Technical Questions & Answers alternative speaker replacement
Author | Topic: alternative speaker replacement |
prowler emil Prowler Junkie From:beverly hills, ca, usa |
posted 07-17-2011 05:18 PM
What are the exact dimensions of our door speakers? I've searched and it seems its a 6.5" or 6.75" speaker, but what is the mounting depth? I will be trying to find other speakers that come 'stock' on other cars that would fit in our doors. Before everyone tells me to get the inifinity speakers, I'm looking for a speaker with a paper cone so I can actually hear the lower frequencies--unfortunately all aftermarket plastic cone speakers don't hit the low freq. So |
posted 07-17-2011 08:30 PM
Buy the Kappa's Infinity 63.9i Bolts right in , no drilling needed.Sounds good also. |
posted 07-17-2011 10:16 PM
Depth from mounting ring on the speaker to bottom of magnet is 2 1/8". Mounting diameter is 6 3/4" |
kb7obj Prowler Junkie From:glendale,az usa |
posted 07-17-2011 11:39 PM
i just replaced mine with the kappa 63.9's and i hate them. factory speakers sounded much better for the bottom end punch |
posted 07-18-2011 01:28 AM
quote: Thanks for reading the post in its entirety, could've saved yourself some time.....
quote: Thank you--exact info I was looking for!
quote: Agreed. Aftermarket (plastic cone) speakers are great for the mids and highs--great clarity and loudness, however just cannot flex like the stock paper cone speakers that most cars come with from the factory. Without getting a new sub, it will never sound the same. A lot of newer cars are coming out with reliable paper cone speakers that would be great replacements. Now the research begins... |
Ken & Roslin Romain POA Site Supporter Prowler Junkie From:Gallatin TN |
posted 07-18-2011 10:12 AM
That is the first BAD thing I've heard about the Kappa's. We have put in no less then a dozen sets for our local owners, and they all love them. I've had mine in for several years, the difference between original and Kappa's is like day and night. |
posted 07-18-2011 11:01 AM
quote: I have to agree with Ken, huge difference compared to the oem's |
Jim C Prowler Junkie From:Corona, Ca |
posted 07-18-2011 12:35 PM
They pretty much are all plastic cones nowadays mainly because the paper and foam outer ring disintegrate Good luck on your search... This message has been edited by Jim C on 07-18-2011 at 05:09 PM |
posted 07-18-2011 12:46 PM
You might try these speakers by Planet audio http://www.amazon.com/Planet-Audio-AP625-6-5-Inch-Treated/dp/B002QUZHRS or you could buy exact replacement speakers but they go for about $65 each. |
posted 07-18-2011 10:44 PM
Nobody said anything bad about the kappa speakers. Please read carefully. All aftermarket speakers are designed specifically for the mid and high frequencies. When properly upgrading your audio, you get tweeters forte high freq, regular speakers for the mid, and a sub for the low freq. The speakers that come from the factory have a paper come or some different material that allows them to hit the low frequencies. Kappas are great at serving their purpose, but at low freq, like all aftermarket speakers, they suck. Since we can't put in a real sub anywhere, I'm looking for a good 'all around speaker' that's capable of hitting those low freq. Hell sit in any newer Nissan and turn the bass up. Those are far superior to our stockers and are not aftermarket. |
posted 07-19-2011 11:23 AM
posted 07-19-2011 01:57 PM
In my last post I stated "paper cone or some other material" Point is, stock speakers hit low frequencies much better than aftermarket. |
Eric Wolf POA Site Supporter Prowler Junkie Personal ScrapBook From:New Westminster, British Columbia, Canada |
posted 07-21-2011 04:08 PM
I found that if you just install the Kappa speakers in the doors thay sound poor, if you change the dash and rear spealers as well they balance themselves out and sound OK. |
posted 07-22-2011 05:15 PM
i changed dash, doors and rear ( except rear sub ) will have it re coned . still not happy. I guess for a car i drive now and then it will due. |
posted 08-20-2011 12:09 PM
I just had kappas installed. The audio guy told me our amp did not allow full power to go to the door speakers. He said the system is designed to primarily allow midrange to the doors, high to the front and back and base to the sub. |
posted 08-20-2011 11:29 PM
removed This message has been edited by kb7obj on 08-22-2011 at 12:36 AM |
posted 08-21-2011 12:24 AM
He's not talking about stock speakers. kb7obj - have you adjusted your equalizer for more base? |
posted 08-21-2011 09:18 AM
His point was the amp will not allow the Infinity Kappa speakers to perform to their full potential, specifically the tweeter. |
posted 08-21-2011 01:47 PM
At this point I am glad I am old and getting hard of hearing. If they aren't buzzing or chirping, they are good enough for me. |
posted 08-21-2011 06:46 PM
My God guys, haven't you all heard of low pass and high pass filters? You can tailor the sound to your liking and can cut the high treable quite easily |
posted 08-21-2011 07:22 PM
To be clear,I am happy with the sound. I think it is much improved over stock. I'm just relaying what I was told. |
posted 08-22-2011 01:12 AM
Someone else posted the same info years ago. |
paulmyers Prowler Enthusiast From:London, England |
posted 01-21-2012 09:01 AM
I'd prefer to replace with original door speakers too. Anyone know the part number or a supplier? |
