and same price $21.97 P/N 4410254 This message has been edited by Jim C on 08-25-2011 at 03:37 PM |
posted 08-25-2011 03:33 PM
quote: Tried the super glue did not last long... This message has been edited by Jim C on 08-25-2011 at 03:36 PM |
posted 08-25-2011 05:13 PM
when you get your new part,look and see where the locking tabs are located.i think there on the circular hole where the pin fits in.i think you need something with a short hook on the end to release it.you will know when you get the new part.its possible you may have to release the bezel and then remove insert.its been quite awhile,since i had one apart.a tip to avoid breaking the insert in the future,make sure the pins line up perfectly with the hole in the insert,those are guide pins and sometimes are a little off of center.also when lowering frt of top onto header,dont just let it drop,do it gently.usually the insert gets broken or cracked from dropping the frt of the top onto the w/s header,and if dropped and pins a little out of alignment it will crack/break the inserts. ------------------ This message has been edited by catfish on 08-25-2011 at 05:26 PM |
posted 08-25-2011 06:27 PM
posted 08-25-2011 08:17 PM
I guess if you slam down the front of the top and it doesn't align with the hole it will get cracked eventually. |
posted 08-25-2011 09:19 PM
those chrome pins are adjustable,and easy to align with the hole in insert. ------------------ |
posted 08-25-2011 09:52 PM
quote: No won't happen again. When I noticed it I checked the pin alignment.It was cracked on the outer square flange that rest on the bezel the inner conical area was fine. First time I seen it the pieces where still attached so I tried to supper glue them worked for awhile.It's been cracked for years just never got around to replacing them. This message has been edited by Jim C on 08-25-2011 at 10:11 PM |
